Soundcore Liberty Air 2 charging case Teardown
crwdns2936025:01crwdne2936025:0 —
Jimmy a pick between the inner and outer casing as depicted on the picture. Carefully use it as a bit of a lever to lift the inner casing a little. A sturdier item is required.
There are no wires or other components (besides the magnets) between inner and outer casing, so do not worry if you jam it in too deep.
