Use this guide to replace the home button cover. Follow the home button ribbon cable guide to replace the actual mechanical home button.
You can also use this guide to replace the home button bracket.
crwdns2936621:0crwdne2936621:0
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Power off your iPhone before beginning disassembly.
Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
to keep screws in order, buy some double sided tape and then affix the tape in small pieces to a sheet of paper. As you take the screws out, you can affix them to the tape (which is on the paper) and then write a description of what they are and where they go. quick, cheap and easy.
I found that these screws did not remove easily. After turning several times and feeling the threads drop back, indicating they were loose, the heads did not extend far enough to grip with my fingernails to pull out. I had to use the tweezers and then it took a bit more force than expected to remove them.
Me too. But instead of tweezers i used a power drill set at max torque and my desk as leverage, & stood on my chair while bent over pushing every ounce of force I had for at least 5-10 minutes then BOOM. Done. Those screws get stripped too quickly. (True story. No elaboration needed.)
RYEKI -
My iPhone 5c has P1 Pentalobe screws, not P2. This guide caused me to buy wrong tools so I thought I would share my experience. Perhaps they vary.
@codycraven01 These guides are created using iFixit tools, and P2 is definitely the correct driver. If you’re using tools you bought somewhere else, then yes, results may vary.
crwdns2935267:0crwdne2935267:0iSclack$24.99
Close the handle on the iSclack, opening the suction-cup jaws.
Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
The top suction cup should rest just above the home button.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
I just replaced my iPhone 5C battery today and only used the I fix it repair kit that came with the suction cup. Getting the glass screen out was not too difficult as I used a little bit of upward motion on the suction cup while at the same time prying gently with the flat end of the opening tool at the same time. If you have two people it makes it a little easier as someone can hold the phone. After getting the end open, I was able to go around the perimeter and gently pry up the edges with very little trouble.
Experienced immediate problem: there is s strap going from the home button to the screen, about 1-1/2 inch long. After removing 3-4 screws I saw no way to disconnect it from either end. My daughter came to help get the screws back (my 70 years have problems with very tiny screws). Slid a piece back and the strap came free of the home button ares. Screen could only open then 75-80 degrees. Tapr tore. Pried battery out. Replaced on original sticky tape. Restarted fine and about to recycle the charge. Thanks for the kit and all. But 6 demos and 3 inatructions never mentioned this strip! So careful opening it up, please!!
@mikamazn What you’re describing sounds like an iPhone 5s. This guide is for the 5c. Glad to hear things worked out for you.
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
Skip the next three steps and continue on to Step 8.
Press a suction cup onto the screen, just above the home button.
cool i diden't now
very, very difficult to get a tight seal on tape. I removed the tape and still can't get a tight seal.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
Cover a badly cracked screen with a strip of packing tape first to get a better seal for your suction cup. If it's a super crappy suction cup, moistening it a bit will help as well.
Great Idea! I have been doing this for awhile and have never thought to share!
duston -
The pry point in this photo is spot on. Just be gentle and maybe come in at a little steeper angle.
This part ended up being really easy for me. I applied the suction cup just as the picture shows and pulled slowly almost straight up; the screen came off very easily and I didn’t even need to use a plastic prying tool. Not sure why it worked so well but I’m glad!
I did it with a guitar pick and no suction cup.
Be sure not to use metal pry tools as they may crack the plastic.
Pull the plastic nub to release the vacuum seal on the suction cup.
Remove the suction cup from the display assembly.
Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
In a pinch, you can use an unopened canned beverage to hold the display.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
Using a can works really well!
I use an old iPhone box to support the open phone. Set the box up on its end, and rubber band the screen side to the box. It works perfectly!
What do I do if it’s a little sticky and dirty inside?
I can't close the top of the screen no matter what i do.
Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
These screws are very tiny and hard to manipulate. The screwdriver is magnetic; which is great to take them out, but makes it hard to put the screws back in, as the screwdriver pulls them from the hole. I solved this problem by using the pointed end of the spudger to put a tiny drop of Elmer's glue in the hole and then insert the screw. You can do this before putting the bracket in place if you want. Then the screw wont pull out by the magnetic driver and make lining up and fastening the screws much easier; at least for me!
