crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the front-facing camera and sensor assembly.
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
crwdns2935267:0crwdne2935267:0Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Pull the blue handle forwards to lock the arms.
Turn the handle clockwise 360 degrees or until the cups start to stretch.
Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
Skip the next three steps.
Use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Remove the following Phillips screws from the battery connector bracket:
One 2.3 mm screw
One 3.1 mm screw
Remove the metal battery connector bracket from the iPhone.
Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.5 mm screw
One 2.9 mm screw
Remove the front panel assembly cable bracket from the logic board.
While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
Disconnect the home button cable connector.
Use a plastic opening tool to disconnect the display data cable connector.
Finally, disconnect the digitizer cable connector.
Remove the front panel assembly from the rear case.
Remove the following Phillips screws securing the upper component bracket:
One 1.5 mm screw
Two 2.3 mm screws
Lift and remove the earpiece bracket from the display assembly.
Use a the flat end of a spudger to pry up the front-facing camera and display cables, and gently push them aside.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to firmly grasp and remove the earpiece speaker from the display assembly.
Use the tip of a spudger to gently pry up the sensor cable assembly from its recess in the display assembly.
Pry the microphone portion of the front-facing camera and sensor cables from the display assembly.
Remove the front-facing camera and sensor cable assembly off the display assembly.
crwdns2935229:0127crwdne2935229:0
crwdns2947412:013crwdne2947412:0
My front microphone had completely stopped working exactly a week out of warranty. I replaced the front assembly with a new one from Fixit and afterwards it still did not work. Then I realized the microphone did pick up very soft sound if I shouted directly into it. I eventually repeated the entire disassembly and found a very thin yellow film glued to the microphone grill which had been muffling 97% of the sound. After peeling this off my microphone is working perfectly! I did not notice this on the microphone the first time and assume it was the backing for the self adhesive. Make sure you remove this - it is not obvious to spot!
Anthony Berkow - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
ave did wrongSo I replaced my iphone 6 plus screen and after i was done my front camera and my earpiece was no longer working. Any advice on what i might have did wrong ? I have another iphone plus to replace the screen and im a little skeptical now. =\
brian - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Fantastic instructions! fixed my problem first time. Just be patient and try not to touch anything to roughly. Thanks for the tip from a previous comment saying to remove the yellow piece of film over the microphone. This saved me a lot of hassle. Thanks
Glad to have siri, dictation, sound in videos and hansfree calls back :)
lloyd - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
hi could i ask one qustion my iphone 6pluse not working after fall i change new sensore bu tnot working how to fix please conect to me
peth - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is the picture quality the same
QuentaviouS - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
