crwdns2936621:0crwdne2936621:0
crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0iPhone 7 Pluscrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. iPhone 7 Plus 분해도, iPhone 7 Plus 분해도: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • "가장 우수한 최첨단 iPhone"에 숨겨진 많은 부품이 있지만—우리가 이미 알고 있는 부품은 다음과 같습니다:
    • M10 모션 코프로세서 내장 Apple A10 Fusion 프로세서
    • 32, 128 또는 256GB 온보드 저장 용량 (제트 블랙 모델에는 32GB가 없습니다)
    • 1920 × 1080 픽셀 (401ppi) 5.5-인치 멀티터치 IPS Retina HD 디스플레이
    • f/1.8 및 f/2.8조리개, (각각) 2x 광학 줌 및 10x 디지털 줌 이중 12MP 광각 및 망원 카메라
    • ƒ/2.2 조리개 및 1080p HD 녹화 기능 7MP FaceTime HD 카메라
    • 새로운 Taptic Engine으로 작동하는 솔리드스테이트 Touch ID 홈 버튼
    • 802.11a/b/g/n/ac Wi‑Fi + MIMO Bluetooth 4.2 + NFC
    Which carrier phone is this
    deepu272 - crwdns2934203:0crwdne2934203:0
    The iPhone 7 plus is much deferent than iPhone 6 and iPhone 6S. The lack of antenna lines especial at the jet black version, the lack of earphone jack, the dual lenses and dual speaker make it distinguishable. I personally like it very much and I will soon buy the iPhone 7 plus jet black 256GByte model. The only thing I dislike is that I won't be able to store my iOS apps on my hard disk as I am doing with my old jailbroken iphone 6 plus. So the 256 Gbytes are more than necessary.
    Agnostos Gnostos - crwdns2934203:0crwdne2934203:0
    @Agnostos Gnostos
    "The only thing I dislike is that I won't be able to store my iOS apps on my hard disk..."
    You can do that using iTunes without jailbreaking. You always could.
    alex - crwdns2934203:0crwdne2934203:0
    I want to make my iphone at home , but from where i should get the parts ???
    can you help me?
    please
    reply me
    Nakul Phulwade - crwdns2934203:0crwdne2934203:0
  2. iPhone 7 Plus 분해도: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • iPhone 7 Plus의 치수는 158.2mm × 77.9mm × 7.3mm로 이전 모델과 동일하지만—무게는 6.63oz로 약간 더 가볍습니다 (vs. 6s Plus의 6.77oz). Apple이 중요한 기능을 제거하지 않았기를 바랍니다.
    • 7 Plus에는 새로운 모델 번호가 찍혀 있습니다: A1785.
    • 어두운 색상을 선호하는 사람들을 위해 Apple은 실버, 골드 및 골드 로즈 색상 외에도 매트 블랙 및 스크래치가 나는 제트 블랙 버전 iPhone 7 Plus를 제공합니다.
    • 또한 7 Plus는 보기 흉한 이전의 안테나 선을 일부 제거하여 보다 미묘한 모습을 제공합니다.
    • 아마도 가장 눈에 띄는 차이점은 상자에 포함된 [http://Lightning-3.5mm 헤드폰 잭 어댑터|http://www.apple.com/shop/product/MMX62A...] 입니다. 헤드폰 잭을 떠나려면 큰 용기가 필요합니다. 미안해요 베이비 어댑터. 너 때문이 아니고, 우리 때문입니다.
    Quote: "6.63 oz (vs. the 6s Plus at 6.77 mm)"
    I know you meant, "6.77 _oz_"!
    biowizard - crwdns2934203:0crwdne2934203:0
    have you done a baby teardown on the baby adapter ? Does it have a DAC in it ? If so which one?
    Jasraj Vaidya - crwdns2934203:0crwdne2934203:0
    The DAC is in the iPhone. How it's for the speakers too.
    George A. -
    No, it's not me, it's "baby adapter" Dongles were a thing of the past, and hated them as much as they will be hated now.
    scottwilkins - crwdns2934203:0crwdne2934203:0
    The dimensions of the iPhone 7 Plus are identical to those of its predecessor, at 158.2 mm × 77.9 mm × 7.3 mm—and yet it's slightly lighter, at 6.63 oz (vs. the 6s Plus at 6.77 oz). Hopefully Apple didn't remove anything important.... They removed the headphone jack and assembly.
    Emma - crwdns2934203:0crwdne2934203:0
    I have no courage. I also have no Apple Music because I have no reason to trust Apple with my content.
    Dave - crwdns2934203:0crwdne2934203:0
    oz... what is oz... You are measuring in mm, so do in Gram, too... 99% of the world does it metric...
    Skimmy - crwdns2934203:0crwdne2934203:0
    Yes. you're right!
    Ricardo Rodríguez -
    How about 3.5mm powered accessories like the square? Is square going to ante up for the lightning interface?
    refd123 - crwdns2934203:0crwdne2934203:0
    I don't believe that the jet black color is so prone to scratches. I generally baby my phone and protect them with cases and glass membranes. So it's not a real issue. The lack of earphone jack isn't a problem. I bet that every manufacturer very soon will produce earphones with lighting jack. Those with very expensive conventional earphones will find the earphone adapter annoying but that isn't a big issue. After all when you are buying a phone at 800 dollars you can spent 100 dollars for decent earphones. Apple as always is removing parts from its iPhones. People forget that the earphone jack of the first generation iphone was small and deep inside. It didn't allow many earphones.
    Do the new antenna lines in the 7 plus iPhone improve the signal reception in poor transmission areas
    gaylestan - crwdns2934203:0crwdne2934203:0
    @dave.
    "I have no courage. I also have no Apple Music because I have no reason to trust Apple with my content."
    Apple music is a subscription streaming service. You don't own the content. So you don't need to trust them.
    I keep my own content on iTunes match. I do trust them. But it's all safe on my Mac, and backed up too.
    @refd123
    'How about 3.5mm powered accessories like the square? Is square going to ante up for the lightning interface?"
    The square works off the headphone jack. If they use it to spec, then it should work off the adapter.
    Don't know about A1785,
    but on Apple's iPHone specs page they specifiy two 7+ model #'s as A1661 & A1784.
    One of them supports CDMA, the other does not.
    macnosy - crwdns2934203:0crwdne2934203:0
  3. iPhone 7 Plus 분해도: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 이 세눈박이 괴물을 파헤치기 전에, 우리는 Creative Electron 친구들 덕분에 내부를 마음껏 미리 들여다 보았습니다.
    • X-ray X-perts/X-레이 전문가가 새 iPhone 내부 보기를 계속 제공합니다. 지켜보세요!
    • 강력한 X-레이 비전이 허락하는 이점은 무엇일까요?
    • 우선, Taptic Engine/탭틱 엔진 공간을 확보하려고 헤드폰 잭을 몰아낸 것을 알 수 있습니다.
    • 좀 더 자세히 살펴보니 새로운, 아래쪽의 두 번째 스피커 그릴이... 어디로 이어지지? 흥미롭군요.
    • iPhone 7 Plus 카메라 배열에서 새로운 세 번째 눈이 보입니다. 어떤 지혜와 비전을 가지고 있을까요? 알아 봅시다!
    Please x-ray the Lightning to 3.5mm jack adapter so we can see if there's a DAC and AMP built into the cable. Otherwise you're going to have to cut it open, and that won't be pretty.
    iPostIt - crwdns2934203:0crwdne2934203:0
    I second this!
    Dan Parsons -
    I wonder if you could use the Lightning to mini jack adapter on one of the older iPhones as a way around having to replace the mini jack when it goes within the phone.
    Dan - crwdns2934203:0crwdne2934203:0
    The adapter's store page lists it as compatible with every iOS device with a lightning port. Looks like that should work.
    Chaz Larson - crwdns2934203:0crwdne2934203:0
    The adapter will work with all devices running iOS 10+
    You can also use the lightning headphones with any iOS 10+ device as well.
    As iOS 10+ only supports the lightning connector they will work with and are backwards compatible with any capable of running it.
    paul - crwdns2934203:0crwdne2934203:0
    The X-Ray photos that iFixit publicly show are fantastic. I don't think that Apple will be happy with such deep intervention into its hardware. However I am sure that all major phone manufactures are using similar technics of inspection.
    Well it looks like the Mini to Lightning adapter has its own DAC! Here's a teardown: iPhone 7 headphone dongle boasts amazing insides
  4. iPhone 7 Plus 분해도: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iSclack
    $24.99
    • Apple은 헤드폰 잭은 없앴지만 Pentalobe/펜타로브/별나사는 여전히 유지합니다. 익숙한 나사 두 개가 Lightning 커넥터의 양 측면에 있습니다.
    • 로즈 골드 외면을 뒤로하고 내부를 보려고, 우리는 iSclack의 강한 힘을 사용하며 제법 많이 비집고 들어올려 강력한 접착제를 헤쳐봅니다.
    • 7 Plus를 씰링하는 접착 스트립은 이전 버전의 스트립보다 훨씬 강력합니다. 이것이 방수의 첫 징후일까요?
    Does it make sense noting the best location to set the iSclack onto the iPhone so not to rip the cable connection shown in Step5 below? Or the best pattern to lift the cover off.
    Apple could easily have avoid screws on iPhone like it does with iPads and iPod touch. This is an indications that Apple wants their phone to be serviceable by experienced foreigners. But not easily ben opened by ordinary users. The adhesive strip is a good idea. I wouldn't like an iPhone with a wobbling battery inside.
    It's not waterproof, it's water-resistant. Similar, but not the same.
    Aristarco Palacios - crwdns2934203:0crwdne2934203:0
    Can anyone confirm are the pentalobe screws identical (diameter and shaft length) to those of the 6 plus's?
    Cooper Chase - crwdns2934203:0crwdne2934203:0
    How are the pentalobe screws protected from water? Is there rubber gusket?
