iMac Intel 21.5" EMC 2308 PRAM Battery Replacement
  1. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Access Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Access Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
    In order for the logic board to come out cleanly, one should remove the RAM at the end of this step.
    kevmacmills - crwdns2934203:0crwdne2934203:0
    Definitely! The author should make this as a step in the description (because not everyone reads Comments)
    finnik2d - crwdns2934203:0crwdne2934203:0
    Just did this procedure and the RAM must absolutely come out for the logic board to come free later.
    matt - crwdns2934203:0crwdne2934203:0
  2. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Glass Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Glass Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • Before beginning, unplug your iMac and lay it on a soft surface as shown.
    • Stick a suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel. While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle.
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
    Very easy to lift the glass out. Don't jerk too hard.
    kctipton - crwdns2934203:0crwdne2934203:0
    Another comment on DATA & LCD Temp. Sensor cables: I had to remove the vertical sync, and the backlight cable, however, if you have an assistant or/can carefully rotate the screen clockwise/and then have it held up about 5" to 6" at a slight angle, you do not need to remove LCD data cable or LCD thermal cable, however - IMPORTANT: you must have a second pair of hands/or way to securely prop up the LCD. Also, don't rotate too much, since then you will pull out LCD data cable, and it renders the whole exercise moot, or can damage the cable or connector.
    MaximBorzov - crwdns2934203:0crwdne2934203:0
    You don't need suction cups. The screen, held by magnets, can simply be pried off using a very thin blade such as a screw driver and fingers.
    Deepsurvival - crwdns2934203:0crwdne2934203:0
    That's a bad idea. using a metal tool to pry off glass is likely to end with an expensive broken front glass.
    Suction cups are common. Find a couple and do it the safe way. I use some cheap ones that came with iPhone repair kit.
    max damage -
    No need for suction cups, I just stuck my nails (short like guys usually have) between the top part of the screen and body, and it came off easily. I've never done it before, so it seems to be very easy.
    Nikolas Lintulaakso - crwdns2934203:0crwdne2934203:0
    Just completed the replacement of the optical drive with an SSD using an OWC Data Doubler kit. Attempted to remove the optical drive without disconnecting any cables but found it a bit fiddly to orient the screen for good access. I bit the bullet and disconnected them and found the process less daunting than I imagined. Reconnecting them was similarly straightforward if you're careful.
    Tip: you can skip the step for removing the optical drive thermal sensor connector from the motherboard. Still need to remove the sensor from the optical drive but you can leave that hanging and reattach it to the SSD later.
    osienna - crwdns2934203:0crwdne2934203:0
    I use Garmin GPS suction cup. Work very well
    jc3Dcx - crwdns2934203:0crwdne2934203:0
    I’ve just successfully installed a 1TB SSD in place of my optical drive thanks to the information here- thank you to everyone who has contributed!
    3 comments- the procedure described here seems to vary between HD replacement and dual HD/optical drive replacement. This can be confusing at times.
    Expect there to be minor differences between the layout described and what you find when you open up your iMac. There are also, surprisingly, differences between the HD enclosure description, and the article provided by ifixit.
    I was able to replace the DVD/HD enclosure single-handedly without fully removing the LCD, or deconnecting any of the cables (steps 5-11). It’s a bit cramped, and fiddly, but I was not happy removing any of the cables despite watching videos, etc., since they all seemed to involve applying more force than I was comfortable with. A more detailed description of how to release them might have helped, but even here, there may be minor variations even within the 2389 model.
    Good luck!
    ivan birks - crwdns2934203:0crwdne2934203:0
    I did it several times with one suction cup at the end of a kitchen brush. Once with the blade of a swiss army knive, also ok. And i’m pretty sure it works with fingernails too
    Tai - crwdns2934203:0crwdne2934203:0
    Fingernails are all you need to free the glass from its magnetic hold. If you don’t have them, slip something thin and plastic, like a spudger, at a top corner.
    Max Powers - crwdns2934203:0crwdne2934203:0
    Minha dúvida é a seguinte: após o técnico trocar o HD do meu iMac de 21,5 polegadas, a câmera parou de funcionar. Seria por causa da troca do HD? Tem solução?
