crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0WD blue Hard Drivecrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. WD Blue Hard Drive Teardown, Exterior of Hard drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Exterior of Hard drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Exterior of Hard drive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pre-disassembly
  2. WD Blue Hard Drive Teardown, Remove circuit board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Remove circuit board: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four screws and circuit board lifts out
    What screwdriver tip fits the screws?
    Jim Fogle - crwdns2934203:0crwdne2934203:0
  3. WD Blue Hard Drive Teardown, Circuit board interfaces: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Motor contacts
    • Head contacts
    Excellent. Love the highlights. They help a lot.
  4. WD Blue Hard Drive Teardown, Removing top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Removing top cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Removing top cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 6 perimeter screws
    • Remove screw from under sticker
    • Lift cover off
    Maybe rotate 1st photo 180 degrees so the orientation matches photo 2. Also in photo 1 highlight the location of the hidden screw.
  5. WD Blue Hard Drive Teardown, Inside details: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Inside details: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Inside details: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Inside of hard drive
    • Desiccant packet removed from lower right corner
    • Inside of cover
  6. WD Blue Hard Drive Teardown, Head details and dock removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head details and dock removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head details and dock removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Head in dock
    • Head on disk
    • Dock removed
    What size driver tip is used to remove the screw?
  7. WD Blue Hard Drive Teardown, Head removal p1: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head removal p1: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head removal p1: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Head before bridge removed
    • Remove two screws
    • Lift bridge away
    Highlight screw location in photo 1. Provide driver tip used to remove screws.
  8. WD Blue Hard Drive Teardown, Head travel limits: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Head travel limits: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Stops to limit head travel
    • Red coil over magnet cause the head to rotate
  9. WD Blue Hard Drive Teardown, Head contact removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Head contact removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Contact block installed
    • Remove two screws, contact block is now loose but connected to head by a ribbon cable
    Add driver tip size. Highlight ribbon cable as it blends in with body.
  10. WD Blue Hard Drive Teardown, Disk removal p1: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Disk removal p1: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Disk removal p1: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disk installed
    • Remove 3 screws holding down collar
    • Remove collar
    Highlight the screw faces please. The screw faces blend in with the collar.
  11. WD Blue Hard Drive Teardown, Disk removal p2: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Disk removal p2: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift disk out of case
    • Collar after removal
  12. WD Blue Hard Drive Teardown, Head removal p2: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head removal p2: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head removal p2: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Head installed, simply lift head out of case
    • Remove head
    • Case without head
    May want to identify the platter motor in photo 3
  13. WD Blue Hard Drive Teardown, Head details: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head details: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Head details: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removed head
    • Contacts for data and head control
    • Head interface to disk
    Photo 3 is a great photo. Well done!
  14. WD Blue Hard Drive Teardown, Empty case: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WD Blue Hard Drive Teardown, Empty case: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove magnet
    • Remove stop for head on disk
    • Remove head docked stop
    What is the purpose of the black strip below where the head use to be?
  15. WD Blue Hard Drive Teardown, Components laid out: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Components laid out: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WD Blue Hard Drive Teardown, Components laid out: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • All components arranged
Wieli
crwdns2935283:001/08/23crwdne2935283:0
2,141 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
Well done Wieli! Your photographs are very clear and well lighted. Should you decide to edit the guide may I suggest (1) you add what screwdriver tips you used to remove screws and (2) at step 10, highlight the three screws. The screw tips blend in with the collar.
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 163
crwdns2942667:0crwdne2942667:0 5,869
