Time flies: it's been eight months since Apple announced its (digital) crowning achievement, the Apple Watch. Join us as we make time stand still by tearing down the Apple Watch—and see what makes it tick.
Update: We've got more Apple Watch teardown goodness! When you're done here, wind your way over to our X-ray teardown.
The good times never end at iFixit—and you can be a part of the fun by following us on Instagram, Twitter, and Facebook!
crwdns2936621:0crwdne2936621:0
            Ladies and gentlemen, the Apple Watch has arrived. But before we get down to the brass tacks, here's a quick overview of the tech specs:
            Pressure-sensitive, flexible, touchscreen AMOLED Retina display
            Custom-designed Apple S1 SiP (System in Package)
            8 GB onboard storage
            NFC + Wi-Fi 802.11b/g/n + Bluetooth 4.0
            Accelerometer + gyroscope + heart rate monitor + microphone + speaker
            Watch OS
            So ends the wait. The Apple Watch has arrived, and our first course of action is to unbox it.
            While we'd hoped to find a golden ticket inside, we'll settle for the next best thing: the Apple Watch Sport, complete with its Sport Band, charging cradle, and power adapter.
 That settles it: I'm getting the blue band. I think it looks pretty slick (as does the packaging). I went with the blue band for mine. Can't wait to see it in person :) John -
            We were all set to disassemble the Apple Watch until we got distracted by a fancy graphic visualization. Oooh, pretty colors.
            Not sure how to fasten that fancy Sport Band? Have no fear—Apple included instructions right on the back of the band!
            There's no need for pesky charging cables—the Apple Watch features MagSafe inductive charging technology, which allows it to magnetically attach to the charger. Apple also touts that it is a "...completely sealed system free of exposed contacts."
 Can you please post the exact measurements of the charger? Thank you and blue skies! The charging cradle is 6.7 mm thick with a diameter of 28 mm.
            We turn our attention to the back of the case, where we find a composite cover with hard-coated, optical polymer lenses protecting a set of LEDs and photodiodes.
            The specially designed heart rate sensor uses a combination of infrared and visible-light sensors to gauge your heart rate.
            Opposite the Digital Crown, we find the microphone and speaker ports.
 I think the back piece on the Sport watch is composite, not ceramic Correct. According to footnote on Apple Watch site: "Sport models have a composite back with hard coated optical polymer lenses." http://www.apple.com/watch/technology/ The backs on the Watch and Edition collections are zirconia ceramic with sapphire crystal lenses Good catch. We've updated the teardown. Thanks! Not an LCD, so no LCD connector. Sam - So does this mean it is an OLED screen if not LCD? ..and the microphone is from?
            Before laying it out on the chopping block, we'll try something non-destructive: removing the band.
            If you're looking forward to swapping out bands, there's not much to it, physically. However, Apple would prefer that you only use bands from the same collection. No Link Bracelets on your Watch Sport, please.
            The Sport Band is all plastic—or, more accurately, elastomer—with no metal watch band pins.
            Assembled in China!
            Hidden inside the Sport Band slot, we spot a mysterious cover—a door of sorts.
            Taking a closer look at the side of the Apple Watch, we find the model number: A1553.
 Could you show us the strapping mechanism for the band? Is that model number text as misaligned with the port as it looks?
   crwdns2935267:0crwdne2935267:0Precision Utility Knife$4.99-
            Unfazed by the lack of external screws, we reattach the Sport Band for extra leverage and whip out an iOpener to negotiate our way into the belly of this beast.
            Forgoing our traditional opening tools, we give this display all the force our Tech Knife can muster.
            We move in with our opening pick to finish things off. Let's hope this doesn't get as messy as Apple's other flagship release.
 What was actually holding the screen itself down? And can you show further disassembly of the screen? and there goes any water resistance... How would one even make their watch water resistant when replacing the screen? I guess it wouldn't be... even if I was told, *use this* glue/tape and it will be, I wouldn't trust it..
            We gingerly lift up the display, expecting a snaggle of cables—namely, the display and digitizer cables.
            Disconnecting the display isn't easy, as the display cables are trapped under a springy bracket (not unlike the Touch ID cable cover of the iPhone 5s).
