Use this guide to replace the Taptic Engine in your iPhone 15 Plus.
If the vibrations coming from your phone feel rattly or are intermittent, you might need to replace the Taptic Engine.
You'll need replacement back glass adhesive to complete this repair.
Unplug any cables from your phone.
Hold the power and either volume buttons and slide to power off your phone.
If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
Apply a suction handle to the bottom edge of the back glass.
Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
Insert the tip of an opening pick into the gap.
There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
Slide your pick back and forth along the bottom edge to separate the adhesive.
Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Heat the right edge of the back glass until it's hot to the touch.
Rotate your pick around the bottom right corner and slide it halfway up the right edge or until you feel a hard stop at a clip securing the back glass.
Leave this pick inserted to prevent the adhesive from resealing.
Heat the left edge of the back glass until it's hot to the touch.
Insert a second opening pick at the bottom edge.
Rotate the second pick around the bottom left corner.
Slide this pick up to the top left corner to separate the adhesive.
Heat the top edge of the back glass until it's hot to the touch.
Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
Leave this pick in place to prevent the adhesive from resealing.
Heat the top right corner of the back glass until it's hot to the touch.
Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
Gently swing open the back glass to the right of the phone.
Rest the back glass against a raised surface so it doesn't strain the cable.
crwdns2935267:0crwdne2935267:0FixMat$36.95
Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
Remove the cover.
Hold the back glass upright with one hand and rotate the bottom edge to the left to reveal the battery press connector just below the volume buttons.
Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
Remove the cover.
Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
Remove the back glass.
This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
Use this guide to reapply adhesive and install your back glass.
Use your Phillips #000 driver to remove the four screws securing the Taptic Engine and its connector cover:
One 1.4 mm‑long screw
One 1.9 mm‑long screw (larger screw head)
One 1.9 mm‑long screw (smaller screw head)
One 2.1 mm‑long screw
Use tweezers to remove the Taptic Engine connector cover.
Use the point of your spudger to pry up and disconnect the Taptic Engine press connector.
crwdns2935267:0crwdne2935267:0Standoff Screwdriver for iPhones$5.49
Use a standoff driver to remove the 3.3 mm screw securing the top left of the Taptic Engine.
Use tweezers or your fingers to remove the Taptic Engine.
To reassemble your phone, follow these instructions in reverse order.
