iPhone 15 Pro Front Camera Assembly Replacement
Spencer Day
crwdns2944107:0crwdnd2944107:0Spencer Daycrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 15, 2025crwdne2944111:0
1 - 2 crwdns2931253:0crwdne2931253:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace the front camera assembly in your iPhone 15 Pro.
If your front camera's image looks fuzzy or has stopped working entirely along with your Face ID, you might need to replace the front camera assembly.
You'll need replacement screen adhesive to complete this repair.
This assembly includes the front-facing camera and Face ID hardware. These parts come as one unit, and the sensors are uniquely paired to your logic board. Note: If you replace this part, Face ID will no longer work. This repair will restore a broken selfie cam to working order, but on iOS 17.6 and earlier, only Apple or an Apple “authorized” technician can restore Face ID. On iOS 18 and newer, you can recalibrate genuine front-facing cameras using Apple's Repair Assistant.
crwdns2944105:0crwdne2944105:0
crwdns2943227:0crwdne2943227:0
  1. iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Prepare your iPhone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
    在開始維修之前,請讓手機電池電量耗盡 25% 以下——充電的鋰離子電池如果損壞可能會起火。
    拔掉手機上的所有電纜。
    按住電源和任一音量按鈕並滑動即可關閉手機。
    Ansel Lin - crwdns2934203:0crwdne2934203:0
  2. iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Tape over any cracks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
    如果您的螢幕或後玻璃破裂,請將包裝膠帶貼在玻璃上以保護自己並使拆卸更容易。
    確保底部邊緣附近有一個足夠大的光滑區域,以便吸盤可以吸附在上面。
  3. iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - crwdns2934203:0crwdne2934203:0
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - crwdns2934203:0crwdne2934203:0
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - crwdns2934203:0crwdne2934203:0
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - crwdns2934203:0crwdne2934203:0
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - crwdns2934203:0crwdne2934203:0
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    @leifdewolf I wouldn't skip it for a first repair.
    Gabriel-Science -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - crwdns2934203:0crwdne2934203:0
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - crwdns2934203:0crwdne2934203:0
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - crwdns2934203:0crwdne2934203:0
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - crwdns2934203:0crwdne2934203:0
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - crwdns2934203:0crwdne2934203:0
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - crwdns2934203:0crwdne2934203:0
    I don't have a pick, but how much better are these picks than an old credit card for opening an iPhone 13 mini?
    mike eng - crwdns2934203:0crwdne2934203:0
    The pick in my iFixIt kit was packed with the battery, not with the rest of the toolkit.
    Tony Houlihan - crwdns2934203:0crwdne2934203:0
  4. iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Remove the pentalobe screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
  5. iPhone 15 Pro Front Camera Assembly Replacement, Heat the bottom edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Pro Front Camera Assembly Replacement, Screen information: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    触点被弄断了 怎么办??
    Chris008 - crwdns2934203:0crwdne2934203:0
  8. iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Separate the bottom edge adhesive: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Pro Front Camera Assembly Replacement, Heat the right edge: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Position the opening pick: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Release the right clip: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  12. iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Separate the right edge adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Pro Front Camera Assembly Replacement, Heat the top edge: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Separate the top edge adhesive: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  15. iPhone 15 Pro Front Camera Assembly Replacement, Heat the left edge: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the left edge of the screen until it's hot to the touch.
  16. iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Separate the left edge adhesive: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  17. iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Prop up the screen: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access its cables without straining them.
  18. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the logic board cover: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
    • Four 1.6 mm‑long screws
    • Two 1.3 mm‑long screws
  19. iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Remove the logic board cover: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
    • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
  20. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  21. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the screen: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
  22. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the ambient light sensor: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
    • Lift the cable to disconnect it.
  23. iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Remove the screen: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen.
    • During reassembly, follow this guide to apply new adhesive and install your screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  24. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the rear cameras: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the three rear camera press connectors from the top right of the logic board.
    • The third connector is hidden beneath the top one—lift the top cable slightly to reveal the third connector.
  25. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the rear cameras: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the three screws securing the rear cameras:
    • One 3.8 mm‑long screw
    • One 3.2 mm‑long screw
    • One 2.8 mm‑long screw
  26. iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Remove the rear cameras: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to touch or smudge the camera lenses during this step.
    • Insert the point of a spudger between the top right corner of the rear cameras and frame.
    • Pry up until you can grab the rear cameras with your fingers.
    • Remove the rear cameras.
  27. iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Unfasten the earpiece speaker: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Standoff Screwdriver for iPhones
    $5.49
    • Use a Phillips #000 screwdriver to remove the 2 mm‑long screw securing the top of the earpiece speaker.
    • Use a standoff screwdriver to remove the remaining screw securing the bottom left corner of the earpiece speaker.
    • If you don't have a standoff screwdriver, you can use a thin flathead one instead. Apply constant, downward pressure to avoid damaging the shallow notches in the screw head.
  28. iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Remove the earpiece speaker: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the earpiece speaker.
    • During reassembly, make sure the gasket on the top right corner of the speaker lines up with its recess in the frame.
  29. iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Move the microphone cable: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The microphone cable covers the front sensors press connector.
    • Use the tip of an opening pick to disconnect the microphone press connector from the top left corner of the logic board.
    • Lift the cable out of the way so you can access the two press connectors on the logic board's top edge.
  30. iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Pro Front Camera Assembly Replacement, Disconnect the front camera assembly: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the front sensors and front camera press connectors from the top edge of the logic board.
  31. iPhone 15 Pro Front Camera Assembly Replacement, Remove the front camera assembly: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front camera assembly.
    • Be careful not to touch or smudge the camera or sensor lenses.
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
116,132 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2935297:020,508crwdne2935297:0
with ios 18, can you use the repair assistant tool to fix faceid? if not is there some sort of device i can use to pair the logic board with the faceid? if not, is my best bet for the front camera and faceid to work again just sending it in to apple for repairs?
Jesse Beckmann - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 61
crwdns2936753:030crwdne2936753:0 312
crwdns2942667:0crwdne2942667:0 4,533
