Is the backplate of your Yuneec ST16s damaged or broken and needs to be replaced? Use this guide to help you replace it.
This device is an all-inclusive transmitter and receiver that gives you full control over a H520 Hexacopter during flight. It allows users to capture photos and videos with great ease.
Backplates (if damaged) can pose a great risk of increasing overall damage to your device if left unreplaced.
Before starting, make sure the device is powered completely off.
Remove the single screw from the battery compartment.
Remove the rubber bumpers from the back of the device using a spudger.
Remove the two screws located under each of the rubber bumpers.
Remove the three screws along the top of the device.
Carefully remove the backplate from the device.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
