Xiaomi Redmi Go Screen and Battery Replacement
  1. Xiaomi Redmi Go Screen and Battery Replacement, Tools required: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • An opening pick or strong fingernail to open the phone creating a gap between the case and the screen
    • A small Phillips screwdriver
    • A plastic spudger to disconnect the cables without damaging them
    • A box cutter or X-Acto knife to take off the vibrator and the cable that carries the Power/Volume buttons
    • Contact glue (liquid neoprene) to glue the vibrator, the cable that carries the Power/Volume buttons, the charger cable and the battery
  2. Xiaomi Redmi Go Screen and Battery Replacement, Remove the SIM and SD card holders: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You must remove both the SIM and SD card holders before unclipping the case
  3. Xiaomi Redmi Go Screen and Battery Replacement, Open the Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is a difficult operation and if done incorrectly, there is a significant risk of damaging the screen. Above all, do not attempt to use a knife to separate the glass from the screen.
    • To unclip the rear case, you must insert a fingernail or an opening pick between the screen glass and the case at the level of the card holders located on the left, to create a gap in which you will slide a pick.
    • Once you have an opening, insert an opening pick and leave it in place, then continue to go around the case by sliding a thumbnail or pick between the case and the screen
    • With the screen facing you, continue unclipping, preferably turning counter-clockwise to go around the bottom of the screen, then the right of the screen without damaging the push buttons, to finish from the top of the screen
    • The rear case is made of plastic and therefore withstands the manipulations required to unclip the screen without permanent warpage.
  4. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Loudspeaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Loudspeaker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 screws from the loudspeaker located at the bottom of the phone.
    • One of the screws located at the top right of the loudspeaker is covered by an opening indicator (small adhesive circle with the "MI" logo)
    • Carefully peel off the loudspeaker assembly
  5. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Charger Module: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Charger Module: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the charger module cable located at the bottom right of the battery
    • Carefully peel off the charger module starting from the left
    • Be careful not to damage the small black coax cable that connects the charger module to the motherboard
  6. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Motherboard Midframe: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Motherboard Midframe: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 8 mounting screws from the motherboard cover. One of them, located at the bottom left, is hidden by an opening indicator (small adhesive circle with the "MI" logo).
    • In general the screws are all very close to the same length, but it is recommended you use a screw mat to ensure they go back in the same hole they came out from during reassembly
    • Carefully unclip the plastic cover, taking care not to twist it too much. Lever it up with a small screwdriver on one of the corners of the screen
  7. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the 2 adhesive tabs located at the bottom of the battery
    • One at a time, pull these tabs horizontally, wrapping them around pliers or a screwdriver as you go. They will stretch to a length of around 20 to 30 cm
    • Disconnect the battery cable. The connector is located at the bottom of the motherboard between the screen connector and the charger module connector
    • Remove the battery
  8. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Charging Flex Cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The charging cable is not usually included with a replacement frame. In this case it must be removed from the old frame without damaging it.
    • Disconnect the charger module cable. The connector is located at the bottom right of the motherboard
    • Carefully peel off the charger cable located on the right of the frame if it is not included with the new screen
    • Keep the flex cable away from dust so as not to degrade its adhesive
  9. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Motherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully disconnect the following:
    • The touch connector located at the top right of the motherboard
    • The volume/power cable connector, located on the left
    • The screen cable connector, located at the bottom left
    • Remove the motherboard by lifting it from the bottom
    • Be careful not to lose the black rubber gasket that surrounds the camera. Do not forget to disconnect the black coax cable that connects the motherboard to the charger module
  10. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Vibrator: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Vibrator: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a sharp blade, slice the adhesive under the vibrator's printed circuit to carefully remove it
    • Carefully remove the remaining glue under the vibrator with a sharp blade
    • Glue the vibrator back onto the new screen frame, taking care to position it correctly between the two small lugs on the metal frame
    • To bond with neoprene glue, proceed as follows:
    • Put a dot of glue on the vibrator motor
    • Press the motor into place so that the glue spreads over the motor and the frame
    • Immediately remove the motor and wait a few minutes for the glue to dry a little
    • When the glue is no longer liquid, but it still sticks slightly to the finger, position the motor into position and press. The bond will be solid after a few hours
  11. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Earpiece Speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a very small flat screwdriver remove the earpiece speaker located at the top of the phone
    • Place it directly on the new screen so as not to get the orientation wrong
    • The contacts that form a small bump at the end of the two copper blades are oriented downwards
  12. Xiaomi Redmi Go Screen and Battery Replacement, Remove the Power and Volume Buttons: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Power and Volume Buttons: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Remove the Power and Volume Buttons: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully use a flat spudger or a sharp blade between the frame of the screen and the cable which supports the power and volume buttons, located on the left of the telephone to slice the adhesive and remove this cable
    • Be careful not to deform the flex cable to keep it flat for reinstallation
    • Carefully remove the glue on the back of the flex cable with a fingernail or a plastic spudger
    • Place the cable on the new chassis and check that it is positioned flat on the edge of the frame just flush with the metal edge of the chassis
    • Glue the flex cable with a thin line of neoprene glue (see step 9 for gluing instructions)
  13. Xiaomi Redmi Go Screen and Battery Replacement, Reassemble the Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Reassemble the Motherboard: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully fold the touch screen flex connector located at the top left upwards
    • Place the motherboard on the new screen, taking care to position the headphone jack and the front camera in their respective slots. Be sure the rubber seal for the rear camera is in place.