            Our teardown engineers are watching out for such tricks... but who watches the watchmen?
 How do you stick the display screen back? You’ll need either the Touch Force gasket or the die cut adhesive strips. Both are sold by IFIXIT. DanJ -
            Houston, we have separation. With the display panel removed, we quickly spy two highly-advertised Apple Watch features: the Taptic Engine and the Digital Crown.
            It looks like even the lowly Watch Sport gets a bit of glitzy gold. We expect that this is some kind of antenna, featuring Apple's familiar gold treatment.
 I think the question on everyone's mind is will that s1 chip be replaceable. Doesn't look easy to get to. Oh , unfortunately I could not find out where's Pressure sensor underneath the display. It's another key topics of differentiator on Apple watch
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            With this first photo, we take a moment to compare the internals of the Apple Watch with that of a classic mechanical watch as old as time itself.
            Which of these will outlast the other?
            Although we're still dealing with a watch, this second photo makes it clear that the tools required for routine repairs have very much changed with the times.
            You're already familiar with our friends on the left: opening pick, tweezer, driver, and tech knife.
            On the right, the tool with the Mickey Mouse ears is none other than a pallet fork tool. To its immediate right, we've got a pin vise. Below that, a roller jewel shlacking tool...
            ...and to its right, tweezers! Some things really don't change. (Though our resident watchmaker informs us that it's perhaps more accurately called "the lazy man's screw holder.")
 I thought you were pulling another April Fool's joke when I saw this photo. :) Interesting that you chose a tuning fork watch for a comparison device. Most of your readers might not be familiar with this fine timepiece. I would love to see a teardown on this one :). The tuning fork timepiece mechanism is from an Accutron. If you google Accutron Spaceview you can see it in pictures. I have one of these watches, they look great! Bulova Accutron sighting!!!
            A quick flick of a plastic opening tool is all it takes to dispatch the light adhesive securing the battery.
            This wee 3.8 V, 0.78 Wh lithium-ion battery is the power behind the 38 mm Apple Watch. No gears here! Apple claims the 205 mAh battery should provide up to 18 hours of use (which translates to 6.5 hours of audio playback, 3 hours of talk time, or 72 hours of Power Reserve mode.)
 Can we get the physical dimensions of the cell itself? It would be nice to know the weight as well. mbeatty - Any info on the battery connector used? i.e. part number? according to the photo: 3.80V, 0.78Whr, 205mAh, Model A1578, 1icp5/18/26
   crwdns2935267:0crwdne2935267:0File Set$10.99-
            As we work our way to the S1 SiP, we encounter the tiniest tri-point screws we've ever seen.
            No, we don't think Apple had repairability in mind when they designed her, Fixers.
            It's rare that we don't have the right tool for the job, but even our teensiest bit isn't up to snuff. We've never been thwarted before—so it's time for some modifications.
 the S1 disintegrates into conformal powder if you try to open the case... Is that a barcode beneath the "S1" designation? Definitely looks like one. I'd venture a guess that it's not much different than barcodes/data matrices found on other processors, likely acting as an identifier of some sort (plate no., serial no., lot no., etc.). I've seen triwing screws about that size before, in the old compact flash sized disk drives made by IBM (now Hitachi Global Storage). I want to do a teardown of mine, but I too will have to make my own tools to do so. The screws appear to be MicroStix 3ULR and referenced here www.j-osp.com/en/products/neji.html. The micro screws are patented by OSG Japan. As jrehwin mentions, they first showed up in Hitachi and Seagate 1" hard disk drives then later in MS Zune player and gaming systems. Licensed to Unisteel Singapore. Source for licensed bit manufacturer is unknown. Given the quantity of Apple watches to be produced and the volume of screws needed to meet that demand, the screws will have to be formed, not machined. To deliver torque, the slanted 3-lobe recess design works with minimal depth providing enough strength for adequate clamp load. The difficulty in making and forming the screws lies within the very thin head and depth of recess required. The blue material shown on one of the screw threads is a chemical patch. It works as an adhesive to prevent vibrational loosening in very short threads. Alternate screw recess designs are possible; 5-lobe like found on the iPhone, Torx Plus, Nacro, 00 or 000 Phillips, and MorTorq Super MTS-04 micro screw. Each design offers certain drive system strength capability but limited by head thickness and minimal thickness of the components being fastened together. Secondary function of the recess is to provide some level of tamper resistance as driver bits are not readily available. Here's the Tri-point Y000 Screwdriver driver: IF145-309-2 crwdns2937315:0IF145-309crwdne2937315:0
            Given the limited amount of space inside the Apple Watch, we find the microphone ribbon cable creatively ensnared between the inner and outer layers of the case.
