Use this guide to replace a broken, cracked, or non-responsive screen on your iPhone 15 Pro.
You'll need replacement screen adhesive to complete this repair.
Note: Due to Apple's parts pairing restrictions, on iOS 17.6 and earlier, True Tone and auto brightness are disabled after a screen replacement, even when using an original Apple screen. On iOS 18 and newer, you can calibrate your new screen using Apple's Repair Assistant to restore functionality on genuine parts.
Unplug all cables from your phone.
Hold the power and either volume button and slide to power off your phone.
If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
如果您的螢幕或後玻璃破裂,請將包裝膠帶貼在玻璃上以保護自己並使拆卸更容易。
確保底部邊緣附近有一個足夠大的光滑區域,以便吸盤可以吸附在上面。
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
the picture shows 3 cm but the description says 3 mm's. Which one is it?
That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
VauWeh -
Oh, come ON!
Big Ed -
It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
@leifdewolf I wouldn't skip it for a first repair.
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
Many of these comments are PURE GOLD. Seriously y’all, if you’re not sure if it should be 3mm or 3cm or whether you could find and use an alternative pick, mending an IPhone really isn’t for you. Find a responsible adult and get back to doing something simpler…
Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
Apply a suction handle to the bottom edge of the screen.
Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap.
There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
触点被弄断了 怎么办??
this screen picture is for iphone 15 pro max lcd, not iphone 15 pro
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Heat the right edge of the screen until it's hot to the touch.
Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
Rotate your pick so the flat edge is under the screen.
Twist the pick to increase the gap between the screen and the frame until the right clip releases.
Insert a second opening pick to the right of the first pick.
Slide the first pick back to the bottom right corner of the screen.
Slide the second pick to the top right corner of the screen to separate the adhesive.
Leave these picks inserted to prevent the adhesive from resealing.
Heat the top edge of the screen until it's hot to the touch.
Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
Heat the left edge of the screen until it's hot to the touch.
Rotate your pick around the top left corner of the screen.
Slide your pick to the bottom left corner of the screen to separate the adhesive.
Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
Swing up the right edge of the screen like the front cover of a book.
Prop up the screen so you can access its cables without straining them.
Use a Y000 screwdriver to remove the six screws securing the logic board cover:
Four 1.6 mm‑long screws
Two 1.3 mm‑long screws
Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
Lift the cable to disconnect it.
Remove the screen.
To reassemble your iPhone, follow this guide to apply new adhesive and install your screen.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
crwdns2935229:018crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Very helpful
Pls also make the videos of your guides available on YouTube so it can be more understandable
Where the hell do you buy the replacement display on the iFixIt website?
You can buy it at selfservicerepair.com it is a lot cheaper there
This adhesive is way more annoying than it has any logical reason to be.
What this doesn't tell you is that you have to swap the proximity sensor on to your new screen before installing it. If you don't, you'll get the pink screen of death. Lots of helpful videos of how to do that on yube tube.
I did this last week, turned out to not be working because the phone for some reason does require the ambient light sensor to be connected. without it, the phoe kept shutting down/crashing every other minute. the instructions unfortunately don't mention this in any way. ended up having to take the phone to the repair shop who replaced the sensor after which it worked fine.
otherwise the instrucions are really good, thanks a lot
在開始維修之前,請讓手機電池電量耗盡 25% 以下——充電的鋰離子電池如果損壞可能會起火。
拔掉手機上的所有電纜。
按住電源和任一音量按鈕並滑動即可關閉手機。
Ansel Lin - crwdns2934203:0crwdne2934203:0
