iPod Nano 6th Generation Battery Replacement
crwdns2942287:0crwdne2942287:0This guide provides details on how to replace the battery in an iPod Nano 6th Generation.
The iPod Nano 6th Generation battery is not a plug-and-play battery. This process requires delicate desoldering to remove the old battery.
There are two options for replacing this battery:
crwdns2944105:0crwdne2944105:0
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
While the front panel is still warm, use the edge of an opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
I strongly recommend using a Small Suction Cup (IF145-019-1) instead of a plastic opening tool.
After half an hour of various heating times, trying to use a plastic opening tool, I overheated the LCD, which caused it to discolour. Now I need to buy a new screen. I wish I'd thought to use a suction cup earlier; it seems so obvious in retrospect.
I used a hot water bottle with towelling cover, resting on it for about 5 minutes. glue softened at 45 degrees. enough to easily lift panel.. Ipod’s working temperate is 55 deg C max according to apple. I used IR heat gun for temperature check.
We have a temperature controlled testing oven at work. I set the oven for 50 degrees C, let it absorb heat for half an hour, then took it out. I had zero luck with either the plastic pry tool or the suction cup, so I carefully pried up the indicated side with the sharp pointed tip of a dental pick until I could get the plastic tool into the crack opening.
Lift the front panel assembly from the headphone jack side of the Nano.
Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
Lay the front panel assembly next to the Nano.
Remove the following two screws:
One 2.3 mm Phillips screw
One 2.6 mm shouldered Phillips screw
Use an opening tool to pry the steel shield out of the Nano by its upper right corner.
Remove the steel shield from the Nano.
Why does the steel shielding look like a DS cart (this isn't a real question)
Use an opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
Remove the front panel assembly, minding its two cables that may get caught.
How come you did not put back the metal plate that goes between the iPod and the display?
You do put the steel shield back in to place and screw it down, but only after you connect the digitizer and display data cable connectors to their sockets on the logic board.
Does anyone have a current link to the screen adhesive tape product? The ebay link in the article is dead.
Use an opening tool to gently pry the battery up from the adhesive securing it to the outer case.
Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
The wires on your replacement battery can be spliced into the existing wires from the old battery. This process allows you to install your new battery without desoldering and removing the existing wires from the logic board.
Detailed instructions for this procedure can be found in this Fix It Planet video.
Use an opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
Remove the single 1.9 mm Phillips screw that secures the logic board to the outer case.
Use an opening tool to gently pry the logic board off the adhesive holding it against the outer case.
Use your opening tool to gently push the dock connector toward the center of the Nano.
Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
Follow the steps found in this PON2.0 video for desoldering and removing the old battery wires from the logic board.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:05crwdne2947412:0
This is probably a stupid question but is there a way to put on the battery without solder? i dont have any tools and there isnt really any repair shops next to my place or around
You could could splice the wires (cut the original battery wire in the middle exspose some bare wire and twist together with the replacement batteries wire) don't forget to not leave bare wire exposed heat shrink or wrap with electrical tape.
P tr -
Do you sell the adhesive to adhere the face back on?
To me this tutorial stops unfinished. The main thing i need hasnt been answered which is where is the spot i need to solder the new battery into? it hasnt been showed, at all. This is a bad tutorial.
You can see how to remove the logic board, the battery is soldered to that. Another picture from the downside of the board would be nice, so we could see where the black wire goes. But all the hard parts are shown, where that wire goes you will see when you have removed the board.
Do I need new adhesive to reassemble?
David Wallin - crwdns2934203:0crwdne2934203:0
Make sure to not break this cable even if your backlight is out, there can be internal corrosion that prevents the backlight from working. It may still work with the old display.
Matthew Borgholthaus - crwdns2934203:0crwdne2934203:0
