iPhone 15 Logic Board Replacement
  1. iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Logic Board Replacement, Tape over any cracks: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Tape over any cracks: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Logic Board Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Mark your opening picks: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 15 Logic Board Replacement, Remove the pentalobe screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the pentalobe screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Logic Board Replacement, Heat the bottom edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Logic Board Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Logic Board Replacement, Screen information: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
  8. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Logic Board Replacement, Heat the right edge: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the right edge of the screen until it's hot to the touch.
  10. iPhone 15 Logic Board Replacement, Position the opening pick: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Position the opening pick: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Position the opening pick: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  11. iPhone 15 Logic Board Replacement, Release the right clip: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Release the right clip: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Release the right clip: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the pick with one hand and twist it to increase the gap between the screen and the frame and release the right clip.
    • Insert a second opening pick to the right of the first one.
  12. iPhone 15 Logic Board Replacement, Separate the right edge adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the right edge adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the right edge adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  13. iPhone 15 Logic Board Replacement, Heat the top edge: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the top edge of the screen until it's hot to the touch.
  14. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Insert a third opening pick in the top right corner, just above the previous pick.
    • Slide your pick around the top right corner and along the top edge until you feel it stop against the top left screen clip.
  15. iPhone 15 Logic Board Replacement, Release the top edge clips: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Release the top edge clips: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Release the top edge clips: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate your pick so its flat edge is under the screen.
    • Twist your pick to release the top left screen clip.
    • Slide your pick to the top left corner.
  16. iPhone 15 Logic Board Replacement, Heat the left edge: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the left edge of the screen until it's hot to the touch.
  17. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
  18. iPhone 15 Logic Board Replacement, Swing open the screen: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Swing open the screen: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Swing open the screen: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently swing open the screen over the left edge of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
  19. iPhone 15 Logic Board Replacement, Unfasten the front sensor connector cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a tri-point Y000 driver to remove the 0.9 mm-long screw securing the front sensor connector cover.
  20. iPhone 15 Logic Board Replacement, Remove the cover: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the cover: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the cover: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to lift the cover to a 90-degree angle.
    • Unhook the cover from its slot in the logic board.
    • Remove the cover.
    • During reassembly, insert the cover at a 90-degree angle to re-engage the hook before laying it flat against the press connector.
  21. iPhone 15 Logic Board Replacement, Disconnect the front sensor: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the front sensor: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
  22. iPhone 15 Logic Board Replacement, Unfasten the screen connector cover: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
  23. iPhone 15 Logic Board Replacement, Remove the cover: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the cover: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
    • Remove the cover.
  24. iPhone 15 Logic Board Replacement, Disconnect the screen: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the screen: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the screen press connector.
  25. iPhone 15 Logic Board Replacement, Remove the screen: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen.
    • During reassembly, use this guide to reapply adhesive and install your new screen.
    • Be careful not to damage any of the spring contacts as you clean the frame.
  26. iPhone 15 Logic Board Replacement, Flip your iPhone over: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    • Flip your phone over and lay it on a soft surface, such as a microfiber cloth, to protect its internals as you work.
  27. iPhone 15 Logic Board Replacement, Heat the bottom edge: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
  28. iPhone 15 Logic Board Replacement, Insert an opening pick: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Insert an opening pick: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Insert an opening pick: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
  29. iPhone 15 Logic Board Replacement, Back glass information: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  30. iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the bottom edge adhesive: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
  31. iPhone 15 Logic Board Replacement, Heat the right edge: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the right edge of the back glass until it's hot to the touch.
  32. iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the bottom right corner adhesive: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  33. iPhone 15 Logic Board Replacement, Heat the left edge: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the left edge of the back glass until it's hot to the touch.
  34. iPhone 15 Logic Board Replacement, Separate the left edge adhesive: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the left edge adhesive: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  35. iPhone 15 Logic Board Replacement, Heat the top edge: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the top edge of the back glass until it's hot to the touch.
  36. iPhone 15 Logic Board Replacement, Separate the top edge adhesive: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the top edge adhesive: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the top edge adhesive: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  37. iPhone 15 Logic Board Replacement, Heat the top right corner: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the top right corner of the back glass until it's hot to the touch.
  38. iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the top right corner adhesive: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  39. iPhone 15 Logic Board Replacement, Swing open the back glass: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Swing open the back glass: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Swing open the back glass: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  40. iPhone 15 Logic Board Replacement, Unfasten the lower connector cover: crwdns2935265:040crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  41. iPhone 15 Logic Board Replacement, Remove the lower connector cover: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the lower connector cover: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the lower connector cover: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
    • During reassembly, latch the top edge of the cover onto its slot on the logic board before securing it with its screw.
