Fairphone True Wireless Earbuds Teardown
crwdns2936025:02crwdne2936025:0 —
We kick off disassembly with the most removable, and cleanable, bit: the flexible tips—much like you find on competing models, including AirPods Pro. With three different size options, you've got a good chance of finding a set that fits.
Next: hoping to keep it nondestructive, we aim for a likely seam and get slicing with an opening wheel—luckily no heat required!
The plate we peel up has the touch controls mounted to it, but your taps are communicated via spring contacts, so no booby trap cables in sight!
Inside, we can already spot the glued-in motherboard. Forcing it out seems unwise, so we'll backtrack a bit—and try what has become our standard opening procedure for the generally not-so-repairable earbud category.