    Claudio - crwdns2934203:0crwdne2934203:0
    Creio que o cabo da camera não foi plugado ou deu mau contato… ou até danificado.
    glecyo@gmail.com
    glecyo medeiros -
    I can’t get my glass to budge. I’m replacing a cracked one and now it’s about to shatter.
    jamboxmitchell - crwdns2934203:0crwdne2934203:0
    I know that I'm replying really late but I advise to use clear tape over any cracks so the cracks don't get bigger
    Jace Holmes -
    Check for chips in the glass BEFORE you do this step. If there is a chip when you pull up with the suction cups you will wind up with a jagged mess. If you do have a chip I would advise covering the screen near the chip with clear tape of some kind before lifting out. Mine shattered right at the chip and the resulting glass dust cloud got all over. My solution was buying a new glass screen.
    BCam - crwdns2934203:0crwdne2934203:0
  3. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
    What's the best product to clean the face of the LCD?
    Steve Speirs - crwdns2934203:0crwdne2934203:0
    Microfiber Cloth
    Leonardo Fournier -
    Try your best not touch it in the first place
    Brian -
    Wearing Nitrile or regular surgical gloves helps prevent finger prints if you accidentally touch the glass.
    amiller770 - crwdns2934203:0crwdne2934203:0
    I use a Swiffer duster from above at the last moment before I let the magnets grab the glass cover. This has worked so well the last dozen or so times I’ve replaced a glass cover since I never have access to a “clean room” and don’t wear a “bunny suit”.
    Also, more dust will shed from your skin if you’ve just taken a shower, so I like to finish these repairs in the morning before a shower.
    gatortpk - crwdns2934203:0crwdne2934203:0
  4. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Display: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Display: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Display: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
    • The last two pictures are detail shots of each side of the display.
    On reassembly, it is REALLY HARD to align those screws, because of the field of the strong magnets that hold the glass cover on. I'm sure there's a trick to it, but I'd love to know what it is for future reference.
    Peter Shenkin - crwdns2934203:0crwdne2934203:0
    I used needlenose pliers and the T10 to align the screw into the hole. Otherwise the screw keeps jumping to the magnet. And patience with this NON-CAPTIVE screw design (c’mon Apple, even **I** came up with that, and I’m an idiot!)
    A short piece of small gauge vinyl tubing that fits tightly over the head of the T-10 driver leaving an 8th of an inch or so in which to insert the screw to engage the head will hold the screw long enough to keep it away from the magnet and get it going in the hole.
    Paul Boudreau - crwdns2934203:0crwdne2934203:0
    I use non magnetic SS curved tip tweezers together with a magnetized #10 torx bit both to remove and reinstall the screws. You can magnetize and demagnetize the bit using the strong magnets on the LCD frame. Don't worry too much during removal, you can recover the screw. But loath the moment you drop the last screw during reassembly. For that reason, reinstall the screws near the magnets and hardest to get to first.
    Michael Ben-Yehuda - crwdns2934203:0crwdne2934203:0
  5. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slightly lift the top edge of the display out of the outer case.
    • Do not lift it too much. There are several cables attaching the display to the logic board.
    When putting the display back I have resistance from the foam elements (on the top end where the iSight is) and have to press down really hard. Is that okay?
    gm.konsortium - crwdns2934203:0crwdne2934203:0
    Well, stupid me put the 3.5" to 2.5" cage the wrong side up. ;)
    Standing the imac upright on its stand really helps this step! Laying it falt makes getting under the panel a real hassle.
  6. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • The vertical sync ribbon cable has a ZIF style end, but the socket has no lock or retaining flap. Simply pull the cable away from its socket toward the optical drive side of the iMac to disconnect it from the LED driver board.
    The vertical sync cable was snug initially and now is loose. I checked and the cable is intact. Has anyone had experience with making it fit better?
    Rajan - crwdns2934203:0crwdne2934203:0
    Scotch tape on the upper side and sliding this in helped to secure the cable.
