Iomega ZIP 250 MB External USB Teardown
crwdns2936025:05crwdne2936025:0 —
Remove three silver screws (Phillips 000) from blue component.
Carefully peel off adhesive on wiring (flex pcb) to remove from blue component.
Unlatch the spring.
Lift and slide blue component out of disk drive casing.
Push blue tab on either side to release the blue casing from metal component.
Carefully peel off adhesive on wiring (flex pcb) to fully remove the blue component from metal.
Remove plastic arm and spring from drive body.
