Zipper Pull Replacement
crwdns2936621:0crwdne2936621:0
Zipper pull replacement overview.
  1. Zipper Pull Replacement, Locate the zipper tab: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zipper Pull Replacement, Locate the zipper tab: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zipper Pull Replacement, Locate the zipper tab: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This tutorial demonstrates how to insert a paracord pull with a rubber end, a common type of zipper pull on Patagonia products. These pulls come in a large size for main zippers and a small size for pockets (reference image #2).
    • If you need to remove a damaged zipper pull, skip to Step 6.
    • Locate the tab of the zipper slider. The tab has two holes, one where the tab is attached to the slider body and one at the end of the tab.
  2. Zipper Pull Replacement, Insert the paracord end: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zipper Pull Replacement, Insert the paracord end: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the paracord end of the pull and slide it into the tab hole that's closer to the slider.
    • It doesn't matter whether it's inserted from the top or bottom.
    • Pull the paracord through the tab hole.
    • Use pliers to help pinch the paracord and aid in this step, especially if the tab hole is small.
  3. Zipper Pull Replacement, Thread the pull through the second hole: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zipper Pull Replacement, Thread the pull through the second hole: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the paracord end of the pull and thread it through the other hole on the slider tab, the one furthest from the slider body.
    • Now there will be a paracord loop emerging from this tab hole (reference red arrow, image #2).
  4. Zipper Pull Replacement, Loop the rubber end: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zipper Pull Replacement, Loop the rubber end: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the rubber end of the paracord pull through the loop emerging from the slider tab.
  5. Zipper Pull Replacement, Tighten the pull: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zipper Pull Replacement, Tighten the pull: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the slider, pull the rubber end of the zipper pull to tighten it. The zipper pull is now inserted and should lay flat on the slider tab.
    • To take off a damaged zipper pull, do these same steps in reverse.
    • Pliers can be helpful in getting into the small space and loosening the tension of the pull.
    • Discard the damaged pull responsibly.
crwdns2935229:05crwdne2935229:0
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
89,977 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2935297:019,857crwdne2935297:0
Awesome! Thanks for the training!
Kathleen Hutton - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 331
crwdns2942667:0crwdne2942667:0 27,231