    Apple - crwdns2934203:0crwdne2934203:0
  5. iPhone 7 Plus 분해도: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 이건 무슨 상황? 7 Plus는 이전 모델 처럼 디스플레이를 제자리에 맞추는 휴대폰 상단의 익숙한 클립이 있음에도 불구하고 기묘하게 옆으로 열립니다.
    • 우리는 운이 좋게 중앙-오른편을 따라 위치한 디스플레이 케이블을 찢지 않았습니다. 고맙게도 상단 케이블에는 약간의 여유 공간이 있습니다.
    • 이와 같은 미묘한 디자인 변경에는 수리 안내서가 유용하게 사용됩니다.
    • 7 Plus를 열면 휴대폰 가장자리를 따라 검고 흰 끈적 끈적한 접착제가 많이 보입니다.
    • 우리가 추측컨대 이 펭귄-테마의 끈적임은 Apple의 방수 기능 추가 노력의 일부일 것입니다. 또 한편으로, Apple 엔지니어들이 그냥 접착제를 엄청 좋아하는 경우일 수도 있습니다.
    Interesting, threes no button, yet it looks like there is? and the metal peice on the side transfers teh taptic? ... Can you go more into this?
    Mark - crwdns2934203:0crwdne2934203:0
    That's the TouchID sensor.
    fastasleep -
    Is the White gasket material less or more sticky than the Black? It does look like its thicker than the black (has more viscosity)?
    You guys act like APPLE hasnt already said that the new iPhone has waterproofing. Which they did and there are plenty of videos showing it works
    Jarrett Moering - crwdns2934203:0crwdne2934203:0
    I like your writing style! ..."Then again, Apple's engineers might just really love glue." And then a fanboi moron adds comments! Fake Geniuses' would never learn!
    orion2000 - crwdns2934203:0crwdne2934203:0
    The Glue is silicone ferrite add with adhesive to deflect Cellular transmission effectively
    Loli Pop - crwdns2934203:0crwdne2934203:0
    The iSclack is more than necessary. This cables can be broken easily. One of the reasons I love iFixit. From my experience all iPhones since iphone 4 were a little waterproofing. I didn't have problems with lightly rain or with wet hands or very sweaty faces. Now with the new iPhone I will use it safely at the beach. However waterproofing is a subjective issue. The iphone 7 is less waterproof than the second Apple watch.
    What Apple Enginners love the most was screw. They take all size of screws, probably they have to get used to different 2 different bosses. Lol...
    HSY3 HSY4 - crwdns2934203:0crwdne2934203:0
    I'm sure that very soon, you will be loving selling us replacement waterproof sticky seals.
    Yeah where can we get "genuine Apple" seals?
    gleeglee217 -
    As long and convoluted as the prox has become, there should've been a close-up.
    mstein - crwdns2934203:0crwdne2934203:0
  6. iPhone 7 Plus 분해도: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Mako Driver Kit - 64 Precision Bits
    $33.96
    • 내부에서 배터리 커넥터와 디스플레이 케이블 두 개를 덮고 있는 케이블 브래킷 주위를 둘러싼 용맹한 tri-point/3-점 나사들을 발견합니다.
    • 일 년 전, 우리는 큰 마음을 먹고 64-비트 툴킷에 Apple 워치 나사를 추가했습니다. 진짜, 그러길 잘했죠.
    • 두 번째 tri-point/3-점 나사 소대는 길고 탄력있는 상단 부품 디스플레이 케이블 브래킷을 고정합니다.
    • Tri-point/3-점 나사는 흔하지 않습니다. Tri-point/3-점 나사가 마모 가능성이 낮고, 기계적인 이점에서 선택되었다면, iDevice 전체에서 사용되야 합니다. 하지만 이들은 배터리 및 화면 교체 처럼 가장 일반적인 두 가지 사용자 수리를 방해하기 위해 존재한다는 것이 분명합니다.
    • 우리는 자사의 스크루드라이버를 파병하여 브래킷의 항복을 이끌어 내어 iPhone 7 Plus의 심장부로 우리의 임무를 진행합니다.
    There is space for audio jack up there!
    victortaykw - crwdns2934203:0crwdne2934203:0
    Audio Jack and Water Resistance strike me as being somewhat mutually counterproductive. I, for one, am very happy to see the poxy 3.5mm Jack consigned to history.
    biowizard -
    Another possibility for the reasoning behind the tri-point screws is that Apple knows these are the most common screws to need to be removed, and chose to go with something less likely to strip for their "geniuses" to work with.
    Bryan Schwartz - crwdns2934203:0crwdne2934203:0
    The Phillips screw is a terrible screw drive design. According to McFeeley's, it was invented and promoted because the driver will cam out when torque increases. I'm skeptical about the motivation, but Phillips screws cam out or strip out with alarming frequency, especially in smaller sizes. I would love to never see or use a Phillips screw.
    If you want to ding Apple for picking obscure drivers, fine. But you should also ding them, and everyone else, when they use the horrible Phillips screws.
    Derek Roff - crwdns2934203:0crwdne2934203:0
    Then why not use Torx?
    Chris Prendergast -
    The reason tri-lobe screws are used is because a Torx drive socket on a screw that small wouldn't work. The tri-lobe is like a Torx profile and has the same advantages, but with two less lobes. In addition, tri-lobes are used because it can be put on a screw with a thinner head, where other drive types wouldn't work. The thinnest screw heads (0.3mm and below) require tri-lobe.
    Do people really think nefarious apple engineers are intentionally trying to keep users from doing repairs? They could care less. Besides, if anyone's gotten that far, a screw type with an uncommon head is not going to stop them.
    John Connor -
    Bryan is right. They are tri-point because they are the most common to remove and therefore you don't want to strip them. Why all the screws aren't tri-point I'm not sure of.
    Shaun Stelley - crwdns2934203:0crwdne2934203:0
    But what size of tri lobe is it? Like apple watch y0.6?
    Piotr - crwdns2934203:0crwdne2934203:0
    I never could understand why Apple is bothering with so many different type of screws. At the age of ebay and iFixit every screw can be opened safely. Maybe another method to discourage users that don't know iFixit to mess with the the internal hardware
    Lets add more screw variant each new release....
    taexyz - crwdns2934203:0crwdne2934203:0
    Be careful on this part, I did rip one of the cables in the middle. There are actually 2 and the one I broke was for the home button...
    Brent Thompson - crwdns2934203:0crwdne2934203:0
    Is there a way to remove stripped screws
    mlclarke303 - crwdns2934203:0crwdne2934203:0
  7. iPhone 7 Plus 분해도: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 헤드폰 잭 대신, 휴대폰 외부에서 마이크로 소리를 입력하는 것처럼 보이는 부품이 있습니다... 또는 Taptic Engine/탭틱 엔진에서 출력.
    • 여기 복잡한 전자 제품이 아닌 제대로-설계된 음향 시설과 플라스틱 틀이 있습니다.
    • 분해도 업데이트: Apple에 따르면, 이 플라스틱 부품은 기압 벤트라고 합니다. 방수 씰링은 추가 방수 방진 기능을 제공하며, iPhone은 이 baffle/배플을 사용하여 내부 압력과 기압을 균등하게 만들어 고도계의 정확성을 높입니다.
    • Taptic Engine/탭틱 엔진을 사용한다면 기계식 버튼은 옛날 일입니다! 이 세련된 엔진은 haptic/촉감 피드백을 사용하여 실제 버튼없이 버튼 누름을 시뮬레이션합니다.
    • Retina MacBook 2015의 터치 패드에 익숙한 사용자는 이미 Taptic Engine/탭틱 엔진의 haptic/촉감을 경험했습니다.
    If it's like ours (Chipworks), there's a microphone on one end of it , so it could be some sort of sound channeling chamber for that.
    BHD2 - crwdns2934203:0crwdne2934203:0
    Touchpad is also in the latest MacBook Pro laptops
    Nathanael - crwdns2934203:0crwdne2934203:0
    Apple doesn't waste space. The left port is for the microphone. It isn't a fake speaker port. And that speaker like component is a sound chamber - like our outer ears.
    James Katt - crwdns2934203:0crwdne2934203:0
    I agree, likely used to cut down on wind noise (low frequencies) the mic could pick up.
    Dan -
    Seems apple wasted space here. That "Taptic" engine seems to have a lot of air in it ( in the middle where it's not needed). Wonder if they could have made that a tad less wide and included the audio jack after all???
    The two things you have to think about is the mass and the throw you have within the Taptic engine when you design it. You need enough mass that can kinetically offset the mass of the device you have it in, as well as the amount of energy to throw of the mass so you feel it.
    It appears Apple has used a slightly larger unit (comparing the images). It would nice if someone could weigh the mass and measure the opening size between the iPhone 7 & 7 Plus Taptic engines and the 6 iPhone vibrators
    Dan -
    Looks a lot like that a "speaker port" for the Taptic Engine, for the home button to not only feel but also sound clicky.
    What you described as a sound chamber doesn't seem to actually have any connection to the microphone, but to the Taptic Engine.
    MrUNIMOG - crwdns2934203:0crwdne2934203:0
    A Taptic could also be used as a subwoofer, due to its low resonant frequency of about 190Hz
    The Speaker Guy - crwdns2934203:0crwdne2934203:0
    Are there pins on both sides of the Lightning port.
    I don't understand it.? No other product is taken apart except Apple products. We don't tear apart Samsung, Teslas, GM cars or any other computer type gadgets. Are people that fascinated with only Apple products? Come on stop it. Enjoy the technology. There's plenty of whiz bang products out there try tear them down too. Otherwise, this is iPhone 7, not iPhone 1 give it a break. I want to know more about the hidden features built into the software.
    Cg10 - crwdns2934203:0crwdne2934203:0
    First day on ifixit? That tore down a lot of other stuff too.
