Lay out your mouse and gather your tools.
Use metal spudger to lift sticker
The wireless version has two (2) more screws under the other two (2) small circular pads.
Using a phillips #0, unscrew the screws
Applying some force lift the mouse top up and backward at the same time to disconnect it
Once inside pull on the scroll wheel to remove it from the board
Pull on the cable and the board should come out
The wireless version has yet another small Philips head screw holding the main board to the base.
Then pull out the plastic at the bottom
In the wireless version there is also a slider under the main board that engages with the battery (AA size) isolation switch.
All done just follow guide in reverse to reassemble
The wireless version of this mouse has 2 extra screws under the other two small pads and arranged differently because of the battery compartment intrusion into available space. There was also a small screw retaining the circuit board.
Scroll not working
