Xbox Series X Fan Replacement
crwdns2869540:0crwdne2869540:0: 67K
25
185
1,085
67,101
crwdns2955950:0crwdne2955950:0: 18
crwdns2960004:017crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 37
crwdns2959974:037crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 6
crwdns2959982:06crwdne2959982:0
crwdns2955944:0crwdne2955944:0: 15 - 30 crwdns2931279:0crwdne2931279:0
Use this guide to replace a faulty cooling fan in an Xbox Series X. You can also follow this guide to remove a dusty or dirty fan to clean it out.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
    1. Xbox Series X Fan Replacement, Uncover the back panel screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series X Fan Replacement, Uncover the back panel screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before you begin, completely power down and unplug all cables from your console.
      • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
    2. Xbox Series X Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
      • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
      • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
      • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    3. Xbox Series X Fan Replacement, Remove the back panel screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Magnetic Project Mat
      $19.95
      • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    4. Xbox Series X Fan Replacement, Unclip the back panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement, Unclip the back panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement, Unclip the back panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
      • Pry up the back panel to release it from the locking clips.
    5. Xbox Series X Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series X Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
    6. Xbox Series X Fan Replacement, Remove the back panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement, Remove the back panel: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement, Remove the back panel: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
      • During reassembly, press along the edges of the back panel to snap it into place.
    7. Xbox Series X Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The back panel slots into a gap at the top of the shell.
      • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
      • Remove the back panel.
    1. Xbox Series X Fan Replacement, Remove the fan screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
      • One 10.5 mm pancake screw
      • Two 8.8 mm screws
    2. Xbox Series X Fan Replacement, Disconnect the fan cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement, Disconnect the fan cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series X Fan Replacement, Disconnect the fan cable: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
      • Always pull cables by their connectors and not the wires themselves.
      • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
    3. Xbox Series X Fan Replacement, Remove the fan: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series X Fan Replacement, Remove the fan: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the fan out of its slot to remove it.
      • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
      • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
crwdns2935229:037crwdne2935229:0
Carsten Frauenheim
171,689 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
Staff
crwdns2935297:072,885crwdne2935297:0
Thank you for the support! I picked up the "Essential Electronics" and it provided all i needed. Excellent tool kit!
Modesto Delvalle Jr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 25
crwdns2936753:07crwdne2936753:0 185
crwdns2936753:030crwdne2936753:0 1,085
crwdns2959996:0crwdne2959996:0 67,101
