Use this guide to replace the southbridge board on an Xbox Series X (2TB Galaxy Black edition).
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing the console.
Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
Remove the back panel.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.5 mm pancake screw
Two 8.8 mm screws
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
Slide the fan out of its slot to remove it.
Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
Remove the base.
Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
Lift up the optical drive's vibration isolator to remove it.
Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
Use your fingers to pull up and disconnect the data cable from the optical drive.
Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
Gently peel the taped USB port ribbon cable off of the heatsink.
Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
Use two hands to lift out the chassis to remove it from the shell.
crwdns2935267:0crwdne2935267:0Dust Blower$5.99
Gently place the chassis heatsink-side down on a clean work surface.
Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
Use a T8 Torx driver to remove the three screws securing the power cable port to the chassis:
Two 13.1 mm‑long screws
One 35 mm‑long screw
Lift the power connector out of its recess in the chassis.
Unlatch and open the lid on the power cable's plastic guide.
Lift the power cable out from underneath the extra section of the cable guide.
Use a T8 Torx driver to remove the ten screws securing the board shield:
Seven 8.7 mm‑long screws
Two 35 mm‑long screws
One 13 mm‑long screw
Hold the power supply cable out of the way and lift the board shield straight up to remove it.
Open the lid on the power supply's plastic cable guide.
Use your fingers to pinch the power supply's two‑pin power connector, so the locking tab opens outward.
With the locking tab open, lift the connector straight up and out of its socket.
Repeat the previous step to disconnect the power supply's 10‑pin connector.
Pull the end of the rubber strap down and away from the chassis to unlatch it.
Pull the chassis strap off its three alignment posts and unlatch it from the sides of the power supply.
Use a T8 Torx driver to remove the four screws securing the corners of the power supply:
Three 35 mm‑long silver screws
One 8.7 mm‑long black screw
Lift the power supply straight up and remove it.
Use a T8 Torx driver to remove the three 8.7 mm‑long screws securing the Wi-Fi antenna board.
Grip the antenna board and pull it directly away from the center chassis to disconnect it.
Remove the antenna board.
Use your fingers to pinch the locking tab in the center of the interconnect cable connector.
While pinching the tab, insert the flat end of a spudger between the top of the socket and the connector's tab.
Twist the spudger to lift the connector out of its socket until the clip in the center disengages.
Use your fingers to pull the connector straight up and out of its socket.
Lift the center chassis off the motherboard and heatsink assembly, routing the interconnect cable through its cutout.
Use a T8 Torx driver to remove the seven 8.7 mm‑long screws securing the southbridge board shield.
Lift up to remove the power supply cable guide from the southbridge board.
Remove the southbridge board from the center chassis.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