    • Check that the card is correctly positioned in relation to the two small metal guide pins on the chassis (circled in green)
    • Temporarily secure the motherboard in the chassis with one of the 8 screws of the midframe cover
    • Plug in the touch screen connector, located at the top right of the motherboard
    • Plug in the power and volume button cable, located to the left of the motherboard
    • Plug in the screen cable, located at the bottom left of the motherboard.
    • The connection between components is a delicate operation which determines the proper functioning of the phone. There's nothing more stupid than having to disassemble it again because one of them is poorly connected. To do this, position the cable, press gently with the flat tip of a finger in the center of the connector. You should feel a "click".
  14. Xiaomi Redmi Go Screen and Battery Replacement, Fit the Charging Assembly: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Fit the Charging Assembly: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the new screen, remove the two blue stickers that protect the adhesive used to secure the charger module and the micro USB connector
    • Replace the charger module by positioning it correctly in relation to the two small metal lugs located on the chassis (a small cylindrical point located at the top right and a small protrusion located just above and to the right of the micro USB connector)
  15. Xiaomi Redmi Go Screen and Battery Replacement, Installing the Charging Flex Cable: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Installing the Charging Flex Cable: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Plug the charger flex cable into the motherboard
    • Plug the other end into the charger module
    • On the frame of the screen, in the path of the charger cable, place a thin line of neoprene glue
    • Apply the flex cable to the frame to distribute the glue on the flex cable and in the path of the flex cable
    • Wait a few minutes and stick the cable onto the chassis starting from the center and flattening the cable going up and down towards the two connectors
    • Form the cable near the connectors without forcing it too much so as not to damage it
    • Check that the black coax antenna cable that connects the charger module to the motherboard is correctly positioned in its channel
  16. Xiaomi Redmi Go Screen and Battery Replacement, Install the Battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Install the Battery: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place 2 dots of contact adhesive (neoprene) on the chassis at the base of the battery, where the tabs are.
    • Be careful not to put too much glue because you already have to think about replacing the battery and making it easier to take off
    • Position the battery in its location in order to distribute the glue on the battery and on the chassis then immediately remove the battery
    • As with gluing the vibrator, wait a few minutes before gluing the battery
    • Reconnect the battery flex cable to the motherboard
  17. Xiaomi Redmi Go Screen and Battery Replacement, Install the Lower Speaker: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the loudspeaker module and install its 6 screws
    • Double-check on the right that the black coax antenna cable that connects the charger module and the motherboard is correctly positioned in its groove
  18. Xiaomi Redmi Go Screen and Battery Replacement, Check for Proper Operation: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before completing the complete reassembly, check the proper functioning of the phone
    • Turn on the phone and check that the vibrator is functioning
    • Take a photo with and without flash then a selfie to check the front and rear cameras as well as the flash
    • Make a call to check the microphone and earpiece speaker
    • During the call, hold your hand close to the screen to check that it turns off. This indicates that the proximity sensor is working properly.
    • Check the loudspeaker by playing music or switching to speakerphone mode during a call
    • Check that the touchscreen works correctly with a drawing application or a test application
    • Bravo, you have been meticulous, everything works perfectly!
  19. Xiaomi Redmi Go Screen and Battery Replacement, Replace the Motherboard Midframe: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xiaomi Redmi Go Screen and Battery Replacement, Replace the Motherboard Midframe: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check that the rubber surround around the rear camera is in place
    • Remove the screw previously placed temporarily to hold the motherboard in place
    • Reposition and reclip the protective cover of the motherboard and install its 8 screws
  20. Xiaomi Redmi Go Screen and Battery Replacement, Reassemble the Rear Case: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reclip the case starting at the bottom and working upwards symmetrically on the left and right sides
    • Once installed, the rear case should be perfectly joined to the frame. If this is not the case, it is possible that the battery or the speaker unit is incorrectly positioned, or the midframe cover on the motherboard is not correctly installed.
  21. Xiaomi Redmi Go Screen and Battery Replacement, Reinsert the SIM and SD Cards: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reinstall the SIM card and the SD memory card
    • Attention, the circuit contacts are oriented towards the back of the phone
The operation is accessible to any patient and meticulous person who will carefully follow the instructions of this tutorial.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Jean-Louis Moser
crwdns2935283:011/01/19crwdne2935283:0
313 crwdns2915208:0crwdne2915208:0
How is the battery and the slot
Felix Osoro - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 1,312
