crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Iomega ZIP 250 MB External USBcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Iomega ZIP 250 MB External USB Teardown, Remove the Covers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push pin into holes on sides to release the top blue casing.
    • Pull blue casing out of side slots located in each corner.
    • Remove the back end cover panel by pulling it outwards.
    • Remove front panel by inserting push pin into holes.
    • Remove the back panel.
    • Remove rubber feet nubs.
  2. Iomega ZIP 250 MB External USB Teardown, Access Internal Assembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega ZIP 250 MB External USB Teardown, Access Internal Assembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove light silver screws (T6) from black piece on circuit board.
    • Slide the assembly out of bottom casing.
  3. Iomega ZIP 250 MB External USB Teardown, Separate Internal Parts: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Iomega ZIP 250 MB External USB Teardown, Separate Internal Parts: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Iomega ZIP 250 MB External USB Teardown, Separate Internal Parts: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four light silver screws (Phillips 00) on the bottom of the assembly.
    • Remove three black screws (Phillips 000) to remove disk drive from circuit board.
    • Remove the circuit board and admire.
  4. Iomega ZIP 250 MB External USB Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Front Main PCB IC Identification:
    • You may need to enlarge it to view the text.
  5. Iomega ZIP 250 MB External USB Teardown, Removal of the Blue Part: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Iomega ZIP 250 MB External USB Teardown, Removal of the Blue Part: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Iomega ZIP 250 MB External USB Teardown, Removal of the Blue Part: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three silver screws (Phillips 000) from blue component.
    • Carefully peel off adhesive on wiring (flex pcb) to remove from blue component.
    • Unlatch the spring.
    • Lift and slide blue component out of disk drive casing.
    • Push blue tab on either side to release the blue casing from metal component.
    • Carefully peel off adhesive on wiring (flex pcb) to fully remove the blue component from metal.
    • Remove plastic arm and spring from drive body.
  6. Iomega ZIP 250 MB External USB Teardown, That Ejector Arm: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Iomega ZIP 250 MB External USB Teardown, That Ejector Arm: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two springs from top corner (17mm) and middle section (20mm).
    • Remove two screws (Phillips 00) on back left corner of drive.
    • Remove eject button shaft by sliding out of slot in drive and lifting out off black arm.
    • Lift and twist the white latch on silver circle and slide the black arm sideways.
    • Slide out smaller black lever from drive body.
  7. Iomega ZIP 250 MB External USB Teardown, Disk Drive Body: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Break spot welds by jamming a flathead screwdriver into cracks.
    • Remove gear system from back corner.
    • Remove black spring arm by pushing tab on bottom side of the case.
    • Break small white plastic plugs.
    • Remove circular reader from metal body casing.
    • Remove white plastic ring from reader.
    • Bend front door slightly to pop it out of casing.
    • You're all done! Pat yourself on the back.
    • Take a photo to remember this fantastical moment of your accomplishment!
Boo
crwdns2935283:003/22/20crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
I had a stuck cartridge and followed the instructions up to Step 3 where I was able to get it to eject! Put everything back together and the eject mechanism is working again!! Also added a bit of lubricant to the eject mechanism before I reassembled the unit. Sucess!! Thanks. :-)
GARY J WIMMER - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,150