 That’s the force touch sensor flex cable: https://www.ebay.co.uk/itm/292620286556 Yes the tweezer is grasping the force touch sensor. I think the writer was pointing out how the mic connector is inter-woven between the parts when you also look at the second image. DanJ -
            It's time to remove the Taptic Engine, which is attached at the hip to the speaker.
            It makes sense that the Taptic Engine is attached to the speaker. When combined with subtle audio cues from the specially engineered speaker driver, the Taptic Engine is designed to output a unique motion.
 Can you compare the Watch's Taptic Engine with the Macbook's? What are the dimensions of the Taptic Engine, the battery and the interior space? Perhaps we can figure out how much bigger a battery that the 42mm can have. WARNING - they just ruined the watch in this step. They ripped off the flex coming from the battery. you can see it in step 16 pic 1. this is non-replaceable. Apparently, ifixit didnt put this watch back together again. i figured this out using this guide to change the housing on my watch, which is now ruined. Correct, which is why there's a warning that this is not a repair guide right at the top of the page. When a device is dismantled for the very first time and the manufacturer doesn't publish the service manual, there's a lot of guesswork involved and things sometimes get damaged. Don't try to use a teardown as instructions! A little note in the section where things are damaged would be helpful Jeff.
            The speaker comes equipped with an O-ring for water resistance. Like everything else in this device, it's tiny.
            For the spec geeks out there, IPX7 means that the Apple Watch can withstand up to 30 minutes of full submersion in up to 1 meter of water.
            Apple doesn't recommend testing those limits, stating that you can "...wear and use Apple Watch during exercise, in the rain, and while washing your hands, but submerging Apple Watch is not recommended."
            We carefully remove the antenna assembly, which is discreetly tucked into the recesses of the case.
 I would daresay that discreetly is a more appropriate spelling
            What is this? A phone for ants? Just like a miniature version of an iPhone, we find a button cable with a mechanical button.
            The little button even comes with a little button cover and gasket.
            We quickly dispatch two very small tri-point screws holding a tiny panel to the watch case.
            Behind the tiny panel we find a set of contacts that align perfectly with the location of the hidden diagnostic port.
            Not wanting to make contact, we quickly dispatch this little connector.
            Still unable to remove the diagnostic port door, we resort to pushing it free through the little holes on the inside of the case.
 My guess is that the diagnostic port cover isn't meant to be removed. On the manufacturing line they probably have a test station that runs a series of functional tests on the device and once those are complete, they close up the port. It looks like a tight fit so the force of insertion locks it in place. Is the cover of the diagnostic port cover plastic or metal? How is it secured to the case? A small hole can be seen on the door. Isn't it screw-threaded? If so, it will be able to open by sinking a screw longer than the thickness of the door. Is any part of the diagnostics port magnetic (like magsafe)? Is there any way to tell if power, rather than just data, is able to transfer though the port? If so, it would definitely point towards future smart bands. Sure, a smart band could have it's own battery supply that doesn't connect with the watch, preventing it from leaching precious battery life, but then you'd have to charge two separate devices (band and watch) every day. If power could transfer through the diagnostics port, then not only could you have battery packs in smart bands to help power the watch itself, but also you'd only have to charge one device each night (the watch could then recharge the bands). This is cool suggestion!!!! You don't need to unscrew to remove the tiny panel. It just comes out using a sharp tool like an artists knife. Unscrewing is only necessary to remove the contacts ribbon. Yes, It’s coming of with little bit force, piked with thin sharp, but strong enough to not bend tool. It looks like little bit glue under, and looks like my be magnet to. I did not play with it much:)
            We remove the Digital Crown bracket, the final obstacle keeping us from the S1 SiP.
