The guide instructs you to replace the spring clip or (also known as the arm clip) at the arm attachment on the Yuneec Typhoon H.
The spring clips usually get broken during a crash.
Using a JIS #00 screwdriver, unscrew the 3mm oval screw.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the broken arm clip by pinching the metal top and then pull it out with an upward force.
How did you get the broken piece out from under the screw?
what function does the little screw have?
