Xiaomi Mi Note Screen Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace your Xiaomi Mi Note's screen display.
crwdns2944105:0crwdne2944105:0
Locate the hole for the Dual SIM SD card on the left side of the phone.
Use the Dual SIM SD card removal tool (or use a paper clip) and insert it into the slot hole until the tray pops out.
Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
There is no lock on screen side so when you force pulling with sucker you only lift the phone so?
Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
No need to remove the lower part.
The position of the screw is wrong
Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
Be careful not to turntoo much the top left screw, next to the lens. It's close to the white film of the screen , you may hurt it (i did)
Before removing the battery, it is better to hold the phone in a warm place, so that the adhesive tape is easier to remove.
Use a spudger to detach the ribbons connected to the motherboard using an upward prying motion.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to detach the small ribbon on left side located near the volume buttons using an upwards prying motion.
You will also need to detach the microphone cord located on the right side along the frame using an upwards prying motion as well.
Use a tweezer to lift and remove the motherboard from the frame.
Peel back the ribbon that is adhered to the metal surface as shown.
Using tweezers slowly start prying upwards at the locations shown in the images. After carefully prying around the edges of the dock connector, it can now lifted upwards out of the frame.
Using a spudger detach the top two ribbons that connect the screen to the touch sensor and motherboard using an upwards prying motion.
Using tweezers lift the two remaining ribbons from the bottom frame by grasping the ribbons at any point and lifting towards the bottom of the frame.
Peel back the ribbon attached to the back metal frame.
Use your spudger at any point to get underneath the metal frame. Slide the spudger around the sides of the metal to free it from the frame.
Apply considerable force to the back corners using your spudger to help relieve it of the adhesive as shown.
Once you have freed the screen from a portion of the adhesive, wedge your spudger around the front edge to work around the edges of the screen and frame in order to fully remove it from the frame.
crwdns2935229:021crwdne2935229:0
Looks like there is no procedure to explain how to put a new screen on there.
You don't need a Screen now. You have now successfully screwed your phone to a whopping 100%.
Hello, I have unmounted my mi note pro to change the battery. I successfully changed it but now my phone's touch screen does not work anymore. The screen displays but the touch function doesn't work. Can someone help me identify the part I might have damaged or disconnected accidentally?
