iPod Nano 4th Generation Battery Replacement
Walter Galan
crwdns2944107:0crwdnd2944107:0Walter Galancrwdnd2944107:0crwdnd2944107:0crwdnd2944107:013crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 12, 2022crwdne2944111:0
2 - 3 crwdns2931253:0crwdne2931253:0
crwdns2937595:0crwdne2937595:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
Replacing the battery requires a fine tip soldering iron and is a difficult job that only experienced solderers should attempt.
crwdns2944105:0crwdne2944105:0
  1. iPod Nano 4th Generation Battery Replacement, Glass Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 4th Generation Battery Replacement, Glass Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
    • Pry the top bezel off the adhesive securing it to the display retainer.
    • At this point the hold switch slider is free and may fall. Be careful not to lose it.
    Be sure to use the smaller iPod opening tool and press it in FIRMLY in order to get enough leverage to get under the bezel and pry it off. Adhesive is very strong, so don't be afraid to use a little bit of force.
    captcarl13 - crwdns2934203:0crwdne2934203:0
    Tool broke before I could get the cover off !!! So I’m done before I even started !!
    linda45p - crwdns2934203:0crwdne2934203:0
    I have a Apple iPod Nano 4th gen(Green) and I only have 7 tech pieces to the iPod and I may/might have the small philips screws and I am not sure how to fix the iPod nano
    Nick Davies - crwdns2934203:0crwdne2934203:0
    I also had Problems to remove the bezel. The solution was to start with a very small screw driver from the hole of the switch. There I could lift it a bit and get the plastic tool in between. Than it was easy.
    Michal Niewiadomski - crwdns2934203:0crwdne2934203:0
    After replacing the battery, the old glue would lump up too thick, and also become too weak to fix the panel back to the outer case. I have scraped all the old glue off using a small flat head screw driver, and affixed a double sided adhesive tape cut into small strips, which was successful in both aspects.
    diytradjazz - crwdns2934203:0crwdne2934203:0
    TIP: Use a plastic tool and pull it out through the hold switch. This may break the top bezel, but this was the only way to get it off.
    Caleb Murphy - crwdns2934203:0crwdne2934203:0
    **** BEFORE YOU GO ANY FURTHER **** I totally ruined my Ipod and broke 4 parts including the LCD screen, so learn from my mistakes. This tutorial was VERY poorly written. Just keep an eye for any of my comments for each step and you should be fine.
    happyoctopus - crwdns2934203:0crwdne2934203:0
  2. iPod Nano 4th Generation Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hold switch slider from the top of the Nano.
  3. iPod Nano 4th Generation Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two angled Phillips screws from the two corners of the display retainer.
    • These screw heads are extremely small and easily stripped.
    Be sure to use a good phillips #00 screwdriver here, or you run the risk of stripping the very small screws.
    iTronics Repair - crwdns2934203:0crwdne2934203:0
    The screws were covered with the adhesive. They were very difficult to remove.
    I RUINED the hold switch! I accidentally broke the cord. 0_o The directions were kind of unclear.
    bodieg - crwdns2934203:0crwdne2934203:0
    crwdns2936937:0bodiegcrwdne2936937:0
    Step 12 is misleading as it does not show to remove the screen from the metal frame.
    Sorry guys, but the explanations are really bad. Go onto youtube and watch it. This site misses heaps of steps. I just broke my iPod :(
    S Mile - crwdns2934203:0crwdne2934203:0
    Like others have noted, screws are covered in adhesive and difficult to remove. Take extreme care to not strip the heads. I'd suggest using a very small flathead to scrape some of the adhesive off before attempting to remove the screws.
    a 1mm slotted screwdriver will work in a pinch, but be carefull and make sure you get the angle just right
    andrew - crwdns2934203:0crwdne2934203:0
    The tools list doesn't say you need an iPod opener to, nor does the parts list day you'll need a new click wheel, though this is called ”...click wheel REPLACEMENT​”. I don't get the feeling these are very trustworthy instructions, ESPECIALLY after having read other comments. I'd say BEWARE, and look at a variety of resources to get a much more comprehensive picture.
    Skyfire - crwdns2934203:0crwdne2934203:0
    Actually, the screws are not aligned with the edges of the iPod, which means that you must not try to unscrew them vertically. If you do there is a good chance that you damage the head of the screws. Thus look carefully with a torch to see at what angle you have to unscrew them.
    Fabrice Sarelli - crwdns2934203:0crwdne2934203:0
    Actually, the screws are not aligned with the edges of the iPod. That means that if you try to unscrew them vertically, there is a good chance that you damage the head of the screws. Thus, look carefully with a torch to see exactly at what angle you need to unscrew them safelly.
    Everything was good up to this point. I could barely see the screws and ended up stripping them. Just gave up at this point and threw the
    Ipod on the ground and stomped on it.
    gonzalo gonzalez - crwdns2934203:0crwdne2934203:0
    I agree with several other contributors here, that a properly sized flat screwdriver *that is not worn* held at the correct angle is a better option than a phillips because the screw head is filled in with adhesive tape. BEWARE: The screws on the top and bottom outer edges are not parallel to the case. They are offset by 25 or 30 degrees, with the tips of the screws pointing out towards the outer edge of the case with respect to where the heads are. Use something to get magnification so you can really see how your screwdriver fits, and whether it’s engaged. An undamaged and properly sized standard screwdriver held in the appropriate orientation will readily remove the top and bottom side screws without stripping and with very little force. Feel for engagement — press the screwdriver in just enough to get past the adhesive. Not much torque or pressure is required — just a good fit. You must have the right tools to do this job successfully, and look under high magnification. Align your screwdriver!
    Barry L. Kramer - crwdns2934203:0crwdne2934203:0
    In accordance with another source, I have bought online and used a Phillips #0000 screw driver, which worked pretty well here. It costed me only $2 .
    Screws are inserted under an angle. Would suggest to use a jeweler’s magnifying glass to check the angle before sticking any screw driver in there.
    aramis - crwdns2934203:0crwdne2934203:0
    BEFORE REMOVING THE SCREWS spend all the time necessary to remove thoroughly the very sticky gunky glue from the screws, using a needle and gently scraping off absolutely every bit of glue on and around the screw. If you don't you will flatten the screws and this would make your ipod almost impossible to open. Once the glue is removed, and with a small enough screwdriver, it should NOT require force. Do NOT use use force!!! Or you will ruin the screws.
