Zipper Pull Replacement
crwdns2936621:0crwdne2936621:0
Zipper pull replacement overview.
  1. Zipper Pull Replacement, Locate the zipper tab: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Zipper Pull Replacement, Locate the zipper tab: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Zipper Pull Replacement, Locate the zipper tab: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This tutorial demonstrates how to insert a paracord pull with a rubber end, a common type of zipper pull on Patagonia products. These pulls come in a large size for main zippers and a small size for pockets (reference image #2).
    • If you need to remove a damaged zipper pull, skip to Step 6.
    • Locate the zipper slider that is missing a pull. The slider has a tab with two holes, one where the tab is attached to the slider body and one at the end of the tab.
  2. Zipper Pull Replacement, Insert the paracord end: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zipper Pull Replacement, Insert the paracord end: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the paracord end of the pull and slide it into the tab hole that's closer to the slider.
    • It doesn't matter whether it's inserted from the top or bottom.
    • Pull the paracord through the tab hole.
    • Use pliers to help pinch the paracord and aid in this step, especially if the tab hole is small.
  3. Zipper Pull Replacement, Thread the pull through the second hole: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zipper Pull Replacement, Thread the pull through the second hole: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the paracord end of the pull and thread it through the other hole on the slider tab, the one furthest from the slider body.
    • Now there will be a paracord loop emerging from this tab hole (reference red arrow, image #2).
  4. Zipper Pull Replacement, Loop the rubber end: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zipper Pull Replacement, Loop the rubber end: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Thread the rubber end of the paracord pull through the loop emerging from the slider tab.
  5. Zipper Pull Replacement, Tighten the pull: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Zipper Pull Replacement, Tighten the pull: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the slider, pull the rubber end of the zipper pull to tighten it. The zipper pull is now inserted and should lay flat on the slider tab.
    • To take off a damaged zipper pull, do these same steps in reverse.
    • Pliers can be helpful in getting into the small space and loosening the tension of the pull.
    • Discard the damaged pull responsibly.
crwdns2935229:05crwdne2935229:0
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
90.451 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:023.648crwdne2935297:0
Awesome! Thanks for the training!
Kathleen Hutton - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 41
crwdns2936753:07crwdne2936753:0 238
crwdns2936753:030crwdne2936753:0 1,050
crwdns2942667:0crwdne2942667:0 31,205