    Reassembly of this part was the closest I came to disaster on this project. I tried inserting the connector a few times without success, and when I looked it it the leads, which are fragile, were all mangled. I smoothed them out by hand as best I could and and reinserted, very carefully this time. The trick is that the tip of the connector should be pointed somewhat upwards when reconnecting.
    I was pretty sure that when I was done, I would reboot but have no display; but fortunately, everything worked.
    Hi, I still have a question. What is the "Job" of the vertical sync ribbon cable. Thanks
    Lutz Blum - crwdns2934203:0crwdne2934203:0
    So let’s say someone wanted to suck some of the dust off the back of the display before reassembly. Let’s just say that. Someone would likely suck this forsaken cable up into the vacuum tube then, wouldn’t they? They might. And if it were to oscillate in a rushing torrent of air, it might get munged? It might.
    Here’s how you overcome such a disaster:
    1) cut the end fresh, as close to the end as you can while cutting off any frayed end.
    2) abrade the end gently, repeatedly, along the connector wire axis. I used emory paper. Your goal is to expose the copper conductors in the last 1/4” of the fragile evil wire.
    3) Tape a small stiff cardstock to the back of the end of the connector. This is essential to press the connector wires into the connector.
    4) Gently insert, taking special caution to not peel the copper off of the connector.
    5) Tape that connector down deftly, without letting it move a millimeter and securing it for all time.
    sydnius - crwdns2934203:0crwdne2934203:0
    I just leave it connected. After disconnecting the other cables, there is enough slack to lay the display on its backside if you’re working on a flat surface.
    Duane Johnson - crwdns2934203:0crwdne2934203:0
    I have replaced the hdd in this model about 8-10 times - I have never had to disconnect any cables other than the sata and temp sensor cables on the hdd. I just prop the lcd up with an egg carton (or something about 3 inches high that is soft and light) and access the hdd that way. The only thing I ever have trouble with are is putting the LCD screws back in around the magnets - but I have pretty much perfected that with a sissor/ tweezer tool.
    Suzanne Levy - crwdns2934203:0crwdne2934203:0
    Could you put up some photos of this procedure - egg carton etc…
    Peter Barnett -
    The LCD screen is super soft on these since they rely on external glass for protection. Since LCD side will be facing down without disconnecting vsync, I'd lay it on a flat surface with soft fabric rather than putting the LCD on a rough surface like egg cartons.
    Howard -
    Any ideas where to replace this cable?
    Danny Shaw - crwdns2934203:0crwdne2934203:0
    I followed Suzanne’s comment and also did not disconnect this cable (vertical sync ribbon cable) to avoid damage. I pivoted the screen about 110 degrees after the other cables where detached. On a flat surface, this is easily done and the cable is not tight. Image of my angle if I can drop a link. and cable in this position not in tension.
    investments kkl - crwdns2934203:0crwdne2934203:0
    Where can I buy the replacement for this vertical sync replacement cable?
    Neil Gonsalves - crwdns2934203:0crwdne2934203:0
    Almost every vsync cable's 4 gold traces will be lifted after removal. Easy fix is to straighten them out, put some super/gorilla glue underneath. Clamp in a cloth pin for a little while and can be used again.
    Howard - crwdns2934203:0crwdne2934203:0
  7. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    • Disconnect the LED backlight power cable by depressing the locking mechanism while pulling the connector away from its socket (toward the bottom edge of the iMac).
    I found it easier to very slightly lift the front edge of the black connector with a small spudger, then gently pulling away towards the bottom of the iMac. Pressing felt a little crude and didn’t work for me.
    Anthony C Carnell - crwdns2934203:0crwdne2934203:0
  8. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be careful when disconnecting and reconnecting this cable, as it is easily damaged.
    in Step 7, my connector (new 21.5 iMac - Dec 2010) was not attached that way and just came of easily.
    erin - crwdns2934203:0crwdne2934203:0
    Aperte as duas exibição do conector do cabo de dados braços juntos para desbloqueá-lo de seu soquete na placa lógica.