    Tom Chai -
    iFixit does not NEED to take apart the newer Samsung devices. They are quite capable of doing that themself...
    Ruurd Pels -
    Tearing down Samsung products is too dangerous. They explode.
    alex -
    The taptic home button is extension of the 3D touch. Where on the 6S the haptic feedback signaled a single "pop" out menu, the home button feedback happens on keypress and keyup. :)
    Peter Shen - crwdns2934203:0crwdne2934203:0
    I had a problem with the central button of iPhone 4. Now with the touchpad central button of iPhone 7 the reliability is increased. However the taptic engine is too big. I think that it takes valuable space from the battery. Beside the reliability issue the classic button should be better. I don't like the taptic engine of new MacBooks.
    Why do you say the Taptic Engine is too big? Do you think they made it bigger than it needed to be to function the way they wanted?
    pgoodwin1 - crwdns2934203:0crwdne2934203:0
    When playing audio, can the Taptic Engine act as a passive bass radiator?
    Cam someone just tell me the list of screwdriver sizes needed to take a iphone 7 apart
    chfreeman73 - crwdns2934203:0crwdne2934203:0
    • 흔들리는 상황은 어떻게할까요? 움직이는 모든 것을 X-레이로 투시합니다. 바로 우리는 이렇게 Taptic Engine/탭틱 엔진을 투시했습니다.
    • "Taptic Engine/탭틱 엔진"은 은하계 군함의 일부처럼 들립니다. 사실은, 자그마한 linear actuator/리니어 액추에이터/직선형 작동기와 가중 코어를 흔드는 zig-zag/지그재그 스프링으로 작동하는 부품입니다.
    • 솔직히 말하면, 이 부품은 우리가 스마트폰에서 본 가장 큰 작동 기계입니다.
    • Taptic Engine/탭틱 엔진은 새로운 솔리드 스테이트 홈 버튼에 가해지는 압력을 정밀 조절 진동으로 변환합니다.
    • 우리 모두는 버튼을 클릭하는 느낌을 좋아합니다. Taptic Engine/탭틱 엔진의 정밀 진동은 기계식 버튼을 누르는 느낌을 포함하여 다양한 유형의 촉각 피드백을 제공하도록 설계되었습니다.
    • iPhone 6s처럼 haptic/촉감 추가 기능의 일반 버튼을 사용하지 않냐구요? 자, 버튼 한 개를 줄여서, 물이 들어올 수 있는 지점 한 곳이 줄었습니다.
    So is this a voicecoil+magnets actuator? Or a piezo device?
    (I'm guessing voicecoil based on the X-Ray.)
    atlant - crwdns2934203:0crwdne2934203:0
    The central button could have been integrated on the screen. However it is a different component below screen that now it isn't moving. I hope in the future Apple will produce screens with a virtual central button.
    In case of jailbrake the central button shouldn't be operational like it used to be with previous iPhone jailbrake methods.
    So this is the device that replaced the audio jack?
    Michael Balzer - crwdns2934203:0crwdne2934203:0
    This "button" is cool, but to remove the audio jack is not. Seems Apple needs to find a middle ground. Smaller taptic device and room for the audio jack. Not sure why this wasn't considered on the "Plus" size.
    What X-Ray equipment do you use? Do you sell this device?
    Yan Li - crwdns2934203:0crwdne2934203:0
    As a new owner of iPhone 7 plus i think a Linear oscillator is a mixed bag - pluses are quite well known so I'll just point out one big minus - when phone silenced is left on the desk it's almost inaudible. I've already missed some calls and alarms. :( - (it's case that covers camera bump so it lays even flat on desk)
    Treku - crwdns2934203:0crwdne2934203:0
  8. iPhone 7 Plus 분해도: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 우리는 Apple이 배터리 접착제 당김 탭을 포함하는 전통을 고수하여 기쁘게 생각합니다.
    • 배터리 요가를 할 시간입니다. 접착제 당김 탭 세 개를 각각 늘려 배터리를 떼고 배터리 제거가 어렵다는 긴장감을 풀어줍니다.
    Maybe the trickiest part of iPhone repairing. In the case of an early brake of the battery adhesive, tools must be used for removing the battery. Tools that may puncture the battery and cause fire. I suggest a totally discharged iPhone in case of battery replacement.
    And how are we to do that? Let it run down normally? Seems like thatd take a while.
    Tom Jackson -
    If you rub the haptic feedback sensor in just the right spot it will vibrate continuously and drain the battery quickly
    J Goog -
    4 years later, and I a first time teardown of iPhone, I ask, what sort of tools would ease the removal of the battery in case the adhesive is broken?
    Tay W - crwdns2934203:0crwdne2934203:0
  9. iPhone 7 Plus 분해도: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 그리고 여기 위협적인 배터리가 있습니다!
    • 배터리는 3.82V 및 2900mAh, 총 11.1Wh, 6s Plus의 10.45Wh (3.8V, 2750mAh)보다 약간 향상했으며 6 Plus의 11.1Wh, 2915mAh 전지와 동일합니다.
    • Apple은 배터리 수명이 6s Plus보다 최대 한 시간 늘어났다고 주장합니다—즉, 3G 통화시간 21시간, Wi-Fi 인터넷 사용 약 15시간, 또는 대기시간 최대 16일.
    The new efficiency of the iPhone 7 plus allows a smaller battery and lighter weight.
    I don't see how "1.11Wh" can be considered a step down from "1.11Wh"! They are identical numbers. The trouble with comparing mAh values, is that they are meaningless without knowing the voltage. And (knowing that W = VA) ...
    3.82V * 2.900Ah = 11.078Wh (iPhone 7 plus)
    3.80V * 2.915Ah = 11.077Wh (iPhone 6 plus)
    Which means they are exactly the same, bar the least significant digit (which is in the 7's favour)!
    [comment resubmitted to correct typo!]
    I wondder if Apple ever considers using Quick Charge technology from Qualcomm ? My Iphone6 charges at barely over 1A using Apple adapter and cable (slightly lower if using generic cable), whereas QC 3.0 is known to charge at 2A or higher. What gives ?
    hn1964 - crwdns2934203:0crwdne2934203:0
    Apple as far as I know have a tradition of good batteries except the first generation of iPod nano which wasn't a big issue. I hoped for years that a manufacturer would produced a replacement battery for iPhones with bigger capacity. However Apple has proved that is using the best batteries on the market. And after samsung Galaxy note 7, Apple has the advantage on this factor.
    What voltage can iPhone 7 plus charge at? I see many portable charger claims that they allow voltage boost for iPhone. What exactly it is for me to judge whichever portable charger is best suit for iPhone 7 plus?
    Kevin Yip - crwdns2934203:0crwdne2934203:0
    Will I be able to use iphone 7 plus or iphone 6 plus battery into my iphone 6splus
    shrini23 - crwdns2934203:0crwdne2934203:0
    So the iPhone 6 plus had 2915 mah battery and 6s plus had 2750 mah battery and now iPhone 7 plus have 2900 mag battery they be scamming people
    dandre832 - crwdns2934203:0crwdne2934203:0
  10. iPhone 7 Plus 분해도: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apple은 우리가 카메라 배열을 빼낼 때 개별 센서, 렌즈 및 작은 커넥터가 둘 씩 보이게 합니다.
    • 12MP 광학 줌 카메라 두 개—iPhone 7처럼 광학 이미지 보정(OIS) 광각 한 개, 망원 한 개.
    • 두 카메라 모두 Apple이 이전 iPhone보다 60% 더 빠르며 에너지 효율이 30% 더 높다고 주장하는 새로운 이미지 센서를 자랑합니다.
    • 향상된 카메라는 커진 외부 카메라 범프에 가치가 있을만 하다고 합니다—섀시에 내장된 또 다른 방수/방진 전술.
    • 우리는 X-레이 비전을 사용하여 카메라 배열과 눈 싸움을 시작합니다. 눈을 깜빡이지 않으니 카메라 한 대 주위로 금속 패드 네 개가 보입니다. 우리는 이들이 OIS를 가능하게 하는 자석이라고 추측합니다.
    Two sets of OIS?
    The telephoto lens has OIS?
    Not sure about that one
    jetlitheone - crwdns2934203:0crwdne2934203:0
    Is there any chance anybody can take calipers to both lens assemblies and find us an actual height?
    evilspoonman - crwdns2934203:0crwdne2934203:0
    I'm hoping it does but most rumors said no.
    maquinn1978 - crwdns2934203:0crwdne2934203:0
    It really doesn't seem like it. Look at the voice coils. the smaller 56mm unit only has ones that are lined up to move the lenses back and forth for focusing. the 28mm one has magnets and coils that allow it to move from side to side and up and down for stabilization.
    garyliao2001 - crwdns2934203:0crwdne2934203:0
    I agree with you. I don't think the telephoto has OIS.
    jetlitheone -
    Looking at the two camera assemblies it sure looks like the 56mm camera does NOT have OIS. This is consistent what reviewers with units have written so far.
    sam123 - crwdns2934203:0crwdne2934203:0
    Also, are these sensors 6mm diagonal? (1/3-inch sensors)
    I think 1/2,6" the first one. EXIF data suggest tele sensor is 1/3,2"...
    maurizionatali -
    Doesn't look like it has OIS on the 56MM
    http://imgur.com/a/6lrPW
    max - crwdns2934203:0crwdne2934203:0
    I believe those magnets you are indicating on the 28mm optical housing interact with the electromagnets on the face of the sensor assembly. The orange plate with wire traces on all four corners. I agree with your assessment that the 56mm lens is just a focusing voice coil and is not stabilized.
    evilspoonman -
    "the second a telephoto —allow for optical zoom" Really? Isn't it only for Focus?
