Hp Pavilion dv6-2155dx USB Port Replacement
crwdns2936025:08crwdne2936025:0 —
Disconnect the power connector cable by using the point of the plastic spudger. continue to slide the plastic part until it is completely removed or you are able to grab the plastic with your fingers.
It is not advised to pull the cable bundle to remove this. By doing that you can damage the small wires that are connected.