    Darlan Perira da Silva - crwdns2934203:0crwdne2934203:0
    I accidently broke the data cable socket on step 7. Any advice on what i should do?
    Sam Tang - crwdns2934203:0crwdne2934203:0
    I feel pretty silly. I spent wayyyy too long trying to get these cables disconnected. Happy I found this guide; hopefully, I won't struggle with such simple things since you provide pretty good details! Thanks.
    J.w. - crwdns2934203:0crwdne2934203:0
    Pas beaucoup de place pour déconnecter ce cable ! En essayant d'ouvrir trop l'écran pour passer mes "grosses mains" j'ai cossé le connecteur : je suis dans le caca :-( (et pourtant j'en fait des démontages !) Alors ATTENTION !!!
    divers - crwdns2934203:0crwdne2934203:0
    Il vaut mieux déconnecter la partie du côté écran en premier (sous l'autocollant noir)
    Je suis d’accord. C’est plus facile. Merci mon ami
    Anthony C Carnell -
    Translation: It is better to disconnect the screen side first (under the black sticker)
    Michael Seiler -
    ALWAYS ALWAYS ALWAYS REMOVE THIS CABLE!!! Even if you are "only in there for a minute" tearing the connector off the board is EXTREMELY easy.
    DistroHopper39B - crwdns2934203:0crwdne2934203:0
  9. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
    Is there a way to test the power supply to see if it's dead?
    professorminh - crwdns2934203:0crwdne2934203:0
    Achtung! Dieser Stecker kann sehr fest sitzen, hier hilft ein guter Fingernagel um den Stecker abwechselnd rechts und links zu Hebeln
    bluesoundsmusic - crwdns2934203:0crwdne2934203:0
    English translation of bluesoundsmusic comment: “Caution! This plug can be very tight, here a good fingernail helps to lever the plug alternately right and left”
    investments kkl -
  10. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
  11. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Power Supply: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following four screws securing the power supply to the outer case:
    • Two 22.2 mm fine-thread T10 Torx
    • One 25 mm coarse-thread T10 Torx
    • One 9 mm coarse-thread T10 Torx
    • The next few steps bring your hands close to the exposed face of the power supply. To avoid a high voltage shock from the many large capacitors attached to the board, do not touch the face of the power supply.
    Watch orientation of iMac in relation to this picture: if the base is AWAY from you, the screw positions are reversed in this picture. Also use the black power cable for position reference.
    fuuuuuuuck shiiiittt dammn that mf hurt like !&&* fucckken shocker here guys this macpos WILL KILL your ass be &&^&^$^ aware
    Jeff Robison - crwdns2934203:0crwdne2934203:0
    I installed the power supply and nothing happened when I pushed the power on button, has this happened to someone else or should I also replace the power cable?
    Jose Valdez Jr. - crwdns2934203:0crwdne2934203:0
    Okay, is the side with the soldier joints or the side with the capaciters the “face?”
    Also, you need to destroy that little hook that keeps the big connector on unless you have three strong little hands. Don’t worry, it’s not going to fall off, you can still cut yourself trying to wiggle that thing off. Especially when you are holding the board by the edges to avoid the “face.”
    Gladephone - crwdns2934203:0crwdne2934203:0
    I've taken out the logic board on a late 2009 iMac twice in the last two years, and in neither case did I need to remove the power supply. You can do the rest of the steps without removing the power supply, so I would suggest just making things simpler and leaving it in.
    Phil McInnis - crwdns2934203:0crwdne2934203:0
  12. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the power supply out of the outer case and rotate it to expose the cable lock as shown, minding the DC-Out cable still attaching it to the iMac.
    • Disconnect the DC-In cable by depressing the locking mechanism on the connector while you pull the connector away from its socket on the power supply.
    • Once the locking mechanism has cleared the socket, pull the DC-In connector away from the power supply.
    I found my DC-In cable VERY difficult to detach. I depressed the locking mechanism, but still needed to use my iFixit Jimmy to carefully, gently, slowly work the cable connector (male) loose and away from the power supply (female).
    Bryan Jensen - crwdns2934203:0crwdne2934203:0
  13. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the AC-In cable by depressing the locking mechanism while pulling the connector away from its socket.