  4. iPod Nano 4th Generation Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an iPod opening tool between the outer case and the display retainer.
    • Use the tool to slide the display assembly out of the case slightly.
    • Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
    • Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
    I found I had to gently pry the retainer open with a craft knife (xacto knife?) as the plastic opener tool was too blunt or soft to get any purchase...
    aaaidan - crwdns2934203:0crwdne2934203:0
    My nano had a "swollen" battery which wedged the LCD between battery and front glass. As a result, this step didn't work, I couldn't pull out the TFT and botched case, TFT and TFT frame until it came out. Telltale sign was a display that looked like there is a water between glass and LCD. The other nanos I've opened didnt have this problem and came out effortlessly, so if yours is stuck, don't feel bad, there's not much you can do!
    oliver - crwdns2934203:0crwdne2934203:0
    What to do if the upper metal base (which is fixed to the circuit with 2 screws) came off when extracted?
    Which side can I anchor to force the display to exit?
    Francesco Taliercio - crwdns2934203:0crwdne2934203:0
    I had the BAD idea of following the Parts Plus Pods tutorial for this step and he's quite a brute and removes the aluminium part then pulls it out then pulls again like a brute on the fragile metal bracket which tends break while damaging the button AND breaking the cable (all of which I unfortunately did). So this step is very important. The metal bracket that hold the button (under the aluminium display retainer being pulled on the photo) has to stay attached to the metal bracket under it.
    "Do not rotate the display retainer about the top edge of the display" is a confusing statement. The axis of rotation mentioned is width axis, the only one you can rotate around. It's the rotation of the aluminium display retainer that happens when you pull exactly like on the picture. So keep pulling it EQUALLY on both sides (front/back of the device), the idea being to pull it like a drawer. Otherwise you risk breaking everything like I did.
    READ BEFORE DOING THIS STEP As soon you pull this up a bit, I recommend you do step 8 right away, which is ungluing the switch to free it and prevent either the hold switch or its cable from breaking in later steps. This is by far the biggest flaw of this guide. It is unfortunately not written for maximum damage minimisation. I broke the cable and the switch so please unglue the switch (as in step 8) so that when you pull the LCD screen you don't risk breaking the cable. If it breaks it's game over, so be careful!
  5. iPod Nano 4th Generation Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
    • Do not put unnecessary tension on the very thin display data cable.
    I have several problems in taking it out. I don't know if it is dued to the glue that the iPod has inside. Could you help me. Thanks
    Hector - crwdns2934203:0crwdne2934203:0
    instructions say 5" (inches) it really means 5mm
    pedalsandpicks - crwdns2934203:0crwdne2934203:0
    No it says .5" as in 0.5" = half an inch. But in your defence they should have written it more clearly, very easy to miss that dot, and yes pulling 5 inches would destroy the cable for sure!
    happyoctopus -
    crwdns2936937:0pedalsandpickscrwdne2936937:0
    If you're gonna repair the way you read it will get you nowhere: the text reads .(as point)5 inch. Which is about 12mm.
    Frank veenis - crwdns2934203:0crwdne2934203:0
    you didn't need to be snarky
    happyoctopus -
    The glass panel can be very difficult to get moving requiring a lot of downward force. I have found good old fashioned spit to be very useful here.Just lick both thumbs and rub on fingers until just sticky enough.
    This willl move the glass.
    Pete Green - crwdns2934203:0crwdne2934203:0
    READ BEFORE PULLING THE SCREEN This is step where you can easily break your second cable! (after the hold button cable from earlier steps.) DO NOT USE FORCE. Pull just enough like on the photo.
    In my case, the battery was swollen (visible on the screen when it's off, it looks like there's water between the screen and the glass cover). I suspect as well that the LCD was glued against casing. It was beyond hard to pull the screen out. I ended up breaking the LCD screen by prying inside it instead of in front of it with a cut out piece of that transparent hard plastic everything is sold in (makes a great makeshift prying tool otherwise to unglue the cables gently). I don't know if an LCD screen can be removed without breaking it if he battery is very swollen. A way to avoid that in future is keep replacing your battery early enough and definitely at the very first signs of swelling. It will allow you to pull the screen super easily and not break it every time.
  6. iPod Nano 4th Generation Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 4th Generation Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
    • Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
    I found the adhesive (or fit) quite strong. Pushing on the bottom part of the glass created a small gap at the top, which I could fit a craft knife (xacto blade) into. This made it easier to carefully lever the glass out for me.
    I slipped and broke the LCD. So !#^&@@ off. What an absolute bastard of a job!
    lf - crwdns2934203:0crwdne2934203:0
    What is the "rear edge" of the nano? Can this be a bit clearer please? Maybe a video of this step would be a good idea. Then again, since Apple owns this site, I guess that's not gonna happen, is it?
    I don't see "rear edge" anywhere in the instructions. I do see "lower edge" a few times and it looks pretty clear to me. I did this repair a couple years ago without much trouble.
    Rene Jeddore -
    You could do all these steps and really mess up your nano. Instead of disassembling the iPod, carefully remove the remnants of the old glass which I assumed you have cracked. With the new glass in hand CAREFULLY sand one edge of the glass evenly. I used my fine grinder on my dremel tool. After assuring a snug fit I removed the adhesive and installed the glass. Looks great and functional and I didn't ruin my iPod in the process. And when I said sand one edge I mean one of the edges that has a "lip" on it. The other lip you can slide right in and push gently down for a nice fit. Do not remove the adhesive until you are sure of a good fit. This is a quick fix for those who are too queezy to take apart their device.
    Jim - crwdns2934203:0crwdne2934203:0
    My battery had expanded and pushed out the glass enough for me to peel the glue out like a battery pull tab on a phone so it was pretty easy to remove, but the screen is giving me some trouble. The expanded battery is holding the screen to the frame making it more difficult to remove.
    Elijah - crwdns2934203:0crwdne2934203:0
    Absolut falsch beschrieben, die Anleitung ist
    Herbert - crwdns2934203:0crwdne2934203:0
    Lieber Herbert,
    schade, dass dir die Anleitung bisher nicht geholfen hat. Stand heute haben bereits 35 andere Nutzer ihr Gerät damit erfolgreich repariert, deshalb wäre es gut zu wissen, was genau bei dir nicht geklappt hat und wo es hakt?