            Cue the epic rising of the monolith.
            We can feel the power as we slowly peel the future of humanityS1 out of the case.
            The back of the S1 isn't as pretty as the front—with ribbon cables running to every peripheral and gobs of adhesive gripping it in place, the chip leaves a nasty mess in its wake.
            Pulling this mess out is a destructive procedure, but after ripping out some soldered connectors we get our first real look at the S1.
            Despite rumors (and hopes) of an upgradable product, the difficulty of removing the S1 alone casts serious doubt on the idea of simply swapping out the internals.
            Unfortunately, our first look is obstructed—that S1-emblazoned silver cap isn't a cap at all. It's a solid block of plasticky resin, hiding treasures deep within.
            Update: Chipworks has identified this small IC as the STMicroelectronics C451 gyroscope + accelerometer.
 Yikes - I think you'll need Chipworks assistance getting inside that chunk. Probably have to boil it in Novec, followed by acid for several hours to reach the meat'n taters... The wireless charging antenna inside the base is certainly compact and cute. Looks like it's not a continuous wire loop, but a U-shape printed "coil". Is this Qi-based, or something proprietary like I'd expect? I've seen that the Moto 360 does in fact charge using the Apple Watch Charging Cable, leading me to believe that it could possibly be considered "Qi-based." What are the dimensions of the S1? What is its size as compared to other smartwatch circuit boards? Is there any way to repair the gyroscope? The only way is to replace the entire SIP module. DanJ -
            After removing the S1, we go back to the future, and the display panel, to find a lonesome chip:
            Analog Devices AD7166 ARM Cortex M3-based Touchscreen Controller
            With some careful tweezing, we pull up what appears to be an ambient light sensor.
 I'm looking forward to a firm confirmation whether this "flexible Retina" display is LCD or OLED technology. If the latter is confirmed as rumored, it's a great validation of OLED technology, namely Universal Display Corporation and all players in that supply chain. --EDIT-- I now see in step one "Pressure-sensitive, flexible, touchscreen AMOLED Retina display.". Cheers! Thanks ifixit!! Great validation of OLED technology? Not really. Just because it's a good fit for one purpose, doesnt make it the right solution for a different task, like a cellphone display for example. OLED and LED screens both have their individual advantages and disadvantages. Wait, how is there an ambient light sensor behind/in the screen?! ...or am I mistaken? I was wondering the same thing! I assume that's exactly what it is, since the watch will put the screen to sleep if you cover it with your hand, but I would also assume that the AMOLED display would interfere with the sensor. It appears to be some new Apple tech that allows for light to be sensed through the display, using a special type of solar cell. Pretty cool right? I'm missing the reveal of the touch force sensor. Maybe this isn't a ALS but some kind of low distance sensor that measures indirectly the force the user presses at the display. Well spotted. There indeed is no mention of the force pressure sensor, the black strip around the chassis rim under the glass. это просто датчик освещенности чтобы не делать отдельную дырку как на смартфонах . очень технологично экономия места и дизайн
            The Digital Crown seems to have an encoder system, like the Nest Thermostat, to read the spinning of the dial.
            The encoder branches off of the button cable, along with the single push button and the diagnostic port contacts.
 I guess it must be magnetic encoding Like in the sample image I also ruin this flex and I need replacement where can I order. Would you please give me source where can I order this part? https://d3nevzfk7ii3be.cloudfront.net/ig... Hi … I also ruin this flex during the dissembly … i didn’nt find it on any website … could you help me pleas ??
            Scraping the bottom of the barrelwatch case, we find the pulse-pounding sensor action. And lenses.
            Apple's heart rate monitor is actually a plethysmograph—it looks and acts like a pulse oximeter, but Apple isn’t claiming it can measure your blood oxygen level. Why? Beats us.
            Nestled in the case we also find a magnet, to help seat the watch on its inductive charger. Electrifying.
            We find a familiar looking coil of wire resting in the composite cover. We're guessing this is the inductive charging coil.
            Update: Chipworks has identified the Texas Instruments OPA2376 Precision, low noise, low quiescent current Op Amp as part of the sensor package.
