Use this guide to replace a faulty cooling fan in an Xbox Series X. You can also follow this guide to remove a dusty or dirty fan to clean it out.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
Recommend using a hair dryer to soften the label adhesive.
Microsoft can void your warranty. They can use whatever excuse if it is sent in because you opened it and you cannot prove you didn’t damage it.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
Remove the back panel.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.5 mm pancake screw
Two 8.8 mm screws
are there any 10.5mm wide head screw for the xbox fan for sale because i need a replacement because i accidentally broke mine
If the 10.5 mm screw isn’t budging, use some pliers to loosen it
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
But don’t pull the connectors with tweezers because you will inevitably still damage the cable as you have no grip on the connector and the tweezers will slip.
Tweezers do not work
Terrible guide almost broke my fan connector
Slide the fan out of its slot to remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
crwdns2935229:027crwdne2935229:0
Thank you for the support! I picked up the "Essential Electronics" and it provided all i needed. Excellent tool kit!