    • Remove the power supply from the outer case.
    This was not easy to disconnect with one hand holding the power supply (being careful while holding just to be cautious against any possible electrical discharge). Note that the connector is not on power supply side but on AC-In cable side. Couldn't quite see well enough from photo shown, but hold on the AC-In side of cable connector (depressing the locking mechanism of the male side) and pull away from the Power Supply (female side) cable.
    i’ve gotten away with not removing the PSU at all when removing the motherboard. havent had any issues
    Akeem Scrubb - crwdns2934203:0crwdne2934203:0
  14. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Optical Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
    While you’re here, disconnect that SD reader cable and don’t forget to plug it back in on your way back through: it’s not mentioned elsewhere in this guide.
    Corvallis Computer - crwdns2934203:0crwdne2934203:0
    For me this cable was by the hard drive with a grey and a black wire labeled “ODD_TEMP”
    Bryan Remely - crwdns2934203:0crwdne2934203:0
  15. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 9 mm T10 Torx screws securing the optical drive to the outer case.
  16. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the inner edge of the optical drive and maneuver its connector past the frame attached to the logic board.
    • Carefully pull the optical drive off its mounting pins on the edge of the outer case to gain clearance for disconnecting the optical drive cable.
  17. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to help disconnect the optical drive cable.
    Be sure this cable doesn’t get stuck under the logic board during reassembly. Mine was under it, I was able to get it out but connecting it to the SuperDrive required a bit of force because my cable is so short.
    Javier Indesteege - crwdns2934203:0crwdne2934203:0
  18. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Optical Drive Fan: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 13 mm T10 Torx screw securing the optical drive fan to the outer case.
  19. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the optical drive off the pins attached to the outer case.
    Should read optical drive “fan” off the pins……
    Gordon Farley - crwdns2934203:0crwdne2934203:0
  20. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the optical drive fan connector away from its socket on the logic board.
    • Remove the optical drive fan from the iMac.
  21. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, Logic Board: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the left and right speaker connectors toward the right side of the iMac to disconnect them from the logic board.
    Use a RED marker to tag the RIGHT speaker cable since both speaker cables look identical
    I added a small piece of tape to one of the cables and took a picture to remember where each of them go
    I used a paint pen to draw a line across one of the sockets and its connector before removal
    Simon Pusey - crwdns2934203:0crwdne2934203:0
  22. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the audio port cable by pulling its connector toward the right side of the iMac.
    Use your fingernails to wiggle out the black tabs at the connector; DON'T use the cable itself to remove from the logic board
  23. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the AirPort cable by lifting its connector off the socket on the logic board.
    • Lift the connector perpendicular to the face of the logic board.
    Lift this one directly up towards your cieling. I almost snagged this one off like it was the other cables.
    Jonathan Diress - crwdns2934203:0crwdne2934203:0
  24. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the following cables by pulling their connectors toward the top edge of the iMac:
    • Camera cable
    • Hard drive thermal sensor
    • Hard drive fan
    • Microphone
    • Disconnect the following cables by pulling their connectors toward the right edge of the iMac:
    • Ambient temperature sensor
    • Bluetooth cable
    You might need a spudger to pull the wires out in order to pull ambient temperature sensor and Bluetooth cable out. For mine, the cables were tucked in so it was really difficult just pull out the wires.
    The Bluetooth cable was refusing to disconnect. The cable goes under the logic board pulling the connector down, especially on my iMac it was very tight. What ultimately helped was sliding the flat end of the iFixit Halberd Spudger under the connector, lifting it slightly up. Then I was able to pull it out of the socket.
  25. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the CPU fan and power button by pulling their connectors toward the left edge of the iMac.
    Use tape to hold the connectors out of the way.
  26. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If present, remove the piece of tape covering the IR sensor connector.
    • Disconnect the IR sensor by pulling its connector toward the top edge of the iMac.
  27. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to lift IR sensor assembly straight up out of the outer case.