 In order to measure Blood oxygen levels you need a Red and an IR LED. Can you confirm that the watch has this? Just because its a plethysmograph doesn't mean it can measure oxygen levels. It needs the different wavelengths to determine the ratio of oxygenated hemoglobin, and non oxygenated. All I have ever seen is green LEDs, which are not capable of doing this. What makes you think its capable of being a Oximeter. Hopefully they will enable O2 measurement in a future software update. The Apple Watch does have IR diodes in addition to the green ones. From <https://support.apple.com/en-us/HT204666>: ---------------- How Apple Watch measures your heart rate. The heart rate sensor in Apple Watch uses what is known as photoplethysmography. This technology, while difficult to pronounce, is based on a very simple fact: Blood is red because it reflects red light and absorbs green light. Apple Watch uses green LED lights paired with light‑sensitive photodiodes to detect the amount of blood flowing through your wrist at any given moment. ... The heart rate sensor can also use infrared light. This mode is what Apple Watch uses when it measures your heart rate every 10 minutes. However, if the infrared system isn’t providing an adequate reading, Apple Watch switches to the green LEDs. In addition, the heart rate sensor is designed to compensate for low signal levels by increasing both LED brightness and sampling rate. William - Ps: Green LEDs apparently can be used for reflective oximetry, when paired with infrared. I suspect accuracy is not yet sufficient, or measurements not reliable enough yet, so Apple did not include oximetry in the initial release—but one can hope for signal processing advancements to allow for it in the future. William - I really don't think you can do it with just infrared and green LEDs. Pulse oximeters use one of two combinations: red and IR, or red and green. The common denominator (and the key to the pulse oximeter, itself) is the red light. That's why we have the mnemonic "SeXy DARLing", which stands for "at SiX hundred nm wavelength DeoxyHb Absorbs Red Light". At green wavelengths, both oxygenated and deoxygenated hemoglobin absorb equally, and the same is true at 780nm IR. So, IR and green are the wavelengths you use to calibrate red. My best guess, Apple uses IR for the "any time" pulse because it's invisible, and green for the more accurate "on demand" pulse because it's relatively unobtrusive. Shine a green light into skin and it does not go far. Shine a white light, and you get a red halo. Red is the band that propagates through a human body. If they had red LEDs, the light would diffuse a cm or two, enough to light up the skin all around the watch, forming a "halo". koloshor - Is the gyroscope nestled in within the area at step 23? the Gyro should be one the FCB which ifixit has not tear down yet. So, a magnet on the watch. I was wondering why there isn't a compass. Was building a business around a magnetometer. Very disappointed! It's imposible to measure the relation between oxygenated hemoglobyn and reduced (not oxygenated) hemoglobyn (Hb) without the pair of ir and red lights, is necesary to have this two ligths and receptors for each one light to make a relation between both Hb (oxygenated and reduced) to get a porcentage like 95% of oxygen saturation ( 95% SpO2) wondering how the watch calculates the heading angle?Isn't compass mandatory for it.I am sure the watch has the pedometer abilities but what about heading or is it calculated with acc+gyro data + mag data from the GPRS/GSM ?
            Don't touch that dial! We're not done quite yet.
            Apple's inductive charger is a pretty big deal, and we're always itching to open their newest adapters.
            Officially known as the Apple Watch Magnetic Charging Cable, it features a 6.7 mm thick cradle with a diameter of 28 mm.
            After some heat, we try to pry, and end up ripping up the back case of the mag-safe-ish charger.
            To find it filled to the brim with glue!
 To find it filled to the brim with glue! AND SOME WINDINGS + A CORE Please take it further apart. Is there a kind of half ferrite potcore in it? Are those real windings inside or is it a coil made of PCB traces? I support the wish to take the loader further apart. (btw: Login via Yahoo does not work, states that iFixit uses a deprecated protocol) facebook - Can you please shoot one photo straight from the side of the charger. To show the position where the cable is connected to the charger. Is it in the middle? It would help us so much if you can also measure the diameter of the cable coming out of the charger disc. Thank you. This may be actually step 25 - the photo of the brass colored coil is kind of odd. It is punctured with about 30 random round holes. Can you see if you can determine what purpose those holes serve? If it's step 25, I think that's a PCB, not a coil. Those holes might be vias. The brass plate supports the plastic studs which the coil windings are secured to. The holes in the plate are filled with the studs. DanJ -
            We cut away the housing to get at the little glue cake (complete with magnetic center).