I found that you don't need to disconnect the battery... why bother doing more fiddling with annoyingly tiny screws and obstinate cable connectors when you don't actually have to? Especially when you could only end up causing more damage. As a matter of fact, the original iFixit video didn't bother to disconnect the battery either, but they've since updated the video to include battery disconnection, I guess as a "belt and braces" approach in case the repair-hero forgets to power down the phone first?
Disconnecting the battery is a safety precaution, and yes it's worth doing. Even with the phone powered off, there is some danger of blowing the backlight filter fuse if you disconnect the display while the battery is connected. At that point you're no longer looking at a simple DIY repair. Even though it's possible to skip this step and still come out okay, my advice is not to risk it.
It’s a relatively junky phone, so if it breaks, what the heck. I’m not going to disconnect the battery.
Remove the metal battery connector bracket from the iPhone.
Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
Instead of using a spudger, you can use your fingernails too. This is quicker and enables you to feel if you're not accidentally putting on too much pressure or lifting the connector instead of the cable.
Accidentally pulling out the logic board socket is no idle warning - exactly what I did without much effort. I think this shouldn’t be described as ‘prying’ up because it implies needing to use force - but these things actually pop off quite easily with a nudge, which you discover at later steps.
Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
Two 1.3 mm screws
One 1.7 mm screw
One 3.25 mm screw
I didn't need to remove the front panel to replace the lightning connector. Just prop it up like in Step 8, then skip steps 12-16.
I always put my screws in a magnet tray and place the screws in the exact position they were taken out. The magnet tray holds the screws tight in the position I put them in. No chasing on the floor looking for small screws that you brushed off the table.
I always take a picture of the phone, print it out, then use scotch tape to tape the screws onto the picture in the location where they go. You don't lose the screws and you always know where they go for re-assembly
good tip! but instead of taking & printing a picture of your own phone, you probably could just print the color coded pic from this step (assuming everything on your phone is exactly the same).
When reassembling, the screw holder that the screws screw into came off the board. Is there a way to superglue that back in?
no, do not use super-glue. Quite some of these ‘screw-holders’ are screws themselves with e hollow tread in the head (didn’t find the correct naming for it) - just like the things you screw into a PC case and fasten the mainboard on.
did NOT remove the front entirely. its not necessary to do this to remove the battery. these are only precautionary steps in case your clumsy or you feel you might not be able to manage it without. as always, be cautious.
Agree. Step 12 is unnecessary if one is extremely careful.
*warning* … this connector assembly is very messy to re-build. Next time I change such a battery, I’ll try to get it out carefully *without* detaching the display unit. My resumée: *never* unscrew more things than necessary. These things are not M five (5 mm bolt diameter) like on a bike, these are M zero-point-five. Even for a smirf, this is tiny stuff.
is it necessary to remove these screws in order to remove the battery?
Hi Ali,
You can choose to not remove those screws and still be able to take the battery out. Be very careful supporting the display, or you may tear the display cables and damage your screen.
Remove the front panel assembly cable bracket from the logic board.
Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
You might get a more “modernised” part from eBay (for this very model, iPhone 5c) which has an ENTIRE CABLE missing… if you look closely, it’s been re-directed into the middle cable. And it all works perfectly, touch screen, and display. So it’s a optimisation.
In summary - if you get this version of the screen, you only need to deal with 2 cables, not 3. The rightmost socket will remain empty.
Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
I replaced the broken front panel of the iPhone 5c and got the "famous white stripes" on the new screen. Reading about all kind of problems that the lcd/digitizer cable contacts may cause, I compared the cable connectors of the original Apple and the replacement part I bought online with a 35x magnifying glass. The quality difference was visible: The white description on the original part on the cable next to the connector is: 821-1784-A, while the inferior replacement part is: 821-1784-02. Check out the two numbers online and insist getting the "A" to avoid future troubles !!!