    Masa - crwdns2934203:0crwdne2934203:0
    One camera is a 28mm F1.8 with OIS and sensor, the other is a 56mm F2.8 normal lens with no OIS and it's own sensor, read, not telephoto that optically doubles ( 2x ) the magnification of the two cameras in use. I am not sure how it is dealt with when in between 1-2X but beyond 2x is "digital zoom" which is essentially cropping the native file of the longest lens. There is no real "telephoto" lens in the iPhone 7+, it is just marketing speak. However, the combination of a 28mm and a 56mm lens is not a weak addition to the already great iPhone camera platform. I plan on using it a lot and making a lot of great images with it when not using my professional gear, for my profession.
    dphotobayer - crwdns2934203:0crwdne2934203:0
    what kind of sensor ? IMX????
    badnessboy83 - crwdns2934203:0crwdne2934203:0
    I know it's Apple's term, but the non-wideangle camera is not, by any definition, "telephoto". It's actually a "standard" lens, roughly equivalent to a 55mm lens on a 35m camera.
    Technically it is a telephoto as are all phone lenses - telephoto means that the lens is shorter than its effective focal length whereas on slrs wide angle lenses have to be reverse telephoto to clear the mirror. It is a telephoto of normal focal length, like the pancake lenses fitted to a number of digital cameras.
    Martin Bacon -
    A telephoto lens has a focal length longer than that of the track length of the lens assembly. Apple is using the term correctly.
    mcm - crwdns2934203:0crwdne2934203:0
    where is gyroscope sensor? and accelerometer? thanks
    hector - crwdns2934203:0crwdne2934203:0
    I'd like to know what the camera module is, and what the pixel size is. In the announcement, they stated "bigger pixels" but never said how big.
    skydivertak - crwdns2934203:0crwdne2934203:0
    Could you please tell us what the image sensor is? I'm hoping for IMX260 or IMX377, probably the two best smartphone chips on the market today; if the nominal rated size of the main chip is "1/2.6" at 12 MP, the closest match I'm aware of in the Exmor lineup would be the 260 given unless its something brand new, that's the closet match to the specs given (at ~1/2.5 and 12 MP), and Sony only makes a few 1/2.6 chips, none near 12 MP, as well as the 260 being the sensor used in the also dual camera V10. I can't see any obvious candidates for the second sensor; the only 1/3.2 sensors Sony has are the 8 MPs. And I don't see any discussion of the front sensor here, though perhaps I'm just missing it.
    CAM Gerlach - crwdns2934203:0crwdne2934203:0
    Which is the maker of these sensors?
    Techno Golo - crwdns2934203:0crwdne2934203:0
    What's the baseline between two camera?
    kaiyeh0913 - crwdns2934203:0crwdne2934203:0
    Hello guys,
    Have you figured out who is the sensor manufacturer?
    Miguel Ferreira - crwdns2934203:0crwdne2934203:0
    Smartphones even iPhones suffer from image noise during low light shooting. They use very small image sensors which can't gather enough light fast. So the software amplifies digitally the ISO creating image noise and deteriorating colors.
    I would prefer a bigger camera with a bigger image sensor with better image stabilization instead of two cameras. Ordinary users are impressed more from the two cameras and don't know the benefits of bigger image sensors.
    I think Sony should be the manufacturer, OIS is not available for the telephoto lens.
    gr8sujit - crwdns2934203:0crwdne2934203:0
    The comments below this article indicate the telephoto lens does indeed have OIS. But the comments above my post say otherwise. What is the final conclusion? Does the iP7+ have OIS on all lenses/cameras?
    speedlever - crwdns2934203:0crwdne2934203:0
    Can the camera glass be replaced?
    parshnib - crwdns2934203:0crwdne2934203:0
    Would there be a way to turn off the hardware OIS by doing into the machine? Some people with stabilizing gimbals are finding the hardware OIS troublesome by causing jitters on video capture. Apple has not enabled a way to completely turn off hardware OIS.
    timdlr - crwdns2934203:0crwdne2934203:0
    Any chance of being able to replace the camera glass? It's built into the chassis but looks like it could be removed and replaced.
    phnxdemon24 - crwdns2934203:0crwdne2934203:0
    How do you troubleshoot the camera system when only the 2x camera will work? Replacing the camera didn’t effect the situation - still the same. Any suggestions?
    Rich Tefertiller - crwdns2934203:0crwdne2934203:0
  11. iPhone 7 Plus 분해도: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 후면 케이스에서 로직 보드를 빼기 전에 안테나 어셈블리 일부를 분리해야 합니다—안테나 경로 사이에 다리 역할을 하는 안테나 플렉스 케이블 포함.
    • 안테나 플렉스 케이블을 분리한 상태에서 우리는 왼쪽 상단 Wi-Fi 안테나로 관심을 돌립니다.
    These both appear to be Squelch pads. The second image is the shielding cover over the second. The antenna is the upper case its self.
    Unlike the iPhone 6 series which had two antenna's in the top case this series shares the same antenna for both cellular and WiFi. Its possible they also have so attenuator logic here as well.
    What's with all the tooling marks in the pink? I thought the back is supposed to be as beautiful as the front?
    Charles Reese - crwdns2934203:0crwdne2934203:0
    I hope the the new iPhone 7 with smaller visible antennas will have the same sensitivity as previous models.
  12. iPhone 7 Plus 분해도: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 7 Plus에서 로직 보드를 빼내는 것은 이전 모델보다 훨씬 쉽습니다. 마지막 연결을 분리하기 위해 로직 보드를 뒤집을 필요가 없습니다.
    • 작은 승리처럼 보이지만 우리는 용기를 얻었습니다—작은 디자인 변경도 수리 용이성에서 차이를 만들 수 있습니다.
    • EMI 스티커를 떼내니 추가 열 관리 장치가 보입니다.
    • 밑에 있는 것이 A10일까요?
    That EMI stickers are destroyed when are peeled off? Can they be reused with the same efficiency? Can they be replaced by better quality and more safe ones?
    You guys seem to have ignored the above comment. But really is the EMI sticker replaceable? If so where can we get it ?
    Thdnks
    Musa Bah - crwdns2934203:0crwdne2934203:0
  13. iPhone 7 Plus 분해도: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 방어막이 내려왔습니다! 로직 보드는 검사할 준비가 되어 있습니다. 이 기기 어떤 부품을 포함하고 있는지 봅시다!
    • Apple A10 Fusion APL1W24 SoC + Samsung 3GB LPDDR4 RAM (K3RG4G40MM-YGCH 표시)
    • Qualcomm MDM9645M LTE Cat. 12 모뎀
    • Skyworks 78100-20
    • Avago AFEM-8065 전력 증폭기 모듈
    • Avago AFEM-8055 전력 증폭기 모듈
    • Universal Scientific Industrial O1 X4 (아마도 M2800 "Trinity" SIP)
    • Bosch Sensortec BMP280 기압 센서
    Anyway to tell if there are enough antennas support 4x4 MIMO?
    Nick Roosevelt - crwdns2934203:0crwdne2934203:0
    The blue chip is bigger than the small one, so it can't be same.
    The blue one is an Avago AFEM-8055 Power Amplifier Module.
    Cheers,
    Sebastian Beyer - crwdns2934203:0crwdne2934203:0
    Blue one should be 8055 from the picture?
    torlies - crwdns2934203:0crwdne2934203:0
    What's the part at the right location of the blue avago chip?
    The Qualcomm Snapdragon X12 LTE modem indeed does support 4x4 MIMO, 256-QAM downlink, 64-QAM uplink
    Source: https://www.qualcomm.com/products/snapdr...
    tuanchoang - crwdns2934203:0crwdne2934203:0
    It supports 4X4 MIMO, but the physical antennas have to be installed by the manufacturer, in this case, Apple would have to be sure to include the antenna set. It is supposedly supported via software update, so it seems that might also depend on Apple.
    The chip below the green one looks like a Murata one. It has its marker "M" with a circle.
    Jie Zou - crwdns2934203:0crwdne2934203:0
    So Apple is advertising a 450 Mbps maximum downlink throughput (cat 9 or 10) but Qualcomm chipset (at least, no idea for intel LTE baseband used) is capable of Cat 12 , i.e up to 600 Mbps throughputs ? Maybe Apple is advertising 450 Mbps because only Qualcomm chipset support it ? Maybe it is firmware locked to ue cat 9 or 10 ?
    Basile Carle - crwdns2934203:0crwdne2934203:0
    Looks like there is another chip hidden. Left side of A10chip, in between capacitors - try to xray or remove the material
    humanresourceac - crwdns2934203:0crwdne2934203:0
    You mean the inductor coil?
    Dan -
    3 GBytes Ram on iPhone when the 4Gbyte Ram of new macbook are considered enough by Apple. This phone is a real beast. The one Gbyte of iPhone 6 plus isn't enough for multitasking with the new updates of apps. A really huge step forward. The gap between iPads and iPhone is closing.
    The Avago chips are really Broadcom chips. Avago announced its intention to acquire Broadcom in May 2015. The acquisition was completed in February 2016. Avago decided to exist under the Broadcom name, as it was more well known than the relatively new Avago (which formerly was part of Agilent, which itself was a spin-off from Hewlett-Packard).
    bobmcd50 - crwdns2934203:0crwdne2934203:0
    It is not "MDM9645M". It is MDM9645.
    JJ Wu - crwdns2934203:0crwdne2934203:0
    52RD.com is showing the Invensense 773C chip on the same board. http://img.mp.itc.cn/upload/20160919/734...
    Geeky1 - crwdns2934203:0crwdne2934203:0
    Very surprised that Ifixit would miss such an identifiable chip. Especially after having so much time to correct it. Could something foul be afoot with the politics in which they "teardown"?
    dseigel - crwdns2934203:0crwdne2934203:0
    Can't say for certain. I just find it bizarre that no US teardown has identified this chip but several others internationally have.
