Car dies randomly, It turns over but no spark
The car died while being driven. gas is in the car and it does turn over, but there is no spark form the spark plug
crwdns2933947:0crwdne2933947:0
crwdns2930901:0crwdne2930901:0crwdns2933953:020crwdne2933953:0
crwdns2916016:0crwdne2916016:0
crwdns2933933:025crwdne2933933:0
crwdns2931729:0crwdne2931729:0:
crwdns2933933:0688.3crwdns2936485:0crwdne2936485:0crwdne2933933:0
If your engine cranks normally but will not start because it has no spark, or it stalls and won't restart because it has no spark, the problem may be due to any of the following:
A bad pickup inside the distributor (on engines that have a distributor), a stripped distributor drive gear (common problem with plastic distributor drive gears), broken, loose or corroded wires from the pickup to the ignition module or PCM.
A bad crankshaft position (CKP) sensor (on engines that do not have a distributor), or broken, loose or corroded wires from the sensor to the PCM.
A bad ignition module (on engines that have a distributor or use an ignition module separate from the PCM)
A bad ignition coil (on engines that have a distributor and a single coil)
A bad rotor or distributor cap (cracks or carbon tracks that are allowing the spark to short to ground)
Faulty ignition switch
For solutions go here: http://www.aa1car.com/library/no_spark.h...
crwdns2933955:0crwdne2933955:0
crwdns2935735:0crwdne2935735:0
crwdns2935737:0crwdne2935737:0
crwdns2918042:0crwdne2918042:0
crwdns2935739:0crwdne2935739:0
crwdns2918044:0crwdne2918044:0
crwdns2935741:0crwdne2935741:0
crwdns2944259:01crwdnd2944259:01crwdne2944259:0