This person above is not knowledgeable. That number is a camera proxy part number, not the lcd or digitizer number. It changes with production date, both for original and aftermarket ones. A, B, D, 02, 04, 08 etc. Can all be either or.
vince -
Apple uses numerical revisions (-02) for pre-production parts, and alpha revisions (-A) for production revisions. It looks like you got a preproduction assembly, or a knock-off.
There are, in fact, three connectors in this step, not two. The front-facing camera and digitizer connector (Step 11) is really difficult to align when you put it back. Took me about 15 minutes before I succeeded.
Now I have a different problem. Everything works just dandy, EXCEPT:
Towards the bottom of the screen (in portrait) there is a horizontal line that is dead to the touch. For example, on the keyboard, I can use the spacebar, but not C V B N M, etcetera.
Three possibilities in my mind: One, when I dropped it, something else besides the glass and digitizer, etc, was damaged.
Two: I did not replace the cables correctly. This seems unlikely. They all "clicked" into place and stayed there.
Three: The digitizer supplied is faulty.
Comments? Which cable/connector could be causing this -- if it is that?
Take apart, Clean Connections, Put back together.... If same problem sounds like a fault part...
duston -
When reassembling the iPhone 5c, I used the flat end of the spudger to press on the connectors and maintain them while replacing the front panel on the body of the iPhone.
The third and "deepest" connector no longer slips out of its socket, which it did before holding the whole lot with the spudger.
If the ESD plate covering the connectors is properly re-attached to the phone, you should not have to do this. The cover holds all the connectors in place just fine.
iBroke -
I replaced the display assembly to resolve an issue with the phone not responding to any touch input. I assumed it was a bad digitizer. However, I have the same problem with the new display assembly—no touch response at all. The phone starts up fine and the screen works, I just can’t “slide to unlock”. This is also preventing me from downloading photos from the phone since I can’t enter the passcode. I have cleaned the connections and reseated the cables. Is it possible this is a problem on the logic board? If so, is there any way to get the photos off the phone since I can’t enter the passcode on the screen?
Remove the front panel assembly from the rear case.
Remove the two 1.3 mm Phillips #000 screws securing the home button bracket to the display assembly.
Ok the screw are just the 2 highlighted in red. Note that if you fix them too tight the button will lose some space. I suggest to fix them tight and then to unscrew them of 180° just to remove some pressure. Then try the home button movement: if it’s ok go ahead otherwise if it has no freedom to move unscrew again a little bit
Use a plastic opening tool to pry the edge of the home button ribbon cable up from the display assembly.
Start under the contact points on the right and work to the left.
If you have an iOpener, I STRONGLY suggest placing it on top to loosen the glue. Once I heated the surface, it came off with little difficulty.
Achtung! Am oberen linken Eck bei den orangenen Kontakten sitzen zwei winzige elektronische Bauteile. Diese können bei unvorsichtiger Arbeit und falls das Kabel sehr fest sitzt abbrechen. Sie sind mit ein bisschen Kleber abgedeckt.
Remove the home button ribbon cable from the display assembly.
Wenn der Home Button nach dem Austausch immer noch nicht funktioniert, sollte man sich die beiden kleinen Kontakte anschauen, die auf der Platine an einem Flachbandkabel sind und auf die in dieser Anleitung zu sehenden messingfarbenen Kontakte drücken. Ist einer dieser beiden Kontakte defekt, muss man den Lightning Anschluss ersetzen. Kostet zwar unter 5€, ist aber ziemlich aufwändig, da der Akku ausgebaut werden muss.
Gently push the top right corner of the home button up away from the front panel.
Peel the home button the rest of the way off of the display by prying gently with a spudger.
Note that under the home button is a very thin adhesive “gasket” that attaches the button to the screen. The home button can easily separate from this adhesive band. If you are not careful you stretch or break it. I used heat fron a hair dryer to loosen it and get it off with the home button.
Remove the home button assembly from the front panel.
crwdns2935229:0112crwdne2935229:0