    Unsere Anleitungen werden nach dem Wikipedia-Prinzip geschrieben, das heißt du kannst auch selbst jederzeit noch zusätzliche Punkte hinzufügen oder Änderungen vornehmen, die besser beschreiben, was hilft, damit für diejenigen, die nach dir diese Reparatur versuchen, eine noch umfassendere Dokumentation zur Verfügung steht.
    Sandra Hiller -
    To get this right, the important bit is to not just press it IN and also TOWARDS YOU, with a bit of downward pulling grip with your thumbs.
    食器を洗う用などのゴムの手袋を使うと簡単です。
    詫間俐仁(RIHITOお) - crwdns2934203:0crwdne2934203:0
  7. iPod Nano 4th Generation Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the glass panel out of the Nano.
    • Before reinstalling the glass panel, be sure to clean the face of the display and the inside of the panel as any dust or fingerprints will be annoyingly visible when the Nano is turned on.
  8. iPod Nano 4th Generation Battery Replacement, Display: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
    • The hold switch ribbon cable is extremely fragile and easily broken. Work gently.
    Be extremely careful while doing anything around the screen. The slightest bit of pressure in the wrong direction and you will be replacing the screen along with the battery. I speak from experience.
    Brian Campbell - crwdns2934203:0crwdne2934203:0
    I was extremely careful… and, I broke the display! ~ Gah! ~ $18 for a new one on Ebay (half the price if I wanna wait 3-4x as long to purchase from overseas, twice the price if I buy it from this site!) ~ What a bummer! ~ The goal was to fix this for a customer, and instead I created a longer wait & obviously have to pay for the screen I broke. LISTEN TO BRIAN! BE CAREFUL! THE SCREEN _WANTS_ YOU TO BREAK IT! DON’T FALL FOR IT!
    cybrosis catharsis -
    Does anyone know where I could get the power button flex cable replacement? I was too extremely careful but the screen has a very precise fit. I is fine when you push the screen into the case but !&&* of a work to pull it out.
    [deleted] - crwdns2934203:0crwdne2934203:0
    THIS SHOULD HAVE BEEN BETWEEN STEP 4 AND 5, no point ungluing the switch this late. The earlier you do this the better to avoid breaking the hold switch cable by puling the screen...like I did...and others here too apparently.
  9. iPod Nano 4th Generation Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the Kapton tape covering the display data cable socket.
  10. iPod Nano 4th Generation Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
    Continue to carefully hold the socket down while doing the next step. If the cable come off at the wrong angle it can pull the connector away from the board at the base of the screen.
    Make sure to ZOOM IN to get this right, this picture is not clear otherwise.
  11. iPod Nano 4th Generation Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
    • Be careful not to rip the display data cable.
    Some of the ribbon is inside the white housing with the lock on, it needs to slide out of the housing. I didn't notice this because everything is so small - be sure not to slide your pry tool right through it.
    Martin Mccaffrey - crwdns2934203:0crwdne2934203:0
    The display can actually be pulled out slightly further than it initially seems. When you gently pull it up, you'll experience some resistance, which I initially thought indicated it was as far as it could go. But an extra bit of (still very gentle) force can pull it up a few more millimetres, which means the opening tool can fit.
    Also, it seemed to me to actually be helpful to lever the cable out of its port before removing the ribbon from the adhesive on the plate, since this allowed better access to the adhesive with the opening tool.
    As commenter Brian Campbell wrote on the previous step, it is important to hold down the white cable socket while carefully working the cable loose from the adhesive. Even a small amount of upward force on the display data cable while it is still inside the socket could be enough to tear the socket off the board. Try not to pry up - use a thin, new (undamaged) opening tool to get under the ribbon cable and keep it parallel and as close to the metal plate as possible. It needs to be worked *under* the data cable, not to pry, as the cable just slides straight out the bottom of the white socket.
    Instead of that tool which is not fine enough, I strongly recommend using those plastic stiffeners used to keep the collars of shirts straight, OR cut out a pointy shape from the hard transparent molded plastic used in commercial packaging, that made a great GENTLE and efficient prying tool for these glued cables.
  12. iPod Nano 4th Generation Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the display out of the Nano, minding the hold switch cable that may get caught.
    • As you pull the display out of the case, be careful not to break the hold switch cable.
    WATCH THE HOLD SWITCH!! Be *sure* it is disconnected before pulling out the screen! (I've made that mistake too many times :P)
    disconnected from what?
    I never saw where it was connected to!
    Fred Rodolf -
    @fredrodolf Step 8: ungluing the hold switch, which really is best done much earlier between step 4 & 5, to minimize the risk of breaking it aka the mistake @itronicsrepair is talking about.
    happyoctopus -
    By "caught" do you mean glued to the case? Mine was, and I cant tell how I could possibly have removed the screen without it breaking. Luckily my Ipod was already broken, but now its even more broke because of this guide.
    swd311000 - crwdns2934203:0crwdne2934203:0
    Oops!!!…..I managed to break the little ribbon cable going to the hold switch…lots of very “colourful“ words aimed at myself are in my head now.
    Simon Kormendy - crwdns2934203:0crwdne2934203:0
    You're not alone, it's a very common mistake, I just did it too. This guide is poorly written. Step 8 should between Step 4 and Step 5 precisely to avoid this. Once the cable is broken, it's game over. There's no replacing it.
    happyoctopus -
  13. iPod Nano 4th Generation Battery Replacement, Logic Board Assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 4th Generation Battery Replacement, Logic Board Assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an iPod opening tool between the bottom bezel and the dock connector.
    • Separate the bottom bezel from the adhesive securing it to the Nano and set it aside.
    Follow this picture exactly, inserting the tool in the dock port to pry off the bottom plastic piece-- if you pry on the edges you may bend or break this plastic piece.
  14. iPod Nano 4th Generation Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three Phillips screws along the bottom of the Nano.
    • The slightly longer of the three screws belongs in the middle.
    In my case, the screw on the left was impossible to remove, it looked like it was unscrewing but was not ... I could not proceed any further.
    Any advice?