  28. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following six screws securing the logic board to the outer case:
    • Three 25 mm T10 Torx
    • Two 21.5 mm T10 Torx
    • One 7 mm T10 Torx
    These photos do not show this iMac's optional configuration that contains a discreet GPU. If a GPU card is present there is another Torx screw that must be removed that holds an additional heat sink to the upper right corner of the enclosure. Note that in this configuration, the optical drive fan has a different configuration with a plastic separator that points towards the top of the iMac. This looks to serve as channel for airflow and is noteworthy because it makes the optical drive's SATA connector much more difficult to remove and quite difficult (for me anyway) to reassemble as it is a very tight fit!
    I made it to this step, then carefully removed dust from the back part, not touching any components, then used compressed air to get dust out since getting the whole logic board was a challenge, assembled and when I turn it on it loads normally, white screen with the logo, but then the screen goes black, and then the fans start running at the actual speed (I used SMC fan control) I had before I unplugged it to clean it, what could have happened? thank you =(
    Ricardo - crwdns2934203:0crwdne2934203:0
    I had the additional GPU card, as mentioned by kevmacmills above, and needed to remove two Torx screws, one short one at the plastic separator, and one 7mm approx at the heatsink in the top right of the enclosure.
    Jurgen - crwdns2934203:0crwdne2934203:0
  29. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic ducts from the side of the LED driver board and the hard drive by pulling them away from the outer case.
  30. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the aluminum tape attaching the GPU heat sink to the outer case.
    • It is not necessary to completely remove the aluminum tape from the GPU heat sink.
    OMG!
    I cannot believe it!
    Only by attaching one side of the golden GPU sionk with aluminum tape on the case, is it possible to well handle the thermal dissipation from the GPU
    bruce ayng - crwdns2934203:0crwdne2934203:0
    Was anyone able to install the Q9550S cpu?
    jimmakosp - crwdns2934203:0crwdne2934203:0
    Whoops, definitely tears easily. I tore it at two spots. At reassembly I was able to get it to adhere to the case nonetheless by rubbing along the aluminium tape using my finger nail.
  31. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In the following steps, you will maneuver the logic board out from the outer case. In doing so, be aware of the many cables still attaching the logic board to the outer case.
    • Be sure the logic board clears the plastic lower optical drive fan mounting pin before lifting it up, as it is easily snapped off.
    Be sure you have REMOVED YOUR RAM MEMORY before trying to wiggle out the logic board!
    Thank you! I don’t understand why it’s not mentioned in the guide
    Javier Indesteege -
  32. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the logic board slightly away from the outer case.
    • While holding the board away from the outer case, rotate the board back and forth while lifting up to release it from the outer case.
    If you're having trouble getting the logic board to come free, you probably need to remove the RAM. That was keeping it from coming free in my case.
    My logic board has an extra metal attachment extending to fan grills, which this photo does not show. Help needed. Is there any way I can up load a photo of my logic board?
    winner43 - crwdns2934203:0crwdne2934203:0
    During reassembly make sure all I/O connectors are above the logic board and not under it! I also connected three USB drives to align the logic board.
  33. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the lower edge of the board is free from the outer case, rotate the logic board toward yourself to expose its rear face.
    • The following connector has a tendency to stick in its socket. If so, insert a metal spudger into the gap between the connecter and its socket. Twist the spudger to separate the two components.
    • Carefully pull the optical drive connector away from its socket on the logic board.
    • Pull the connector perpendicular to the face of the logic board.
  34. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the DC-In cable from the logic board by simultaneously depressing the locking lever on the connector while pulling it away from its socket.
    • Remove the logic board from the outer case.
    • During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
  35. iMac Intel 21.5" EMC 2308 PRAM Battery Replacement, PRAM Battery: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tip of a spudger to pry the PRAM battery out of its socket on the logic board.
    This can be used as a troubleshooting step if you have a No Boot/No Power symptom.
    Chris Perra - crwdns2934203:0crwdne2934203:0
crwdns2935229:031crwdne2935229:0
crwdns2947412:014crwdne2947412:0
OK, so not going to do that ever.
cyadmark - crwdns2934203:0crwdne2934203:0
Dank dieser Anleitung hat der Wechsel der Pufferbatterie problemlos funktioniert.
