Soundcore Liberty Air 2 charging case Teardown
crwdns2936025:09crwdne2936025:0 —
Remove the two phillips #00 screws from the main circuit board
There is a connector cable that needs to be removed from the print plate. This can be removed by gently pulling out the main circuit board from the inner case
When putting the main circuit board back in the case, it might be little tricky to connect to the print plate due to limited space. Do not forget to lift the black plate at the connector port and closing the black plate after it is connected.
