Western digital Hard drive tear down
Remove four screws and circuit board lifts out
Motor contacts
Head contacts
Remove 6 perimeter screws
Remove screw from under sticker
Lift cover off
Maybe rotate 1st photo 180 degrees so the orientation matches photo 2. Also in photo 1 highlight the location of the hidden screw.
Inside of hard drive
Desiccant packet removed from lower right corner
Inside of cover
Head in dock
Head on disk
Dock removed
Head before bridge removed
Remove two screws
Lift bridge away
Highlight screw location in photo 1. Provide driver tip used to remove screws.
Stops to limit head travel
Red coil over magnet cause the head to rotate
Contact block installed
Remove two screws, contact block is now loose but connected to head by a ribbon cable
Add driver tip size. Highlight ribbon cable as it blends in with body.
Disk installed
Remove 3 screws holding down collar
Remove collar
Highlight the screw faces please. The screw faces blend in with the collar.
Lift disk out of case
Collar after removal
Head installed, simply lift head out of case
Remove head
Case without head
Removed head
Contacts for data and head control
Head interface to disk
Remove magnet
Remove stop for head on disk
Remove head docked stop
What is the purpose of the black strip below where the head use to be?
All components arranged
Well done Wieli! Your photographs are very clear and well lighted. Should you decide to edit the guide may I suggest (1) you add what screwdriver tips you used to remove screws and (2) at step 10, highlight the three screws. The screw tips blend in with the collar.