    Geeky1 -
    what is inside "Universal Scientific Industrial O1 X4"? There are two similar parts on the main board.
    很有用的拆解!对于初学者有很大的帮助,谢谢!
    Ivan Xie - crwdns2934203:0crwdne2934203:0
    i want to know what is the middle ic of ( green/yellow/blue/ )
    Under the Avago AFEM-8065 Power Amplifier Module ic
    what ic is that ..i want to replace that ic .. coz i have buy a iphone 7 plus with 3g 4g issue ..and someone remove that ic from the m.board ..plzzz help me to find that ic..thanks
    kasun ruwanga - crwdns2934203:0crwdne2934203:0
    There are 2 antenna connector at the bottom of the front logic board. Can someone ID what are the two for? One plug into a signal cable from the loud speakers and the other came from the thin film lightning connector assembly. Why the loud speaker have a signal/antenna cable?
    tandylan - crwdns2934203:0crwdne2934203:0
  14. iPhone 7 Plus 분해도: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 뒤 쪽에: 또 다른 IC 밭!
    • Toshiba THGBX6T0T8LLFXF 128GB NAND 플래시
    • Murata 339S00199 Wi-Fi/Bluetooth 모듈
    • NXP 67V04 NFC 컨트롤러
    • Dialog 338S00225 전원 관리 IC
    • Qualcomm PMD9645 전원 관리 IC
    • Qualcomm WTR4905 멀티모드 LTE 트랜시버
    • Qualcomm WTR3925 RF 트랜시버
    Which SKU of iphone7+ are you tearing down? Does it support CDMA?
    sameer vora - crwdns2934203:0crwdne2934203:0
    The wifi module is done by Murata again. And it seems to provide another chip above the blue one?
    BTW where is the motion sensor, i.e., the accelometer and gyro?
    Sameer Vora - There is only one. The iPhone has been CDMA+GSM since the "World Phone" of the iPhone 4S
    Steven Gergus - crwdns2934203:0crwdne2934203:0
    Not true - The 7 now has 4 part numbers: 2 for the CDMA (7 & 7+) and 2 for the GSM (7 & 7+) . IIRC - the GSM only models have Intel Modems - but no CDMA support.
    Nikon1 - crwdns2934203:0crwdne2934203:0
    TLC again! Is it a 3D NAND?
    Yifan - crwdns2934203:0crwdne2934203:0
    How is the Bluetooth antenna compared to the one on the 6S Plus? Bluetooth performance is particularly important for me since I've invested in wireless earbuds with a weak RX. 6S Plus works fine but there's always room for improvement.
    nametemp - crwdns2934203:0crwdne2934203:0
    Has anyone noticed the lack of an envelope tracker on the Qualcomm version of the iPhone 7??
    Anshel Sag - crwdns2934203:0crwdne2934203:0
    Of course there isn't place for an FM analog radio receiver. I will die and iPhones will still snob the traditional free analog radio. Mobile carriers love people paying for listening radio during commuting. Apple doesn't even produce an adapter for radio. One of the few topics that android phones are betters.
    The model is A1785 according to the first post. This means this is the Japan model. If what I hear is correct, this means that the chips in this model are different than those around the world. This has to do with the FeliCa chip that Apple said would be available in "iPhones sold in Japan." What I would like to know is what a teardown of a non-Japanese iphone 7 has in terms of NFC chips. I wonder because there would be a difference of "We only advertise FeliCa in Japan (but the hardware is there)" as opposed to "We only include the hardware for FeliCa in the Japanese SKUs, A1779 (iphone 7) or A1785 (iPhone 7 Plus)." As someone who travels to Japan (and has Suica/FeliCa cards), this would be useful to know.
    Charles Rosenberg - crwdns2934203:0crwdne2934203:0
  15. iPhone 7 Plus 분해도: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 잠깐, 뒷면에 더 많은 IC가 있습니다!
    • Apple/Cirrus Logic 338S00105 오디오 코덱
    • Cirrus Logic 338S00220 오디오 앰프(x2)
    • Lattice Semiconductor ICE5LP4K
    • Skyworks 13702-20 Diversity 수신 모듈
    • Skyworks 13703-21 Diversity 수신 모듈
    • Avago LFI630 183439
    • NXP 610A38
    it should be lattice iCE5LP4K . what is the purpose for this ? any advantage with it ?
    william0312 - crwdns2934203:0crwdne2934203:0
    Thanks for the Audio Codec and Amplifier info!!
    Barry Wilson - crwdns2934203:0crwdne2934203:0
    As usual Apple exept the panel of iPhone, purchases everything from third suppliers.
  16. iPhone 7 Plus 분해도: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 로직 보드 뒷면의 마지막 몇 IC:
    • TDK EPCOS D5315
    • Texas Instruments 64W0Y5P
    • Texas Instruments 65730A0P 전원 관리 IC
    • 그리고 언제나 그랬듯이, Chipworks 실리콘 전문가의 주요 IC 식별 도움에 감사드립니다! iPhone 7 제어 하드웨어 심층 분석을 위해 분해 페이지로 이동하세요.
    Is there any dimension numbers?
    Hmil2017 - crwdns2934203:0crwdne2934203:0
  17. iPhone 7 Plus 분해도: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 휴대폰에서 스피커를 들어 올리면 멋진 스프링 접점과 방수 방진 기능의 메쉬가 보입니다!
    • 6 Plus6S Plus 스피커와 설계가 유사한 7 Plus 스피커는 친숙한 안테나 부품을 갖추고 있습니다.
    If the lightning port is not smooth with the body the phone will fail when submerged in water?
    Bubs - crwdns2934203:0crwdne2934203:0
  18. iPhone 7 Plus 분해도: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 작은 리본 케이블은 Lightning 커넥터 어셈블리를 스피커 그릴에 단단히 붙어있는 마이크로 연결합니다.
    • 예상대로, 스피커 그릴은 내부를 시원하고 건조하게 유지하는 방수 방진 기능이 있습니다.
    • 그리고 혹시 눈치 채지 못했다면, 이 Lightning 커넥터 어셈블리는 거대합다! 이전 세대와 마찬가지로 후면 케이스에 적당히 붙어있어 쉽게 분리됩니다.
    • 이 케이블 어셈블리는 또한 우리가 본 Lightning 커넥터 중 가장 크고 튼튼한 개스킷이 특징입니다. 방수 방진에 작년 모델은 거품 접착제를 사용했지만, 이 어셈블리는 50미터 물줄기를 저지하는 완전 고무 개스킷이 특징입니다.
    I think the 50m water resistance is apple watch 2's feature, not iphone 7's.
    ruoungon - crwdns2934203:0crwdne2934203:0
    QUOTE: "capable of holding back a 50 meter column of water"
    Really?! I thought the iPhone 7 models were IP67 - meaning they should withstand ingress from 1m of water for 30 minutes
    I think I found the baro sensor, it's underneath the lower left mic, sharing the same port.
    Tom Chai - crwdns2934203:0crwdne2934203:0
    The gasket itself perhaps can hold back a 50m column of water.
    Rick Bargerhuff - crwdns2934203:0crwdne2934203:0
    Me thinks steps 18 & 19 got swapped
    coodie - crwdns2934203:0crwdne2934203:0
    Whoops! Fixed, thanks!
    Andrew Optimus Goldheart -
  19. iPhone 7 Plus 분해도: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 방수는 iPhone 7 Plus의 새로운 기능으로 선전했지만—무엇이 실제 방수 기능을 작동하냐고요? 증거는 도처에 있습니다:
    • 그림 1과 2: 고무 개스킷과 플라스틱 SIM 추출 플러그.
    • 그림 3: SIM 트레이의 고무 개스킷.
    • 여기에 번역 삽입고무 개스킷과 플러그는 새로운 기술은 아니지만 휴대폰에 액체와 먼지가 들어 가지 않도록 막는 효과적인 기술입니다. 그러나 대가를 치러야 합니다—부품을 교체할 때 개스킷을 제 위치에 설치하여 씰링이 잘 이루어지도록 해야 하는 특별하고 까다로운 단계입니다.
  20. iPhone 7 Plus 분해도: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 후면 케이스 발굴을 일시 중지하고 디스플레이 어셈블리와 해당 비트를 살핍니다.
    • 전면에서 보면, iPhone 6 및 6에서 빼낸 1920x1080 디스플레이와 동일하게 보이지만 눈에 띄는 차이가 몇 있습니다: 이 부품은 이전 모델보다 더 넓은 P3 색상 영역을 지원하며 25% 더 밝아졌습니다.
    • 또한 디스플레이 EMI 보호 장치 왼쪽 가장자리에 물 손상 계기가 보입니다. 이 기기에는 방수 기능이 있지만 이 휴대폰을 차고 수영할때 Apple은 책임지지 않습니다.
  21. iPhone 7 Plus 분해도: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 표준 Phillips/십자 나사 몇 개를 풀면 이어피스 스피커는 전면 카메라 밑에서 그냥 떨어집니다.
    • 이 새로운 이어피스 스피커는 두 가지 기능을 제공합니다—처음으로, 스피커 역할을 하여, 마음껏 즐기고 싶은데 헤드폰을 연결할 수 없을 때 iPhone 스테레오 사운드를 제공합니다.
    • 전면 카메라 케이블 어셈블리는 조금 더 버겁습니다. 일반적으로 우리에게 제공되는 엉킨 무언가는 미트볼과 함께 제공됩니다.
    • 모두 통틀어, 상위 부품 번호:
    • 전면 카메라
    • 마이크
    • 스테레오-지원 스피커
    • 근접 센서 및 주변 광 센서
  22. iPhone 7 Plus 분해도: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 더 많은 tri-point/3-점 나사가 홈 버튼과 LCD 쉴드 플레이트를 고정합니다.
    • 그러나 다행히 LCD 쉴드 플레이트에는 접착제를 사용하지 않으며—케이블은 잘 관리됩니다.