    Gauthier Scavée - crwdns2934203:0crwdne2934203:0
    If a screw is stripped, you need to somehow get another under the head to apply pressure to unscrew it (while unscrewing it). It’s an unpleasant operation where you have to apply pressure to keep the screwdriver pressed into the head while prying outward so the threads back out. Try not to strip the head, and try not to strip the threads, while helping the threads to catch.
    If this happens, you’ll need to replace the screw. It’s not a good idea to reinstall a stripped screw.
    우선 하판을 들어내면 나사에 접착제가 있을거에요 핀셋같은걸로 충분히 제거하고나서 나사를 푸시는게좋을듯
    jongjun307 - crwdns2934203:0crwdne2934203:0
    Translation (From Korean): "First of all, if you take the bottom plate off, there will be glue on the screws. You can remove it with tweezers or something and then unscrew the screws."
    I add: Yes, @jongjun307 is right. VERY IMPORTANT to use a needle and tweezers to thoroughly remove the glue first from the screws, otherwise your screwdriver won't fit and you will apply force by natural reflex and ruin the screws. The screws are supposed to unscrew off very easily, without force. VERY important as well to have a fine enough screwdriver, otherwise...again...you'll ruin the screws.
    happyoctopus -
  15. iPod Nano 4th Generation Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 4th Generation Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an iPod opening tool to pry the aluminum dock bezel out of the Nano.
    • The dock bezel is very thin cast aluminum. To avoid breaking it, do not excessively flex it during removal.
    I found using the opening tool to wedge up (toward the case) from between the metal bit (which is a plate) and the dock socket was the easiest way to do this.
  16. iPod Nano 4th Generation Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPod Nano 4th Generation Battery Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPod Nano 4th Generation Battery Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to separate the battery from the adhesive securing it to the outer case.
    • The lithium polymer battery used in the Nano is very flexible. Try not to deform it excessively while separating it from the outer case.
    • Use the flat end of a spudger to push the logic board assembly and battery slightly out of the bottom of the Nano. Stop once it pops out a little bit.
    PRECAUTION #1: How far to push the spudger in without breaking the electronics? Only about 3 cm in (or 1.5 inches for those from a country with a strange unit system), NO FURTHER, you will break the electronics further down. The glue is a 5mm strip going on the sides and at the top of the battery. There's not much of it so don't spudger like a brute or too deep.
    PRECAUTION #2: READ THE NEXT STEP, you must NOT slide the battery down more than 1 cm (or half an inch!) or you will break the click wheel ribbon and it's GAME OVER. The clickwheel is impossible to find as a readily available spare part so pay close attention. This guide is so poorly written and doesn't emphasize enough avoiding ruining your Ipod with cable breakage that are soooo easy to happen if you're applying common repairing sense to this device designed to break if not fixed extremely carefully.
  17. iPod Nano 4th Generation Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the edge of an iPod opening tool to peel the click wheel ribbon cable and its ZIF socket off the dock connector.
    No, don’t do step 17 without reading step 18 and 19 first! Step 17 is very misleading read on its own, you will break the connector. You need to read setps 17, 18 and 19 before starting step 17.
    John beGood - crwdns2934203:0crwdne2934203:0
    Pay heed to the word “peel”. Don’t pry. Work the tool slowly under the connector, keeping it as close to the board as possible. Don’t pry. The unit I repaired also had a small piece of Kapton tape, the corner of which can be lifted with tweezers.
    Looks like I may have broken the little ribbon cable for the click-wheel, so, I might have to call it quits and spend another Au$260.00 on a new iPod Nano.
    READ THIS BEFORE DOING THIS STEP
    1) You don't need a special tool for this, or any step reuquiring to unglue ribbon cables. Just cut some of that hard transparent molded plastic from some packaging (it's thinner) or take-away food box (thicker and less ideal). It's gentle and thin enough to go tricky places and you can make it pointy or shape is as you like. that works for you to gently get under those glued ribbons and pull them out from the glue.
    2) Makes more sense to do step 18 first, while the ribbon and socket+ribbon it goes into are still glued, then unglue them. So basically Step 18, then 17, then 19.
  18. iPod Nano 4th Generation Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 4th Generation Battery Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the edge of an iPod opening tool to flip the ZIF cable lock up toward the headphone jack.
    you might want to put a note for the delicacy of this cable on Step 16... because the cable can break as you slide the logic board assembly out :o(
    juliforsyth - crwdns2934203:0crwdne2934203:0
  19. iPod Nano 4th Generation Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to slide the click wheel ribbon cable out of its socket.
    • Before proceeding, be sure that both the click wheel ribbon cable socket and its cable are freed from the adhesive securing them to the dock connector and logic board.
    • Peel back the cable on both ends!
    You forgot to mention that the click wheel ribbon cable needs to be detached from the adhesive holding it to the main board. Now my ipod is really broken. Please review your instructions to include all the steps!
    Mike - crwdns2934203:0crwdne2934203:0
    crwdns2936937:0Mikecrwdne2936937:0
    You forgot to mention that the click wheel ribbon cable needs to be detached from the adhesive holding it to the main board. Now my iPod is really broken. Please review your instructions to include all the steps!
    Mine too, but the iPod was already toast :D, so now i have a stylish 8GB External SSD
    Chris Green - crwdns2934203:0crwdne2934203:0
    There has got to be a trick to it, or something I am missing when putting it back together. I can't get the click wheel ribbon to go back in properly. It keeps getting bunched up and sticking out the end. It is long enough to stick out so you can detach it from the other ribbon, so is it supposed to fold up inside when you push it in?
    reedc1 - crwdns2934203:0crwdne2934203:0
    Does anyone know of a source of mainboards for this Nano. Preferably in the European Community or China? Every other part seems to be available but this one.
    I've even found dud mainboards for sale on the U.S. Ebay site. What on earth would anyone do with a faulty Maiboard?
    TOOLS: I've ben reading a few commments regarding difficulty wth the screws. I was also told the Phillips screwdriver isn't a true Phillips but has an offset leg. Not having seen one I can't comment with any certainty.
    However,being an improvisor,I've been doing very well with a couple of watchmakers screwdrivers.The flat blades are about 1mm across and made of hard blued steel. The sharp corners dig into the screw and push any glue out of the way. A phillips won't push though glue. I used to buy these in a small plastic box - usuallly on street markets.