Schaut man selbst in das innere eines iMac, wird einem erst richtig bewußt welche Genialität hinter dieser Erfindung steckt.
Danke Steve
HansJoachim Herker - crwdns2934203:0crwdne2934203:0
Stupid design. A battery must be accessible from the outside or should last forever!
lotteherzog - crwdns2934203:0crwdne2934203:0
It was easier than I thougth, my iMac was acting weird with a dead Pram battery, great guide!!...thanks a lot iFixit!
Juan Gonzalez - crwdns2934203:0crwdne2934203:0
Es wäre doch kein Problem gewesen, in die Rückwand des iMacs eine kleine Klappe für diesen Wechsel einzubauen?!
Ich bin seit 1982 Appleianer, aber solche Sachen finde ich echt einer solchen Technik nicht würdig!
GeorgG - crwdns2934203:0crwdne2934203:0
Thank you Andrew Bookholt this step by step helped me a lot ..
I thought I would not be able to run, but I did, it gave me a lot of work but everything worked very well in the end!
Joao - crwdns2934203:0crwdne2934203:0
Dang! I guess it won’t be a quick fix. Really stupid design, unless of course they created a battery that’ll last forever. But, great guide - thank you. I contacted Apple for help, and they wouldn’t even confirm there’s a battery in the machine. The only way they would answer that question, would have been for me to bring the machine into their store and let them do the repair. They haven’t made enough money on the sale of their products that they feel the need to leverage their customers into paying for service and repairs?! Really, Apple…? Tsk, tsk…
Phil - crwdns2934203:0crwdne2934203:0
Andrew, your procedure worked perfectly, thank you very much !!
Took about 6 hours, including two redo’s, because of my own mistakes.
JohnW Strauss - crwdns2934203:0crwdne2934203:0
btw, also changed to an SSD HD in the same procedure :-))
Now my late 2009 iMac has (at least) another 5 years lease of life, saving me a bunch!
Moin, habe alle sehr gut beschriebenen Schritte ausgeführt und die Batterie gewechselt. Leider hat es aber das Problem nicht gelöst. Mein iMac startet nicht jedesmal (stochastisch), wobei die Festplatte beim Start einschläft und die Maschine nicht hochfährt. Der Bildschirm zeigt dann einen kleinen Kreis mit einem waagerechten Strich drin. Darüber hinaus habe ich bemerkt, dass, wenn der Einschaltsound nicht deutlich laut ist, auch die Festplatte letztendlich nicht startet.
Bei Nicht-Start drücke ich die Tasten-Kombi zum Rücksitzen des PRAM, was auch nicht immer zum Erfolg führt.
Hat hier jemand noch eine Idee?
beste Grüße
Hardee
Erhard Behnke - crwdns2934203:0crwdne2934203:0
English: Moin, Did all the very well described steps and changed the battery. Unfortunately, it didn't solve the problem. My iMac does not start every time (stochastically), and the hard drive falls asleep at startup and the machine does not start up. The screen then shows a small circle with a horizontal line in it. In addition, I noticed that if the switch-on sound is not clearly loud, the hard drive will not start either.
When I don't start, I press the button combination to sit the PRAM, which doesn't always lead to success.
Does anyone have an idea here?
best regards
Hardee
Dan -
Wie wäre es, wenn Sie Ihre Frage hier Answers stellen würden?
How about placing your question here Answers were its more visible.
Dan -
The iMac uses a BR2032 battery, however, the parts list shows CR2032. I understand that the BR2032 has a greater acceptable temperature range (can stand the heat better) and a longer life. It's also more expensive and harder to find. Any opinions or better yet informed data on how well the CR2032 holds up versus the BR2032 in iMacs?
There is no perfect answer, if the system only needs to live a few months or even a year or two the CR battery is fine. If you are expecting a much longer life then I would go with the BR. There really is not enough difference from an environmental sense between them as the temp range your system runs at won’t get that hot.
Dan -
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 42,072