    • 여기는 볼 것이 많지 않기 때문에 쉴드 플레이트를 신속히 분리하고 집으로 향합니다, 즉 홈 버튼.
    Has the possibility to swap the flat button extender home like the iphone 6s
    atlantisgfx - crwdns2934203:0crwdne2934203:0
    为什么中国的iPhone7 LCD屏盖板上有粘合剂?把屏幕排线和盖板粘在了一起
    FlyingPig - crwdns2934203:0crwdne2934203:0
  23. iPhone 7 Plus 분해도: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 마지막으로 디스플레이 어셈블리에서 분리되는: 홈 버튼.
    • 실제로 홈 터치 센서와 비슷합니다. 버튼은 없습니다.
    • Analog Devices AD7149 Capacitance/커패시턴스 센서 컨트롤러
    • 숨죽이고 기다리는 사람들에게, 새로운 솔리드 스테이트 홈 버튼은 분리 가능하게 보입니다. 작은 tri-points/3-점과 접착제를 가볍게 사용한 케이블 분리는 간단한 절차가 아니지만 교체해야 하는 부서지기 쉬운 개스킷은 더 이상 없습니다. 전반적으로 올바른 방향 단계입니다.
    • 교체 가능한 홈 버튼은 소비자에게 희소식입니다. 기계식 홈 버튼은 과거 iPhone의 약점입니다. 우리 정보에 따르면 홈 버튼 안정성은 5와 5s에 비해 6와 6s에서 더 나아졌지만, 여전히 약 10만 명의 사람들이 iPhone 6 홈 버튼 복구 절차를 사용하고 있습니다.
    • 게가다, 비 기계식 버튼으로의 전환은 전반적인 안정성이 향상되어 교체 필요성이 줄어 듭니다. 말할 것도 없이, X-레이로 볼때 멋있습니다.
    How is the home button waterproofed? It looks like it just sits on top of the glass but that can't be right...
    The home button acts like a plug, with wedged sides pressing on the screen from above. The screw actually pulls the button in to seal tightly.
    Tom Chai -
    If it doesn't 'move' for normal operation, why is the home button removable? I'm anxious to feel these in action.
    lwwells - crwdns2934203:0crwdne2934203:0
    The home button still implements the touch ID circuitry so it needs to be removable in order to replace.
    Rick Bargerhuff -
    If I recall, not everyone can replace the home button on the previous iPhone because there was a chip on the cable that has some data that's tied to the specific motherboard (apple citing that it was a security feature). Only a reprogram at Apple can "pair" a new home button to a phone. I wonder if this is like that? But without any moving parts, it's a lot more reliable of course.
    Ryo Saeba - crwdns2934203:0crwdne2934203:0
    Yes the home button needs to be paired so after replacing my screen and new home button. It doesn’t work. And it’s $399 for apple to fix it without Apple care
    Daniel L - crwdns2934203:0crwdne2934203:0
  24. iPhone 7 Plus 분해도: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 링/사일런트 스위치와 전체 개스킷 그리고 나머지 버튼 케이블을 빼낼 수 있습니다.
    • 하지만, 볼륨 및 전원 버튼은 케이스에 아늑하게 자리하며 기존 제거 방법을 무시합니다.
    • 이 디자인은 과거 Apple 특허 방수 버튼을 연상케 하며 능숙한 분해 기술을 필요로합니다.
  25. iPhone 7 Plus 분해도: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 7 Plus 분해도: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 그랜드 피날레! 우리는 낱낱히 분해한 iPhone 7 Plus 부품을 나열하여 검사합니다.
    • 하지만 곧—Cupertino/쿠퍼티노의 최신 기기가 곧 나옵니다. 더 지켜보세요!
    • 우리가 가장 잘 하는 분해 작업을 하도록 도쿄 사무실 공간을 빌려준 Nikkei 친구들에게 대단히 감사합니다!
    Did/could you guys put the phone back together into working order. Did ya fix it?!
    fullard108 - crwdns2934203:0crwdne2934203:0
  26. crwdns2935195:0crwdne2935195:0
    • 배터리에 쉽게 접근할 수 있습니다. 배터리를 분리하기 위해 특수 드라이버 및 접착제 제거 기술 지식이 필요하지만 그리 어렵지 않습니다.
    • 솔리드 스테이트 홈 버튼은 일반적인 실패 지점을 제거합니다.
    • 개선된 방수 방진 기능은 (수리를 복잡하게 하지만) 환경 손상 및 실수로 물을 쏟은 경우의 수리 필요성을 낮춥니다.
    • 디스플레이 어셈블리는 제일 처음으로 분리하는 제품으로 스크린 수리를 단순화하지만 개선된 방수 조치는 수리 절차를 더욱 복잡하게 합니다..
    • 트라이-포인트/3점 나사 추가로 인해 iPhone 7 Plus 수리에는 최대 네 가지 드라이버가 필요합니다.
    crwdns2935097:0crwdne2935097:0
    7
    crwdns2935197:07crwdne2935197:0
    crwdns2935199:0crwdne2935199:0
crwdns2934873:0crwdne2934873:0
en ko
80%
crwdns2934883:0Christian Kimcrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2947412:0153crwdne2947412:0
%#*@ i was so eagerly waiting for this ! I'm like ifixit hasn't uploaded the first set of teardown and here we go
yazdanbanaji - crwdns2934203:0crwdne2934203:0
Me too! Love their work.
Colin Baines -
Has anyone tried to remove the home "button" yet? Worried about being able to transfer touch id to replacement screens......
rneeley - crwdns2934203:0crwdne2934203:0
I think the home button is still transferrable to replacement screen based on the screws right under its plate, it should have a small connector to the LCD assembly itself.
iTechshark MO -
That it what I am hoping based on the video that came out Wednesday, but then they did not remove it. I own a repair shop, I am sitting on the edge of my seat here ;)
rneeley -
Same thing here lol
iTechshark MO -
Somebody in China beat ifixit to it and did a full teardown. The home button is transferable.
Tom Chai -
Tom - Do you have a link?
rneeley -
Re Home "button" replacement. I was under the impression a new "button" still needs to be calibrated to recognize all previous finger prints. I am not completely positive this is still the case. (?)
jchagman -
If you save your original home button and swap it to the new screen before you close it up, it is still paired to the motherboard. Sometimes the Touch ID won’t work but it’s hit or miss.
Daniel L -
Are you going to teardown model A1784 to see if it does indeed have an Intel modem?
andrewdavidharvey - crwdns2934203:0crwdne2934203:0
It's all about the modem here. Big thing is for me: if Qualcamm, what model, X12? How many antennas, 4x4?
Nick Roosevelt -
Yes, its Qualcomm LTE Cat 12 modem which is capable of 650Mbps downlink speed. But stupid Apple folks have restricted it to 450 Mbps to match with inferior Intel modem on some models. Intel is Cat 10 modem capable of max 450Mbps
shreyassv123 -
I'd be interested to know if iPhone 7 not sold in Japan contains "FeliCa Type-F NFC contactless technology,"
http://www.apple.com/newsroom/2016/09/ap...
msulistio - crwdns2934203:0crwdne2934203:0
I second this! Look forward to maybe hearing from you guys.
Sam Lewis -
The same NXP 67V04 chip is installed also in the AT&T model.
http://www.chipworks.com/about-chipworks...
koyama -
what is the difference of this iPhone compared to the one they sell in USA?
george allo -
It appears the Home button is screwed in. The LCD shield looks like it will be fun to remove since the display cable is now in the middle left of it instead of at the top.
Kevin Stuckey - crwdns2934203:0crwdne2934203:0
I am zooming in trying to find a cable, so far I can't find one coming off the button. I know the folks at iFixit have to take their time and do a complete teardown (and upload and type out info), I just wish they would skip ahead a little ;) - We all know the logic board will come out ;)
rneeley -
Thats pretty much same layout of LCD/Digitizer in iPad Air located on the lower right side with the addition of another flex for front facing cam on iPhone 7 series.
iTechshark MO -
The cable might be routed under the LCD back plate and thats what I am hoping, Apple will be insane having the home button built in the LCD assembly, maybe next year but not that year lol
iTechshark MO -
Ya, It does have a resemblance to the iPad Mini 4 too (oddly enough did two of those this week, of four total I have seen). We should all know very soon hopefully. We all know the fruit company would like to kill all the small repairs shops off and force people to their stores, but then again I am in a fairly large city with no store for 2.5 hours in any direction...
rneeley -
Will this iPhone have USB 3.0, like the iPad Pro?! Haha.
hyperintel13 - crwdns2934203:0crwdne2934203:0
no, Lightning port on iPhone 7 does not have pins on both sides like iPad Pro 12.9" https://twitter.com/ingulsrud/status/776...
joel -
The flex cable appears to go off on the right of the Home button and there seems to be an extension cable that connects to it near the rightmost screw. You can see a small bubble in the cable between the LCD shield and Home button shield??.
You are right, thats what I was saying a minute ago.
iTechshark MO -
Also I am kinda feeling that the home button/touch ID will be easier to transfer than previous model with no adhesive, it seems its just a plate screwed in the button.
iTechshark MO -
Also if you look at the photo closely, there is a flex on the right side of the home button ( its on the left side on the 6 /6S series ) so I am kinda positive that the home button/touch ID is transferrable based on a close up of the photo with a zoom in the right side of the home button.
iTechshark MO - crwdns2934203:0crwdne2934203:0
I agree with you!
Kevin Stuckey -
OK, I see what your talking about. Their is also a little hump on the right that is probably the connection point. Looking at the screw in the center of the button, maybe it comes out the front like the track-pad on a macbook. That shield should be lots of fun, I am betting the LCD flex is glued over.
rneeley -
Yup that sounds right except that the screw is just sitting to hold the button on place and not to adjust its tactile feedback since its not mechanical.
iTechshark MO -
"Two separate sensors, two lenses, and two sets of optical image stabilizers." So OIS on both lenses/sensors?
