crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Eufy Doorbell 2k (Battery-Powered)crwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Eufy Video Doorbell 2k (Battery-Powered) Teardown, Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using Phillips 000 screw driver remove 8 screws at the back.
  2. Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a metal or plastic prying tool, insert it in between the seems. Then carefully lift the back unit out. Once one side is open simply lift it out from the front cover.
  3. Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Battery is connected to the main board. Using a tweezer remove the battery connector.
  4. Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Water manage to get into my unit and fried this chip. Suggest you use a rain cover if this doorbell is expose to weather outdoors. There are a lot of 3D printed rain covers for this doorbell.
  5. Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4 screws with a Phillips 000.
    • Remove 2 screws with a Phillips 0.
  6. Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the connector.
    • CCD of the camera
    • Do not touch the CCD. If finger prints got stuck it will be difficult to clean.
  7. Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Eufy Video Doorbell 2k (Battery-Powered) Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Battery details and specification.
    • You can use a multimeter to check the voltage of the battery. Mine was still good at 3.9V. Unfortunately the chip got fried.
Muzaffar
crwdns2935283:005/12/19crwdne2935283:0
155 crwdns2915208:0crwdne2915208:0
crwdns2947412:011crwdne2947412:0
Goodacternoon po Maam/Sir?
pwedi poba mag order board lang
LAMPUTE VENT - crwdns2934203:0crwdne2934203:0
This is great. Any suggestions for sourcing a new battery pack?
Tezza - crwdns2934203:0crwdne2934203:0
My battery may be shot. Same as in pics. Where can I get a replacement?
Joe Guy - crwdns2934203:0crwdne2934203:0
I tried changing the battery in mine. Got it sourced individual cell and attached to the existing points (by removing old cells). It got really hot. Seems my chip got fried as well. Not sure how to check if there is anything else faulty than BAttery Chip?
Rishi Gaurav Gupta - crwdns2934203:0crwdne2934203:0
Hello Rishi, I am planning to do the same. DO you have any recommendations? Hopefully chip should not fry
Bhargav Mehta -
For anyone interested, the batteries are just bog standard 18650s wired in parallel. The trick is the soldering of connections to the batteries; usually these connections are spot welded, but not everyone has a spot welder.
David Griffin - crwdns2934203:0crwdne2934203:0
Hello, I need to replace the antenna, but I can not find it. Do you have an idea of the place of the antenna ???????
Thanks so much
Dom Otic - crwdns2934203:0crwdne2934203:0
Where I can get the new pack of battery?
Kelvin Leung CK - crwdns2934203:0crwdne2934203:0
where to get new battery from?
papa test - crwdns2934203:0crwdne2934203:0
i have a different model that uses a single INR21700M50T, but I bought a replacement battery and it still refuses to charge above 3%
Rafael Zuniga BalikbayanBok - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 270
crwdns2942667:0crwdne2942667:0 5,809