    Well... beware, this part is tricky ! the click-wheel ribbon stuck and get cut when pulling the battery+motherboard out. Too bad :(
    Anyway it was "last chance" for my 7-years old blue nano, battery wasn't providing more than 15 minutes autonomy.
    Too bad, it was my fist iPod and I liked it much than my new 7th gen'.
    Playoff - crwdns2934203:0crwdne2934203:0
    Your photos are showing the wrong cable being removed from the zip lock connector and freed, you are not showing that the cable coming from the click wheel is disconnected and freed. Your photo is showing that the cable from the logic board is disconnected and freed. This means that when the logic board is removed, the cable to the click wheel breaks. Your text and warnings are correct, but your photos are misleading. Very bad compared to the rest of the instructions in steps 1 - 16, which are excellent and better than anything else I found. A shame to spoil it with this step. It is not sufficient to warn in the text that “both ends of the cable need to be freed”, you have to add a photo showing the click wheel cable has been disconnected and freed (and what do you mean by both ends of the cable need to be freed - there are TWO cables, one to the logic board, one to the click wheel and you are showing the wrong cable to the logic board as being freed.
    Leider überlebte in meinem iPod der Verbinder für das Flachbandkabel des Klickrades das Öffnen und wieder Schließen nicht. Er kontaktierte nach Umklappen der Verriegelung nicht mehr ordnungsgemäß und hielt das Kabel auch nicht mehr wirklich fest. Das darf man aber einem über 15 Jahre alten Steckverbinder nicht wirklich anlasten. ;-)
    Günther Haslauer - crwdns2934203:0crwdne2934203:0
  20. iPod Nano 4th Generation Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the logic board assembly out of the outer case, minding the hold switch and click wheel cables that may get caught.
    • When reassembling, ensure the click wheel cable is toward the front of the Nano and not in the grooves on the side. If it is in the groove you will probably cut it while sliding the logic board into place.
    My click wheel cable got sliced reinserting the logic board, so make sure your click wheel cable is on the front (like the instructions say), and not on the side. It would help if there were explicit reassembly instructions and not just "do these in the reverse order", so that special reassembly notes stand out more.
    Randall Theobald - crwdns2934203:0crwdne2934203:0
    Instead of pulling it out, I found it easier to use the display hole to push on the top part of the battery straight down toward the bottom of the unit. This gives you far greater control of the battery/mainboard removal operation; you can push it out (down) in tiny increments and confirm no cables are caught as you do it. Pulling can cause a sudden, catastrophic release and if something is caught, it’s destroyed.
    Das Problem ist, das sich der alte Akku aufbläht wenn er kaputt geht bzw. sehr alt ist und das Gerät so gut wie nicht zu zerlegen ist. Bei mir ging das Display und das Kabel des HOLD Schiebers kaputt weil alles so dicht gepackt war. Empfehle den Ärger niemanden bzw. vor der Akku Bestellung zu überprüfen, ob sich der Ipod prinzipiell zerlegen lässt.
    G911CX - crwdns2934203:0crwdne2934203:0
    Ein einziger Mist diese Anleitung es wird nicht hingewiesen dass man den Ipod Weg werfen kann wenn der Akku aufgebläht ist was meistens der Fall ist.
    Bei einem aufgeblähten Akku muss man tatsächlich sehr vorsichtig sein. Ob das immer gleich heißen muss, dass man das Gerät wegwerfen muss, wage ich zu bezweifeln, ich würde zunächst einmal schauen, welche anderen Teile eventuell in Mitleidenschaft gezogen worden sind und ob die ebenfalls austauschbar sind. Falls du dich wirklich gezwungen siehst, das Gerät wegwerfen zu müssen, haben wir hier einige relevante Informationen zum Recycling von Elektroschrott zusammengestellt: How to Recycle End-of-Life Electronics.
    Sandra Hiller -
    Der Akku war auch bei meine iPod aufgebläht und somit ließ sich das Display nicht entfernen. Spannenderweise schrumpfte bei mir der Akku wieder beim Laden und in voll geladenen Zustand klappte das Zerlegen wie beschrieben.
    Günther Haslauer -
  21. iPod Nano 4th Generation Battery Replacement, Battery: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 4th Generation Battery Replacement, Battery: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the hold switch cable from along the edge of the battery and lay it aside. The hold switch cable is not attached to the battery.
    • The battery is held on to the logic board by a strong adhesive. Force may be required to remove the battery from the logic board.
    • Pry the battery off the adhesive securing it to the metal tray on the logic board.
    Achtung! Metallfassung NICHT von der Platine herunterschieben! Die Metallfassung ist beweglich und es kann das 2-polige Flachkabel welches genau gegeüber der 3 Akkukontakte ist durchreißen !!!
    Bild 21/ 2 und Bild 22 sehr gut erkennbar
    René Herwig - crwdns2934203:0crwdne2934203:0
  22. iPod Nano 4th Generation Battery Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 4th Generation Battery Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery on the fourth generation nano is attached via solder pads with small holes that go through the battery ribbon cable and attach to flat pads on the face of the logic board. In this step, you will heat each solder pad individually while using a metal spudger to pry it up from the logic board.
    • DO NOT bridge the connection between the solder pads both on the board and on the ribbon cable with your spudger. Shorts have the potential to ruin the logic board.
    • Beware of overheating the board and the cable. Only hold the tip of the iron against the pad long enough to let the solder melt. Excess heat buildup has the potential to ruin the logic board or melt the ribbon cable. Consider letting the board cool off between melting each solder pad.
    • Start working from one side of the battery ribbon cable. In our case, we started on the left. Heat the leftmost solder pad while gently prying up from under the ribbon cable to free it from the board.
    i would suggest instead of using a spudger to push up the battery solding points, instead hold onto the battery and use a slight amount of pressure to pull each point off as you heat them with the soldering gun.
    crwdns2936937:0iTronics Repaircrwdne2936937:0
    I did it this way and lifted the center trace off the board. Now the logic board will need to be replaced.
    Tom Buttner - crwdns2934203:0crwdne2934203:0
    THIS WAY COULD BE BETTER!
    In the course of soldering on the new battery, I bridged a couple of the tiny pads. In my attempt to fix, I delaminated the tiny pads from the new battery's lead. So I reattached the old battery's circuit and leads, and then soldered the new battery (cut from its board) to the old battery circuit.