Holger - crwdns2934203:0crwdne2934203:0
Yes indeed ! You got the right mate ! Despite people's claims on the telephoto lens not having the OiS it's crystal clear from this teardown that it indeed does have one
yazdanbanaji -
Based on Apple , its just one mechanical OIS and the second one is just software controlled so its just one OIS as far as I can tell.
iTechshark MO -
No I don't think so, the electromagnetic coils of the 56mm unit only move the lens back and forth for focusing. The 28mm unit you can clearly see the coils and the magnets that allow it to move side to side.
garyliao2001 -
You are right, didn't notice the coils at all.
iTechshark MO -
I can confirm that the touch ID/home button is screwed in a plate with 3 screws to pull it off and the button itself is screwed to the middle of the shield with one , cheers guys, its gonna be transferrable :)
Good! Now I can sleep soundly tonight knowing I still have a job for the next year :)
Kevin Stuckey -
We all have businesses for another year then Ed :) -- Can not wait to see the pictures, and especially do my own teardown (I am on the east cost of the US, so I have 8-9 hours to wait on Fedex still.)
rneeley -
Haha you are %#*@ right, one more year in repair business lol
iTechshark MO -
Not like many of us get much Samsung business anymore... Most of my customers faint or hang up when I tell them how much to fix an S7 Edge screen... Looking into the freezing technique, but not eager to spend a could grand on a maybe....
rneeley -
You are always so professional
Dorothy - crwdns2934203:0crwdne2934203:0
Great work!! Can't wait to see the speaker on the top !
Please do provide a detailed review of the new NFC chip that features FeliCa technology exclusively for the Japanese model A1784.
Thanks!
AKari Kamigishi - crwdns2934203:0crwdne2934203:0
Please also tear down the 3.5mm to lightning cable to determine what type of DAC it uses
Pasko - crwdns2934203:0crwdne2934203:0
Yes, please do this someone!
Dan Parsons -
And the earphones ~~ DD
Henryplusone -
Are we sure this uses a DAC and the lightning port isn't just capable of outputting an analog signal?
lwwells -
Indeed I am also dying to know what the DAC situation is!
Foo Bar -
I've had one of these adapters since Thursday -- if I had know it was going to take this long, I would have just torn mine down and published the results on my own blog! The reveal of the third amp is a serious indicator Apple has modified its MFi specs, and now allows analogue output from Lightning. That's a HUGE deal.
Mac 128 -
Yes also very keen to find this info out. Chop-chop ifixit (literally)!
shrike8 -
I'd like to see the SIM tray portion that this mechanism is how to achieve water resistance IPx7.
ao11oaray - crwdns2934203:0crwdne2934203:0
Nice teardown!
How about gyro?
STM or Invensense?
john smith - crwdns2934203:0crwdne2934203:0
I am guessing the rectangular chip besides those front-end modules in step 14 is the gyro/accelometer. It becomes such a weird shape because Apple wants both a low-energy 3-axis and an accurate 6-axis in one module. If my theory is right, the marker on that chip hints STM.
Jie Zou -
It is the latest INVN chip
Someone who knows -
Hey someone who knows why are you so sure? In the 6 there were two separate gyros, a Bosch 3-axis and an Invensense 6-axis: http://www.chipworks.com/about-chipworks... Is this a new part (combo 3 and 6-axis)?
John -
It is 6-axis Invensense and yes, I am very sure for reasons not related to this article.
Someone who knows -
7 and 7 plus accelerometer response is different ,so wonder if 7 still use Bosch acce like iphone 6.
john smith -
It appears to be an invensense chip. You can see it on the Chinese version... http://www.microsofttranslator.com/bv.as...
Geeky1 -
Since the other link is now dead here is another! https://translate.google.com/translate?h...
Geeky1 -
So what is reparability score ?
Fahad Muneeb - crwdns2934203:0crwdne2934203:0
Would like to see what's going on inside the 3.5mm adapter.
Paul Weston - crwdns2934203:0crwdne2934203:0
+1! And there are chips in earphones, too. Crack it!~ DD
Henryplusone -
What is the model number of this phone ?
Sathish S - crwdns2934203:0crwdne2934203:0
model number: A1785.
skemhey -
Apple A10 Fusion APL1W24 SoC - made by TSMC or Samsung?
Lets teardown A1784..
skemhey - crwdns2934203:0crwdne2934203:0
100% made in TSMC. That is old news.
Jie Zou -
Wow, amazing. The battery is the same of 6 Plus.
Marco Tini - crwdns2934203:0crwdne2934203:0
I wonder, if I teardown and reassemble again will it be water resistant after re-assembly? as I can see there were some glue while opening the phone.
dhanesh shastri - crwdns2934203:0crwdne2934203:0
Who supplied the gyroscope and accelometer? Traditionally it is near those front-end modules.
Any changes to the proximity sensor and front camera?
tohff7 - crwdns2934203:0crwdne2934203:0
Are you sure home bouton is transferable : supplier in china send me some photo and it s appear the home home flex is laser soldered on the metal frame
sylvainA FR - crwdns2934203:0crwdne2934203:0
How does Apple get stereo from only one speaker? Or does the photo of the speaker in step 19 show a divider in the middle that "separates" two small speakers? If so, how does one call this "stereo" when the two speakers are so close together? And why do the diagrams on Apple's website show lines pointing to the two grilles on the bottom of the phone, with the legend describing them as "Stereo speakers", when the iFixit teardown shows that the left-hand grille doesn't actually have a speaker behind it, contrary to Apple's diagram? And why do some of Apple's own diagrams point to a supposed second speaker towards the top of the phone, though the iFixit teardown found no such speaker there?
johnsawyercjs - crwdns2934203:0crwdne2934203:0
The receiver speaker - that is, the speaker you hold up to your ear when you make a phone call, is the "second speaker" they're using for stereo sound now.
Dan Parsons -
Thanks. It took me a while to figure that out.
So it seems that the second speaker is a beefier version of the ear speaker at the top of the phone, shown above the display in step 5. If so, since this speaker is front-facing, and the speaker at the bottom is downward/side-facing, this might not give a normal stereo image, but it has the advantage of delivering sound along two planes instead of one, so that whether you're facing the front of the phone or its lower end, you'll still have one speaker pointed towards you, which should deliver better clarity than having neither speaker pointed towards you. Of course, if you have the phone sitting on a table and you're facing one of the two sides or the top end of the phone, you won't have a speaker pointed towards you, but you'll still have the front-facing speaker emitting sound up and out, and sound reflecting upward off the table from the bottom-facing speaker, so there will still be good diffusion of sound, and some stereo separation.
johnsawyercjs -
Looks like iPhone 7 Plus has Qualcomm Modem on both CDMA and non CDMA versions !!
shreyassv123 - crwdns2934203:0crwdne2934203:0
But where is the screen teardown??
edenadinar - crwdns2934203:0crwdne2934203:0
It seems more modular than 6s and earlier. Are there more easily replaceable parts?
John Gough - crwdns2934203:0crwdne2934203:0
Unanswered question, what model, if any, uses Intel Modem.
Is there really a specific NFC-F ( Felica ) hardware or is it all software?
K Sec - crwdns2934203:0crwdne2934203:0
Any thoughts about "BENDGATE" - as this phone is lighter than last year's model, will it be bendy, like the original 6-plus? Or pretty rigid, like the 6S-plus? What type of aluminium have they used this year?
It's extremely rigid.
max damage -
Anybody know who makes the 'Proximity sensor and ambient light sensor' shown in step 21?
PrettyFlyWiFi - crwdns2934203:0crwdne2934203:0
What about the 3.5mm adapter? Does it contain a dac?
George Papamichail - crwdns2934203:0crwdne2934203:0
can you measure the different dimensions of the two camera sensors?
simonesala - crwdns2934203:0crwdne2934203:0
This Looks like much easier display-replacement - right?
Naderio LP - crwdns2934203:0crwdne2934203:0
Tear down the adapter please! Dac and amp info needed!
John - crwdns2934203:0crwdne2934203:0
So Felica is available for all iPhone models. I wonder if tourists can use Felica in Japan?
Staubchen - crwdns2934203:0crwdne2934203:0
iFixit! Where can we get hi-res images of these?
mooo - crwdns2934203:0crwdne2934203:0
IPhone 7
Audio ICs
The iPhone 7 still uses the same Apple/Cirrus Logic 338S00105 Audio Codec as in the iPhone 6S, but the Audio Amplifier has changed to the new 338S00220. (previously 338S1285).
We found not just 2 but 3 Audio Amplifiers - we speculate there is one audio amplifier for for each of the two speakers, and the third amplifier is for the headphone via the Lightning port.
The third Audio amplifier is situated next to the Applications Processor Module with 3 black blobs on it. It was discovered during de-soldering of the A10 applications processor. When the blob was scraped off, it was an ‘oh wow, there are 3 audio amps!’ kind of discovery. Chipworks has a Basic Functional Analysis Report of the Apple/Cirrus Logic 338S1285.
Note******** ifixit teardown report only lists 2 audio amps ....Chipworks discovered the third amp
https://www.chipworks.com/about-chipwork...
marty - crwdns2934203:0crwdne2934203:0
Could you measure the dimensions of the A10 Fusion chip? That would be very useful calculation die size! Also, high-res photo's of the A10 would be much appreciated :)
Ewout - crwdns2934203:0crwdne2934203:0
anyone knows something about light and proximity sensors?