            After peeling away the weight, we find some markings, but that's about it.
 Please teardown the charging disc completely... there appear to be other goodies inside if you do a complete teardown... such as a flexible printed circuit board, copper wiring for inductive charging, and a magnet for attaching the Apple Watch to the charging disc, and other small metal parts around the perimeter of the disc for unknown purpose... Thanks! Yes, the charger needs a more complete teardown. People are reporting that other magnetic chargers, such as the Qi, do not work with the Apple Watch, yet the Apple charger reportedly can be used with at least one other inductively-charged watch. Something's got to be causing this, and some proprietary chip in the charger would explain it (or, it could just be a more powerful field). darryl - It looks like they potted the whole unit in this clear glue. Is it soft goo, like hot glue, or is it hard like epoxy? Does it soften with heat? I'd love to see the business-end of the charger electronics... Could be interresting to understand how the waveform genereted through the coil are produced (is there any electronic inside the cable? ) THere should be some. I second that call for further investigation of the charger. If you plug one into a Mac and investigate it, first with System Information and then with USB Prober (the latter being an optional download once you have XCode), you find it's got a lot of USB personality. It claims to implement the HID (Human Interface Device) profile with a transfer speed of 12Mb/sec, and provides more (uninterpretable) information when attached to a Watch than when it is not. So there's definitely smarts in there. To what end? Beats me.
            Apple Watch Repairability Score: 5 out of 10 (10 is easiest to repair)
            While not an industry standard, the watch band is easily removed and swapped out for a replacement.
            Removing the screen is difficult, but not impossible—it's the first component out, simplifying replacement.
            Once you're inside, the battery is quite easy to remove—only mild adhesive holds it in place.
            While not proprietary, incredibly tiny tri-point screws are a repair hinderance—especially when Torx or Phillips could have been used.
            Removing any other component is essentially impossible—all peripheral cables are soldered onto the back of the S1.
            The fully encased S1 system makes board-level repairs impossible.
            But wait, there's more! For a limited time only, view one teardown, and get a second one free. You heard us, 100% absolutely free!
            Meet the true Apple Watch: the Stainless Steel model.
            Curiously enough, the standard Apple Watch has an entirely different box than the Watch Sport. This may be to accommodate the various bands that can't be laid out flat like the Sport Band.
            Having perfected our pick procedure, we pop the hood on the Apple Watch Stainless Steel.
            No surprises here. The same clips and connectors greet us inside.
            It looks like not too much has changed. The mounting bracket for the Digital Crown looks significantly more substantial, and the bottom features gold tri-point screws.
            For a few mysteries revealed, check out our X-ray Teardown!
 Interesting that the bracket holding the digital crown on the steel model seems far more substantial than that of the Sport watch - it looks like a casting rather than sheet metal. I'm guessing that's to keep the weight/cost of the Sport model down, but interesting that the differences aren't just skin deep. The encoder barrel looks like a different design too. Is the battery bigger? EDIT: Forget that, I thought you were doing a 42mm compared to a 38mm. Silly me. Any word on the battery size of the 42mm? ditto - would like to know how much bigger it is sm - ayuda amigos compre un reloj en la web y me llego en modo demo alguien me podria ayudar a sacarlo de ese modo no tiene cuenta icloud estoy dispuesto hacer un aporte economico de ser nescesario al que me brinde la solucion gracias de antemano I have a apple watch sport series 3 and would like to put my apple watch watch stainless steel series 0 casing on it is that possible? and will it still be water resistant?
crwdns2947412:066crwdne2947412:0
Will you be tearing down the charging disc? Please say, YES!
What a nicely built piece of hardware, it looks extremely well designed - certainly compared to the duct taped together look of the Moto 360 (talking about the internals only).
This a beautiful tear-down.
Can you tear down the watch band for us! We wanna see whats inside it!
Yes, please show us
qiun -
How do you tear down solid plastic?
I'm missing the repairability score. Guess it must be almost zero for the complete watch, although just replacing the battery must be doable for a skilled repairsman.