    To do this, simply remove the tape from the end of the battery, unfold the leads, and unsolder the two pads that connect the battery to its board. Do the same with the new battery, and then solder the two leads from the new battery to the old board.
    I believe this is an easier way of fixing (assuming the battery is dead, and the circuit attached to the battery is fine, as mine was. My wife dropped the ipod in water).
    Bradley Borch - crwdns2934203:0crwdne2934203:0
    When desoldering, you should REALLY be using braid instead of just "pulling up". That makes it 100x easier.
    Drew Jensen - crwdns2934203:0crwdne2934203:0
    I used scissors to very quickly cut the ribbon cable off close to the battery so it’s not in the way. Work under a microscope if you have one — I taped the logic board down with black electrical tape so it stays centered in the field and is easier to work with. Note that there is adhesive on this cable (at the top in the above photo) which should be carefully pried loose before desoldering. I used tweezers to grip the ribbon cable, one terminal at a time while heating with the soldering tip. Without the battery hanging there, you have a good feel for how much pressure is being applied. It was very clear when it was melted loose (comes off with no resistance and no prying, which leaves the pads intact) because there’s no heavy battery hanging on in the way nor adhesive working against you. This also avoids the possibility of shorts electrically damaging the logic board.
    I forgot to add, my soldering station was set to 590 degrees Fahrenheit, for both desoldering and resoldering the new battery. I taped down the new battery cable with a very small triangle of tape prior to soldering — align it; tape it in place, put a little solder on your tip and just touch. It melts right through the hole, and bonds. Then remove the tape and solder the other two terminals (then I also remelted the first one). I would not want to do this job without a 1X-3X microscope! Always let the board cool completely between terminals as the guide suggests. There is a reason surface mount work is almost exclusively done by machines or with hot air and skilled technicians.
    Don’t apply any upward force to a SMT pad, ever! If it doesn’t release on 1st attempt, don’t continue heating. Let it cool and try again in 10 minutes. Most components and pads are rated for only 5 seconds of melt temp. (and very little force). Cut off the dead battery and detach adhesive so you can feel what you’re doing.
    well i was doing this step and flung soulder in my face. so yeah wonderfull.
    Ivan - crwdns2934203:0crwdne2934203:0
    MY METHOD:
    I used a friend at this point. I heated up one pad, and she would lift it up with tweezers so the cable wouldn’t reattach. Did it like this one by one in a row. No spudgers were used, I don’t think it’s necessary and it might even increase the risk of damaging the pad or shorting them.
    I initially thought that I’d use soldering braid to collect away the melted stuff, but there’s so little of it or my braid wasn’t the right size, I just couldn’t get it to do anything.
    I used the cheapest Hakko soldering station, which has a digital display for controlling the temperature precisely. Default tip. At first I didn’t get it to melt, but I increased the temperature carefully only until it did. I started with 300°C which has worked fine with leaded solder, but I had to increase it until 480°C to get this to melt. Let the soldering iron tip touch the pad slightly horizontally rather than vertically, so it gets more contact area. Use flux pen or similar when resoldering.
    Riku - crwdns2934203:0crwdne2934203:0
    !!!DO NOT PULL ON THE CONNECTOR BEFORE DESOLDERING!!!
    I have once ruined a device by doing this, it rips the pads clean off
    Dawid K - crwdns2934203:0crwdne2934203:0
  23. iPod Nano 4th Generation Battery Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPod Nano 4th Generation Battery Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat the previous step for each of the two remaining pads, working either right to left or left to right.
    • At this point, the battery should be free from the logic board.
    • Lift the old battery out of the nano and set it aside.
    Me too lifted the center pad off the board :( :( :(
    Can the center pad of the battery be wired to a point wich is connected to center pad?
    I mean, does anybody know where to wire center battery pad when logic board's center pad is lifted?
    perepe - crwdns2934203:0crwdne2934203:0
    Same here, if anyone ever found where to connect the center wire if the pad came loose, please let us know.
    Mathias Claeys - crwdns2934203:0crwdne2934203:0
    Was für eine drecks Anleitung
To reassemble your device, follow these instructions in reverse order, while being careful not to damage the iPod.
crwdns2935229:0178crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Walter Galan
704,722 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,203crwdne2935297:0
crwdns2947412:040crwdne2947412:0
There is one small point which is worth a mention here.After disconnnecting the screen by flicking up a little black bit on the ZIF Connector, I went on to open the next ZiF (The Click Switch)
Yes- bits of ZIF connector everywhere.I actually had to examine a new Click Switch circuit carefully to find that this one is different.
Yes - you flick the White bit. Do apple do this just to keep us on our toes?
I have taken the nano apart and started to use a solder iron to remove the old battery. I must have pulled on the battery before fully melting the solder and have pulled off two of the three tabs from the board.
Can this be fixed?
Centipede - crwdns2934203:0crwdne2934203:0
I think you might have to get a new board or figure out how to fix the pads with wire. I believe there are tutorials on that.
Ad123re -
I tried what Bradley suggested because it really seems easier than to solder the new battery to the iPod circuit board, which is really tiny. Still I couldn't do it. The battery pads are very fragile and I had an hard time folding the leads and the battery circuit board so that it looked the way it originally was. This was the part where I failed because afterwards I wasn't able to insert the battery plus the iPod circuit board inside its case again and ended it breaking it.
ruigsantos - crwdns2934203:0crwdne2934203:0
When I soldered my battery in I first touched the top and bottom of the pads on the new battery with flux and then added a little solder to the top and bottom of the pads. When I put the pads in place I only had to apply a quick touch and it soldered on perfectly.
Overall it was a real pain! :)
Rene Jeddore - crwdns2934203:0crwdne2934203:0
After 3 hours of hard work I did it !
It's the first time I try such a job, and I found it "quite easy" to change the battery with the guide. Just follow the pictures and you'll be done.
The hard work for me was the solder part - and a friend of mine gave me a hand as he was more used to do this.