Gianluca Bertuzzo - crwdns2934203:0crwdne2934203:0
which ram is right for 7plus ?2gb?3gb?
wei wang - crwdns2934203:0crwdne2934203:0
Wow you guys are like display mate for tearing down phones.
rafaelbreban - crwdns2934203:0crwdne2934203:0
"Hopefully Apple didn't remove anything important." haha
Dylan - crwdns2934203:0crwdne2934203:0
Will you guys tear down the 3.5mm adapter?
rafaelgil2006 - crwdns2934203:0crwdne2934203:0
Does anybody know if the 7 plus is using saphire glass? Or is it (like it was shown in a video earlier on the regular 7) only using Gorilla Glass.
han - crwdns2934203:0crwdne2934203:0
You missed a third audio amplifier. Directly above the "A" in "A10" on the processor, there is a chip with 3 black blobs on it. It's the amplifier for the lightning port to headphone adapter.
spaceywilly - crwdns2934203:0crwdne2934203:0
Yes, that third amp is a significant discovery implying a major change to Apple's MFi specs. In which case its a huge reversal of position, and will lead to a flood of cheap analogue audio products previously not possible, not to mention significant confusion as to just exactly what a "Lightning" equipped product means. My adapter didn't work on my SE until I updated to iOS 10. That shouldn't have been necessary as Apple already has published Lightning audio specs -- unless they changed something significant. So suddenly its not an inexpensive digital adapter with a DAC and amp, its a very expensive port connector changer.
Mac 128 -
Great job! Very interesting and informative! Like your lite hearted easy to read writing!
Nice teardown.... Looks like we have most of the tools available @RadioShack. Ah tri-wings... just like the McDonalds toys.
Radio Shack SLO - crwdns2934203:0crwdne2934203:0
Can somebody help crack my iPhone 6S encryption?? I forgot my passcode and only 2 more attempts before lock out.
hdtv720p - crwdns2934203:0crwdne2934203:0
what is the difference on the 1784 model?
I see everyone asking for a teardown. Is it better than the rest of them?
george allo - crwdns2934203:0crwdne2934203:0
Any idea what the part is between the RF front-end (between the Skyworks part and Avago PAMs)?
Harold - crwdns2934203:0crwdne2934203:0
The stereo speakers function in such a way, that if you do watch a video on your phone or if you tilt your phone sideways, there will be a left and right speaker, both working to create a stereo sound. Most people do use their iPhone sideways to view videos, so this will certainly be noticeable to them.
Jose Toscano - crwdns2934203:0crwdne2934203:0
I'd love to see a review of this. I can't imagine how they are going to make two different speakers sound the same, much less where one faces the listener, and the other points of to the side.
Mac 128 -
What about reassembly? It looks like a lot of the waterproofing is either a) lost, or b) significantly disturbed from the teardown. With reassembly, do we have to completely remove the waterproofing and reapply? If not, does it go back together imperfectly, due to gobs of the waterproofing building up during disassembly?
I wonder if you couldn't spray the entire internals with waterproofing, after the fact? It would make future mods/repairs basically impossible, but would improve/restore the initial waterproofing.
To all the rocket surgeons and techies out there, what're your thoughts?
bsquirdoff - crwdns2934203:0crwdne2934203:0
Can anyone explain why Apple keeps changing their screw heads? I'm genuinely curious to know how this is better than torx or pentalobe.
Ivy Wlrs - crwdns2934203:0crwdne2934203:0
The homebutton is almost the same venkat from harithatech.com
venkatramt - crwdns2934203:0crwdne2934203:0
I was wondering if phones get taken apart for repairability grading, do any of these phones get put back together? :)
How about the flash lights? They claimed to be 4 LEDs.
WPG - crwdns2934203:0crwdne2934203:0
why 4 different types of drivers? star for the bottom two screws, tri point for the new type and the obvious normal screw?
Krayzee - crwdns2934203:0crwdne2934203:0
Hello there ,
I have a question , what size are the tri-points screws (Y000, 1 or 2)??
because i have the classic Pro tech toolkit and i just want to make sure if i have the right tools or not!
Thank you guys
Ibrahim - crwdns2934203:0crwdne2934203:0
Did you specify the IMU package?
Is this the new IPS LCD panel from JDI? I have read it uses the second generation Low Temperature Polysilicon backplanes, which in another article fueled a rumor that a higher resolution panel was going to used due to the power savings.
Is the lightening port data throughput the same as the previous iPhone 6s Plus, or the updated standard used in the iPad Pro?
Have you confirmed that there is analog audio available now from the lightning port?
How about the flash lights? They claimed to be 4 LEDs. http://txlcd.com
txlcdsupplier - crwdns2934203:0crwdne2934203:0
I have a question. Did Apple use any technology from printed electronics, like silver ink, in the latest iPhone?
lol - crwdns2934203:0crwdne2934203:0
If history is any guide as ALL Apple products have InvenSense gyros then we will see an integrated single 6 Axis from InvenSense. The Apple Watch must use a single 6 axis for everything to reduce power.
The only question is did Apple use InveSense GPS navigation Software?
Apple obviously has reduced GPS run time and rides the 6 Axis to reduce power consumption by up to 80% off time. This is what InveSense software specializes in and it has to be in the iWatch.
Will Apple do their own dead reconning algorithms or use InveSense SW?
KrisCo - crwdns2934203:0crwdne2934203:0
I found a write up on a Chinese site that shows the Invensense Chip. http://www.microsofttranslator.com/bv.as...
Also here is a pic of its location: http://img.mp.itc.cn/upload/20160919/734...
Geeky1 -
Can anyone confirm if the camera lens cover and Home button are still sapphire? A few people have said, well, that they aren't.
Chris Brighton - crwdns2934203:0crwdne2934203:0
Can a 6+ or 7+ battery suitable on a 6s+
Porque vocês não me dar um iphone, ao invés de quebrar-lo
fabinhod500 - crwdns2934203:0crwdne2934203:0
Porquê vocês não me dar um iphone ao invés de quebrar-lo
I never understand why it takes so long for folks to figure out the accelerometers / gyros... It's nice to see that others have already identified the InvenSense 773C but I wish iFixit had figured it out first. Is this a living document? Will additional chips and information be added as the rest of the world figures it out? Regardless, great teardown guys! Thank you for doing this year after year!
Bob Powers - crwdns2934203:0crwdne2934203:0
It would be interesting to know who makes the microphone(s). That's a small but important piece that few ever take much notice of.
Is the camera sensor same as on 6s plus? I'm asking about the pixel and resolution. Not just the 12 megapixel total resolution. I know there is a new image processor. That's not the question. I want to know if this new sensor resolves for a better image quality than the iPhone 6 s plus. Practically speaking, is it (the 7 plus camera image sensor) a better film? Better pixels? Knowing the optics are improved for better optical resolution.
gwwakim - crwdns2934203:0crwdne2934203:0
Compared a 7+ Jet Black to and 7+ Black and find the lightning connector is not flush on the Jet Black. Has a sharp edge protruding past the phones surface. Is this normal?
If your lightning port is not flush it is not IP67?
Does anyone know if there is any place that sells the parts of the IPhone 7 plus? I am a new repairer so I want to know where I can find these parts and also the screws and screwdrivers that were used to assemble this. I tried searching this online but most online shops have only iPhone 6s plus parts at the most.
Thanks!!!
Gypsum Chen - crwdns2934203:0crwdne2934203:0
iPhone 7 and now Google Pixel...which smartphone is best for us?
Just purchased the iphone 7 recently from wantITbuyIT and now im waiting for google pixel. The battery life is good unless you are doing something that involves a lot of processing power.
Jenny Jonson - crwdns2934203:0crwdne2934203:0
More importantly did apple FIX the problem that causes Touch Disease in the iphone 6Plus and 6sPlus? you guys never took close photos of the chips to show if they had the epoxy potting that they should have.
timgray1 - crwdns2934203:0crwdne2934203:0
A question: the power button has the rubber around or something for the waterproofing, like the sim tray?
Michele - crwdns2934203:0crwdne2934203:0
There are indeed gaskets in the buttons, you can see them in the iPhone 7 teardown!
Sam Goldheart -
感谢你们翻译成中文来点视频
Gaonan - crwdns2934203:0crwdne2934203:0
Does anyone know what series of aluminum the iPhone 7 plus uses? Thanks.
Albert B. Lopez - crwdns2934203:0crwdne2934203:0
after replacing the touch pad of the 7plus the gps seems to jump around when on google map?
Riaan - crwdns2934203:0crwdne2934203:0
I want to know the place of ic Audio plz !?
s12.s13 - crwdns2934203:0crwdne2934203:0
Where is the GPS in the I phone seven
Robert Graves - crwdns2934203:0crwdne2934203:0
I was replacing an iPhone 7 Plus screen and when I opened the phone up all the screws looked stripped. So I had to figure out any which way to get the screws out. I did and then I replaced the screen. The magnetic cover that covers the phone’s battery/ and screen connectors bent a little. And I noticed that the silver screw female end that is supposed to be attached to the logic board wasn’t on the logic board it was attached to the cover would this cause the phone not to turn on?
Devin Jordan - crwdns2934203:0crwdne2934203:0
My iphone 7 plus screen recently broke and I’ve been told that the IC chip needs to be replaced. The phone won’t turn on. Will this affect the data (photos) stored on the phone?
Karishma Ahuja - crwdns2934203:0crwdne2934203:0
a cosa servono i 2 cavi coassiali ? quello dello speacker e quello de gruppo lightning?
thunderinparadise - crwdns2934203:0crwdne2934203:0
Translation: What are the 2 coaxial cables for? That of the speaker and that of the lightning group?
Dan -
My iPhone keep turn off without stopping
Vanessa Adjessa - crwdns2934203:0crwdne2934203:0
Best to create a question here Answers
Dan -
crwdns2936751:024crwdne2936751:0 55
crwdns2936753:07crwdne2936753:0 262
crwdns2936753:030crwdne2936753:0 1,031
crwdns2942667:0crwdne2942667:0 1,013,894