Well the Moto 360 received a 3/10, citing the replaceable bands as a positive, but apparently the battery was quite a bit less manageable to remove. I'm betting this will receive a 3 or a 4.
Please tear down the box it came in. I think it has the numbers to the lotto
I don't think you completely tore down the charging disc… please try some more heating and prying to expose every little thing… I suspect there are some other goodies to be revealed … Thanks!
Is the Apple Watch that you teased us with the 38mm or the 42 mm? It looks like it has the same battery as the Apple Sport 38 mm . . .
Great Job - as Always - Thank You!
38mm, as it's stated in the back of the Watch
So much empty space below battery in Stainless Steel.
I expected even denser guts.
Do you know the RF Chipset used to talk to The IPhone ?
will it blend?
Anyone know who the manufacturer of the gyroscope is?
ST Micro is the manufacture for Gyroscope. Chipworks' discovery of Invensense is based on the prototype iwatch, not the one went to massive production.
You keep posting that STMicro won the gyroscope in the Applewatch. Do you have a link, or just an agenda>
The Chipworks conclusion that INVN won the gyro in Applewatch was released 2 weeks ago - but was not conclusive... although the component they speculated was an INVN gyro is shown in the actual teardown images. Other outlets speculated STMicro is in the watch.
I am pretty sure that no one knows for sure yet... if you do, then please offer something up. Otherwise stop stating speculation as fact.
John A -
ST Micro did both the accelerometer and the gyroscope. That's according to Chipworks teardown anyways...
@JohnA:It's Chipworks who concluded that it's an STMicro part. Please try and pay attention before accusing others of unwarranted speculation. It's not like we're being overrun with Apple Watch teardowns after all.
I wonder if you could get a job working for Apple - using this as your CV :)
Amazing teardown!! I've been waiting for today just to see what it looks like inside.
You have to hand it to iFixit and their quirky pop culture annotations lol I bet Step# 24.1 is a reference to the Beastie Boys lol
you mean they can't get those little watch batteries that last two decades on these things??? read our humourous review of Apple Watch here: http://entryrevel.com/2015/04/23/just-th...
I hope you will do one for the 42mm would like to find out what size battery is in that one with the extra space and that apple says it does seem to get longer battery life, we don't know how much longer with the extra screen to power but look at the iPhone 6 and 6 plus.
who made the gyroscope? is anything in watch made by INVN? thanks, nice job.
ST Micro made the gyroscope.
Can you do a tear down of the Watch Edition version?
OK... You know what CPU is inside of the S1?
I'll tell you...
Ready?
It's a single core version of the A5.... You heard it here first. How do I know?
Can't tell, but here's something to think about: Remember when a new version of the 3rd Gen Apple TV showed up, featuring a 28nm, reworked single core version of the A5?
And remember there was a lot of speculation, that it was a test run of sorts, and that Apple was planning to use the chip for something else? Since it didn't really make sense to go through all that trouble just to save a few watts in an Apple TV?
The Gyro is marked C451. How does anyone know that is STM?
The 6 axis Accel/Gyro in the Apple Watch is Labeled "C 451". How does this tie it to STM? STM uses their ST letter logo and doesn't have a part "C" anything. How is it that an analyst named Blair at Rosenblat announced STM as the Apple Watch design winner two weeks ago?
At some point the winner needs to brag. No one is taking credit yet...
I find it hard to believe there would be any upgrade path for this device. The case, screen and band are probably about $20 in material/assembly cost. While exquisitely designed, the case is $1.00 worth of metal. The full assembly and ASICs (and R&D and profit) is where the cost is.
-portable RF design engineer
Can you unbox the case for the Stainless Steel? I want to see if it is possible to make a case like the apple watch edition.
I'm interested to see the tear down of the leather band.. I'd love to find a way to use a 3rd party band without resorting to a kickstarted band adapter.
what do the connections between photodiode, the discrete texas instruments op-amp, and the S1 chip look like? Are there any other components in that signal chain?
A more powerfull battery replacement will be needed in the future.
Please please please tear open the link bracelet components. The spring mechanisms in both the butterfly enclosure and the individual removable links are works of engineering too.