You can do it, it worth a try :)
maxdelamure - crwdns2934203:0crwdne2934203:0
He forgot step one where it says "Go on Amazon and purchase a new Ipod."
haaren - crwdns2934203:0crwdne2934203:0
Was able to do it, but got lucky with the soldering working out before I burned it beyond repair. If you're going to do this I recommend getting the toolkit! Or at least having an exacto knife, very tiny phillips screwdriver, and tweezers and PATIENCE. Also be sure to have a very sharp tip soldering iron, and I used .032 soldering wire - but a bit smaller would work too. Also the most important thing is be able to see very small close up details, or use reading glasses or a microscope. Honestly if I had to do it again, I wouldn't - but I love the scroll wheel on the 4th gen over the touch screens and also wanted a challenge. Be prepared to fail, but do your best! Good luck.
baranowskijoe - crwdns2934203:0crwdne2934203:0
I have soldered for almost 20 years, for occasional hobby stuff. I'm nowhere near an expert (some people are amazing!), but I am quite experienced. I have a good power soldering iron with interchangeable tips. I've also repaired countless phones, ipods, computers, etc. But this stupid thing kicked my butt. I hate dealing with such tiny components, and I hate dealing with Apple's fear of exposed fasteners.
Just buy a new one at this point.
Jon Miller - crwdns2934203:0crwdne2934203:0
Great instructions. Very easy job to complete if you work carefully and follow each step. Pictures were a big help. If you are not experienced with a soldering iron, I recommend getting help with this part. It is very easy to overheat these tiny components and make a mess of the whole job. Comments above seem to reinforce this point.
chuckjohnson89 - crwdns2934203:0crwdne2934203:0
Hello Chuck. I have a blue iPod Nano 4th Generation in perfect condition that needs a battery swap. I don’t have time to set aside to swap it yet don’t want to see it in a landfill. If you shoot me your address I’d be happy to send you this unit for you to keep if you don’t mind doing another battery swap. Kind Regards.
Dan Lee -
Is there anywhere Uk I can send this to be done by someone more expert ? I don;t want to tackle it myself. My son picked it up in a charity shop and it worked for a bit, but then died, defiantly the battery problem.
derekndonna - crwdns2934203:0crwdne2934203:0
Everything went perfectly, but when I inserted the display cable there was a beep, and after finishing the assembly it never came to life. I’m not sure what went wrong. I was very careful not to bridge the solder pads, and to keep the board as cool as possible. I thought maybe it was a display issue, but it doesn’t appear when I plug it in to a computer either. Sigh.
Brad Richards - crwdns2934203:0crwdne2934203:0
My battery must’ve been in water because there is corrosion under the battery, so it doesn’t hold a charge anymore, also the clickwheel died while i was removing it, im suspecting this water had a lot to deliver, yet it still worked whilst plugged in
Joshua Turnbull - crwdns2934203:0crwdne2934203:0
From my experience - this is a very hard fix to execute. The guide is good, but you’ll need a good amount of patience and skill to pull it off. Thanks iFixIt!
Jed Leslie - crwdns2934203:0crwdne2934203:0
If your battery is puffed up, don't bother and just bin it. I've spent 4 hours now trying to get it out and I've just snapped the metal piece on the top and the screen assembly refuses to get out.
Pierce Menze - crwdns2934203:0crwdne2934203:0
I’m having the same issue now. I feel ya.
Era -
Really wish there was a guide for a swollen battery, the number one battery issue with this model. Can not get the inner case out whatsoever.
Era - crwdns2934203:0crwdne2934203:0
First of all. I really respect the guys who finished alone. I've got a few questions.
1. It could be a stupid question. should i really need soldering iron?
2. I don't know if it's worth buying a new one because of this ten-year-old thing that doesn't have one at home.
3. Is there an explanation not in the text? Please let me know if there's anything else I need to be careful about.
1. Yes.
2. That’s entirely up to you. I’ve found that a cheap supermarket iron can do more damage than good because you don’t know how hot it is and the quality is bad. I rarely solder, but I’ve been happy with Hakko FX-888D. You need to practice soldering on something else first, you need to learn the basic soldering techniques (no, you don’t melt the solder as if it were candle wax!), and you will need to learn how to take care of and store the soldering iron correctly when it’s not in use. Leaded solder is far easier to work with than lead-free solder. Besides the tool itself, you’d ideally have flux in some form, some means of removing solder, and the appropriate stuff for cleaning and refreshing the tip. Any neglect will lead to frustration and the solder just not behaving as you’d expect. I also found an ammonium chloride block to help a lot when solder doesn’t stick to the tip.
3. We’re all in the same boat. Read all the comments for the extra remarks that people following this guide have made.
Riku -
Superb instructions, thank you, but a fail for me due to the swollen old battery. It crushed everything so tightly into the casing that it was impossible to remove the display or motherboard without damage. They may as well have been set in there with araldite. Try it, but hold off ordering a new battery until after it’s stripped, is my advice.
stevep02 - crwdns2934203:0crwdne2934203:0
Okay, so I broke the ribbon wires going to the hold switch and the click-wheel….my own fault…., I’m going to have to call it quits on replacing the battery in my 2009 iPod Nano 4th Gen, and just buy a brand new one….Thanks Apple for making a really difficult to repair device.
I think you can get at least a replacement assembly for both. If yuo are willing to spend that money, maybe you are better going to buy an android phone and use it as player.
Daniele Carminati -
My hold switch cable snapped too, it’s so %#*@ tiny. I don’t know if it matters that I left the hold switch to off position before I started, but now that it’s snapped, after the battery change the iPod has come alive and the buttons work despite of the snapped hold switch. Now it just can’t be locked, but that’s okay.
With the click wheel, I’m afraid you’ll have to hunt down a new one. That part might just be available somewhere.
Riku -
Thanks for the excellent guide, I couldn’t have done it without you! This was definitely the most difficult repair I have attempted so far, mainly because everything is so small and tightly fitted into the case. The most time consuming part was actually fitting the logic board back into the case; the click wheel cable kept getting dragged into the case as I moved the logic board in. I had to keep bringing it out again to ensure it wasn’t going to get broken, and it did NOT slide in smoothly! You need a LOT of patience! But I got there in the end and now have a fully working 4th gen again! Rene’s tip above about using flux on the solder pads really does make the soldering part very easy if you are carful about it, so thanks for that. I would agree with the difficulty rating, this is not easy and certainly not for a novice repairer, but if you have the patience and go gently it can be done.