  42. iPhone 15 Logic Board Replacement, Disconnect the battery: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the battery: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the battery: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
    • A plus and minus sign is printed on the head of this connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  43. iPhone 15 Logic Board Replacement, Unfasten the middle connector cover: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Unfasten the middle connector cover: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
  44. iPhone 15 Logic Board Replacement, Remove the cover: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the cover: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the cover: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
    • During reassembly, place the cover so its tab is just behind the clip on the logic board. Press down with one finger and slide the cover forward to engage the clip.
  45. iPhone 15 Logic Board Replacement, Disconnect the wireless charging coil: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the wireless charging coil: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
  46. iPhone 15 Logic Board Replacement, Remove the back glass: crwdns2935265:046crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back glass.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  47. iPhone 15 Logic Board Replacement, Remove the upper connector cover: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the upper connector cover: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the upper connector cover: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the upper connector cover.
    • Remove the cover.
  48. iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the front camera and sensors: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the antenna, front sensors, and front camera press connectors (three connectors in total).
  49. iPhone 15 Logic Board Replacement, Remove the front camera and sensors: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the front camera and sensors: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to pull the front camera and sensors out of their recess in the frame and remove them.
  50. iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: crwdns2935265:050crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the earpiece speaker: crwdns2935265:050crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the earpiece speaker press connector.
  51. iPhone 15 Logic Board Replacement, Unfasten the earpiece speaker: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 driver to remove the five screws securing the earpiece speaker:
    • Two 1.1 mm‑long screws
    • Three 1.6 mm‑long screws
  52. iPhone 15 Logic Board Replacement, Remove the earpiece speaker: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the earpiece speaker: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the earpiece speaker: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers or your fingers to lift and pull the earpiece speaker away from the top of the phone to free the gasket from the frame.
    • Remove the earpiece speaker.
  53. iPhone 15 Logic Board Replacement, Separate the battery cable: crwdns2935265:053crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the battery cable: crwdns2935265:053crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Separate the battery cable: crwdns2935265:053crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Light adhesive secures the battery cable to the logic board.
    • Slide an opening pick under the battery cable to separate it from the logic board.
    • Be careful not to crease the cable or dent the battery with your tool.
  54. iPhone 15 Logic Board Replacement, Disconnect the volume buttons: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the volume buttons: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of an opening pick to pry up and disconnect the volume buttons press connector.
  55. iPhone 15 Logic Board Replacement, Disconnect the power button: crwdns2935265:055crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the power button: crwdns2935265:055crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the power button press connector.
  56. iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: crwdns2935265:056crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: crwdns2935265:056crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the rear cameras and antenna: crwdns2935265:056crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the rear cameras and antenna press connectors (three connectors in total).
  57. iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: crwdns2935265:057crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: crwdns2935265:057crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Disconnect the eSIM, Taptic Engine, and charging port: crwdns2935265:057crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the eSIM, Taptic Engine, and charging port press connectors (three connectors in total).
  58. iPhone 15 Logic Board Replacement, Unfasten the logic board: crwdns2935265:058crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPhone 15 Logic Board Replacement, Unfasten the logic board: crwdns2935265:058crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Standoff Screwdriver for iPhones
    $5.49
    • Use your standoff driver to remove the five standoff screws securing the logic board:
    • One 2.9 mm screw
    • One 3.9 mm screw
    • Three 3.5 mm screws
    • If you don't have a standoff driver, you may use a thin flathead driver—but be careful not to strip the shallow notches in the screw heads.
  59. iPhone 15 Logic Board Replacement, Remove the logic board: crwdns2935265:059crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the logic board: crwdns2935265:059crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPhone 15 Logic Board Replacement, Remove the logic board: crwdns2935265:059crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the top edge of the logic board and gently pull it out from under the cables.
    • Remove the logic board.
    • During reassembly, make sure all nine press connectors (including the small volume buttons cable) are above the logic board.
To reassemble your phone, follow these instructions in reverse order.
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
91.413 crwdns2915208:0crwdne2915208:0
crwdns2935297:0459crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:014.939crwdne2935297:0
crwdns2936751:024crwdne2936751:0 41
crwdns2936753:07crwdne2936753:0 275
crwdns2936753:030crwdne2936753:0 1,281
crwdns2942667:0crwdne2942667:0 12,895
