Use this guide to replace the vibrator.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following Phillips screws from the battery connector bracket:
One 2.3 mm screw
One 3.1 mm screw
Remove the metal battery connector bracket from the iPhone.
Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.5 mm screw
One 2.9 mm screw
Remove the front panel assembly cable bracket from the logic board.
While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
Disconnect the home button cable connector.
Use a plastic opening tool to disconnect the display data cable connector.
Finally, disconnect the digitizer cable connector.
Remove the front panel assembly from the rear case.
Pry the charge port connector cable up from its socket on the logic board with the flat end of a spudger.
Use the tip of a spudger to disconnect the interconnect antenna cable from its socket on the logic board.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Grasp the interconnect antenna cable with a pair of tweezers and carefully de-route it from its channel on the vibrator assembly.
Remove the two 2.5 mm Phillips #00 screws securing the vibrator to the rear case.
Remove the vibrator from the iPhone.
crwdns2935229:043crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Was fantastic in helping me fix my phone
cjprzy126 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Do you have to remove the screen completely? Or can you just hold it at a 90 degree angle?
robinvanzutphen11 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You can hold it open at 90 degrees if you like. Prop the display open, disconnect the battery, and then skip on down to the vibrator section.
Jeff Suovanen - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did anyone come across the vibrator button switch not functioning after replacing the LCD screen & vibrator? It was working for a second, and after a few more tries, it stopped. It doesn’t even register that the switch is functioning either (you don’t get the quick image on the screen).
(iPhone 6 Plus)
CHARLES ALMERO - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
toufik tnt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