Nigel Henry - crwdns2934203:0crwdne2934203:0
Hallo Fellows,
I tired to manage the tutorial, unfortuneatly i ripped of my power connector cable. I thinking about to shorten it and remove the function of button. Is there an option that the ipod powers down if no music is played, in a way that the button is not required to use? Could anybody have a try what it is doing? best regards and thank you
Zaremia Draigtmoore - crwdns2934203:0crwdne2934203:0
Hello,
I need a battery for Ipod Nano 4Gen!
Does any one know here can i buy a replacement battery for it ?
I am in advance very grateful for the attention and information that someone can provide me!
Kind Regards,
gogomes
Pedro Gomes - crwdns2934203:0crwdne2934203:0
Excellent but a bit unfinished guide. I'll tell my experience in this comment and put questions in another due to the char limit.
The story so far:
The battery wasn’t fully swollen but occasionally I had noticed a small black area appear to the screen, meaning that it’s now or never if I want to save it. Before starting, I had set the key lock button to off position just in case. It took me literally days to get the contents out from the iPod, but I kept trying. The most frustrating thing ever. In the middle of this I taped the lock ribbon onto something in order to keep it out of the way, but forgot to free it up, and it snapped. I have now successfully soldered a new battery onto it (got it from a shop that specializes in batteries, try searching with P11G73-01-S01; Do use a flux pen!) Without putting the cover back on, I connected the clickwheel and display cables, and put the iPod on charger. Turns out that it comes to life normally, and the clickwheel works! No more key lock but I can live with that.
Comment 2/2, the issues:
Now that the battery has been soldered, the problem is putting it back together. With most iFixit guides, you can just retrace your steps in the reverse order. But this is more complicated than that. It’s hard to remember how exactly you removed tapes and adhesives, and from where. The battery with its soldered on ribbon cable laid out is a bit too long to fit into the case, so I think something must’ve been folded up, but how? Something in the battery “root” was taped and folded up really tight, but I can’t imagine how it was. Youtube videos don’t help either, because some have batteries that connect to a different place with two places to solder, while others only show a teardown without reassembly. If we need to use adhesives, where should they be applied, and what kind of adhesive would be appropriate so it doesn’t damage the battery bag surface? And optional: what adhesive would be ideal at the top+btm, should we want to retain the ability to change batteries in the future too?
Addition: I felt that I needed a pair of extra hands for desoldering the battery, and attaching the new one. I wouldn’t have had enough hands on my own to carefully peel the ribbon cable away while melting the solder, and to keep it in the right angle when soldering the new one. The actual circuit board was gently held stationery by a small and cheap jewelry vise, the kind that’s designed to hold things such as small round rocks, and the touching parts are covered in plastic instead of raw metal touching the object.
Before soldering the new one, I applied flux pen on both sides of the ribbon connector because I was skeptical of whether the solder would genuinely just fall through the hole and between the ribbon and the circuit board itself. This seemed to work. I used leaded solder because lead-free solder has a higher melting point so unless you’re very experienced, it has a higher tendency to make cold joints that look good but aren’t actually good inside. Too much heat for too long can also damage parts.
3.5 Hours - and it works. Many thanks to the author. Without these instructions it is impossible. While reassembling, the clicwheel cable didn't slip in well, then I removed the logic board again, but the battery already was sticked to the case an tore out the metal frame of the logic board and killed the cable to the speaker connector. But I can live without it.
It was a real challenge, but also fun to be able to repair a device that was not designed to be repairable.
Matthias - crwdns2934203:0crwdne2934203:0
Welp I was successful in changing the battery on mine but I tore my hold switch's ribbon and in the process I also believe I fried the logic board. It was working before reassembly! Sadly not after...
Dimondminer11 - crwdns2934203:0crwdne2934203:0
TIP IF YOU CAN'T PULL THE CONTENTS OUT!
It's incredibly hard to work on an iPod whose battery has already started swelling and pushing against the screen. Step 5 of pulling the internals out may feel simply impossible. When the package is too tight, you have to grab the "bridge" that holds the lock switch, but when it's just too tight, the bridge snaps from one end. While that doesn't break the iPod, it leaves you with nothing to pull from!
I realized that the core problem with this stage is that in order to free up the internals, you have to squeeze the housing from the sides very hard in order to make it deform and loosen its grip ever so slightly. But as you use so much force to bend a small piece of aluminium, it's going to be very hard to simultaneously get a hold of the internals and pull them out. I placed the iPod into a small metal-bodied jewelry vise to give it just enough squeeze from the sides, and that allowed me to very easily pull out the internals! No damage on the housing.
Absolutely insane repair, but i managed it somewhat in the end. Ripped cable of the battery twice. Ripped the cable to switch and buzzer. Removed the Buzzer/Switch cable altogether and used fine isolated wire to run from battery to PCB.
Looks frankenstein at the end, but plays again.
I found re-inserting the pcb with battery impossible. With the two wires (no more battery protection board, who needs that ?), it is much easier to re-insert the battery and PCB into the case.
Definitely my last Apple product ;-)
Thomas Widmaier - crwdns2934203:0crwdne2934203:0
Instructions are perfect but must be read with care. Disassembly and assembly worked straight forward. Soldering isn't really an issue, too. You do not need a super fine soldering iron as common for SMD parts. A normal one is sufficient.
However my repair finally failed due to cable connector failure for click wheel. Think it was a aging issue and not related to repair process.
This isn't a comment but more of a question . . . If the display data cable socket is split is the display done for, and if so, is it repairable ?
Robert Tidwell - crwdns2934203:0crwdne2934203:0
Ruined my Ipod in large part (but not only) because of how poorly this guide is written. 4 parts broken that don't have spare parts...mostly broken ribbons. Please re-write this guide by factoring in all the advice and correction in the commons. This guide is so very far from emphasizing enough paranoid levels of extra care, details and warnings on the key steps where you can irreversibly break the ipod in ways that are unfixable.
You should reduce your risk of breaking anything by diligently following my comments. Though I have stopped at step 20 so you're on your own after that.
crwdns2936751:024crwdne2936751:0 111
crwdns2936753:07crwdne2936753:0 858
crwdns2936753:030crwdne2936753:0 3,790
crwdns2942667:0crwdne2942667:0 545,777
