Eufy Video Doorbell 2K (Battery-Powered) a doorbell security camera that can be installed outdoors. Unfortunately for my unit, water got inside and fried a chip rendering the unit inoperable after 2 years of service. Since Eufy does not have a repair centre here in Malaysia, I decided to open it up and take a look inside.
note: Most of the images I took was is Portrait, thus images might be slightly weird or looks like it was rotated to the left.
Using Phillips 000 screw driver remove 8 screws at the back.
Battery is connected to the main board. Using a tweezer remove the battery connector.
Remove 4 screws with a Phillips 000.
Remove 2 screws with a Phillips 0.
Disconnect the connector.
CCD of the camera
crwdns2947412:010crwdne2947412:0
Goodacternoon po Maam/Sir?
pwedi poba mag order board lang
And what happends next?
This is great. Any suggestions for sourcing a new battery pack?
My battery may be shot. Same as in pics. Where can I get a replacement?
I tried changing the battery in mine. Got it sourced individual cell and attached to the existing points (by removing old cells). It got really hot. Seems my chip got fried as well. Not sure how to check if there is anything else faulty than BAttery Chip?
Hello Rishi, I am planning to do the same. DO you have any recommendations? Hopefully chip should not fry
For anyone interested, the batteries are just bog standard 18650s wired in parallel. The trick is the soldering of connections to the batteries; usually these connections are spot welded, but not everyone has a spot welder.
Hello, I need to replace the antenna, but I can not find it. Do you have an idea of the place of the antenna ???????
Thanks so much
Where I can get the new pack of battery?
where to get new battery from?