Taptec engine is having recall issues. Seems they are down to only one supplier as of news this morning.
Can you remove the digital crown?
Guys, any idea whether everything can be removed from the casing without destroying parts?
I'm really confused as to how the electroplating companies are managing to plate the casing without frying the board if they leave it in there or whether they even remove it before applying raw voltage to it.
What language is the game created for this device written in?
Anyone could tell the name of the optical sensor for hearth monitoring or some sensor similar?
A Green LED and a photo sensor which is tuned to measure the reflection of the light is what’s used. The amount of reflection changes with your hearts pumping of the blood cells in your skin.
DanJ -
Could you please share some more sturcture details about the tapic engine?
The topic engine is nothing more than a weighted piston which is moved from one side to the other by a magnetic coil and returned by a spring, repeating the throw over and over again. The speed of the action sets off the vibration you feel.
DanJ -
Hello, can you tell me what is the difficulty to separate the LCD screen of the touch glass? Can only do we replace the glass easily? Or the glass is glued to the LCD screen? Thank you and good day
Hi. I need the same. Did you solve it? I find the spare parts: the external crystal and the glue (adhesive stick) but I have some doubts: How separate brocken cristal from usable lcd and how Stick the new crystal with lcd.
The screen is less than a millimeter thick! You are just not going to be able to peel it away without damaging it.
Which is why we replace the entire display assembly Apple Watch Screen Replacement
DanJ -
Can anyone tell me if buying a replacement screen from ebay (http://ebay.eu/1RvsqPT) and replacing it using this guide will destroy the waterproofing of the watch. If so, by how much, I'm not going swimming or anything but I wear it in the shower at the moment.
The scratch is very deep and noticeable so I'd really like to remove it :(
Waterproofing is more than the parts its the skills of the person doing the work.
Even still even Apple won’t warranty a fixed watch to be waterproof after a repair. There are too many variables to be assured it will be as tight as it was from the factory.
DanJ -
Awesome. Very Helpful!!
What is the voltage and amps on the wireless charging coil receiver and emitter? Is possible retrofit the receiver inside an iPhone?
Sorry just not possible!
DanJ -
please help?
how i replace the display cable from the s1 board?????
Sorry you can’t it’s part of the SIP package
DanJ -
What's the black seal for that runs on the inner of the watch once the screen is removed. As mine came off when pulling off the screen it has two long bits that go near battery connection. How difficult would it be to replace/refit
Besides the adhesive there is the touch sensor that runs around the rim of the case which you can damage when taking off the display assembly.
DanJ -
Where I can buy my new Iwatch 42mm battery ist generation in USA please ???????
mauroendara@me.com
regards
Review the iFixit guide here Apple Watch Battery Replacement on how and a link to the needed battery.
DanJ -
if i damaged the pop connectors trying to get the metal bracket off (nearly impossible) can i replace them? if my lcd was working despite shattered glass--how to separate the two?
Sounds like your watch lost the band button. Apple has been replacing them if they come off. But, you also need a new display assembly if the crystal is cracked. Review the iFixit guide Apple Watch Screen Replacement on how to do it and a link to the needed part.
DanJ -
It is possible to modify qi charger to work with apple watch?
Sorry no, You would need to redesign the SIP module from the ground up!
DanJ -
A thousand dollars question, will it be possible for an expert technician to take aluminum Apple Watch 7 internal components and implant them into my ceramic Apple Watch 5?
To many differences between the screen and the sensor plate.
DanJ -
I actually got a notification for this teardown on my watch! Almost like it's brother watch was crying out for help...
Sean Titmarsh - crwdns2934203:0crwdne2934203:0
Your brother's blood cries out to me from the ground
Kevin Taylor -
Man, some months from now we will all laugh at this but right now almost everyone who pre-ordered their Apple Watch is crying at the sight of this.
Carlos Perea - crwdns2934203:0crwdne2934203:0
The watch is OK, I guess, but the band is a winner!
lainelee - crwdns2934203:0crwdne2934203:0
Going through the breakdown steps of the Apple watch, it appears to be a nice piece of kit. One question I may ask, would it get any new firmware updates and how will be done?
Taki59 - crwdns2934203:0crwdne2934203:0
