Yuneec Typhoon H Spring Clip Replacement
  1. Yuneec Typhoon H Spring Clip  Replacement, Spring Clip: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Yuneec Typhoon H Spring Clip  Replacement, Spring Clip: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Yuneec Typhoon H Spring Clip  Replacement, Spring Clip: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a JIS #00 screwdriver, unscrew the 3mm oval screw.
    • The oval screw is hard to remove once fully unscrewed, to remove the screw flip the drone upside down to have the screw fall out.
  2. Yuneec Typhoon H Spring Clip  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Yuneec Typhoon H Spring Clip  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For this step the arm must be bent.
    • Remove the broken arm clip by pinching the metal top and then pull it out with an upward force.
    • The Blunt Nose Tweezers may be helpful in removing the arm clip.
    How did you get the broken piece out from under the screw?
    Richard Fuller - crwdns2934203:0crwdne2934203:0
Claire Luce
crwdns2935283:004/16/18crwdne2935283:0
371 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G3, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S22-G3, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S22G3
what function does the little screw have?
Ruud - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,145
