Follow this complete guide to remove and replace the motherboard in an Xbox Series S.
Note: When removing the heat sink, be sure to replace the thermal compound material between the heat sink and the plate. Standard thermal paste isn’t suitable for filling larger gaps, so you’ll need to use thermal putty or a high viscosity thermal paste instead. Use standard thermal paste, however, for the APU.
Important: In this guide, some minor photo inconsistencies involving the exterior Bluetooth, Wi-Fi, and power boards are present. They don't affect the repair procedure, but you can help this guide by taking, editing, or uploading new ones.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
Lift straight up and remove the bottom panel from the plastic case.
Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
Remove the plastic case from the chassis.
Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Bluetooth board to the long edge of the chassis.
Use a spudger to pry and loosen the Bluetooth board.
Pull the Bluetooth board straight out to disconnect it from the chassis.
Use a T8 Torx driver to remove the 9.5 mm-long screw securing the power button board to the chassis.
Use a spudger to pry and loosen the power button board.
Pull the power button board straight out to disconnect it from the chassis.
Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Wi-Fi board to the short edge of the chassis.
Use a spudger to pry and loosen the Wi-Fi board.
Pull the Wi-Fi board straight out to disconnect it from the chassis.
Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
Flip the device over.
Lift the upper chassis straight up to remove it.
Lift the power supply straight up to disconnect it from the motherboard.
Remove the power supply.
Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
Use your fingers to pull and disconnect the fan connector from its motherboard socket.
Lift the fan straight up to remove it from the motherboard.
crwdns2931653:019crwdne2931653:0 Remove the motherboard screws
crwdns2944590:019crwdnd2944590:021crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
Use a T8 Torx driver to remove the four 9.4 mm-long screws securing the motherboard to the chassis.
Insert a spudger into the locking clip located on the front-left corner of the chassis.
Lift straight up to remove the clip.
Grasp the heat sink with your fingers and lift up the front of the motherboard up above the edge of the chassis.
Pull the motherboard towards the front of the chassis to remove it.
Use a T8 Torx driver to remove the 5.1 mm-long screw securing the SSD card to the motherboard.
Pull the SSD card straight out and remove it from the motherboard.
crwdns2935267:0crwdne2935267:0Flathead 1.5 mm Screwdriver$5.49
Insert a 1.5 mm flathead screwdriver from the top between the heat sink pin and the x-clamp.
Pry the x-clamp out and away from the heat sink pin to loosen the x-clamp.
With the head parallel to the motherboard, insert a flathead screwdriver from the side between the heat sink pin and the x-clamp hook.
Twist the flathead screwdriver clockwise to pry the bottom edge of the x-clamp out of the groove in the heat sink pin.
Continue to use the same technique described in the previous two steps on all of the heat sink pins until the x-clamp is disconnected.
Flip the motherboard over.
Lift the heat sink straight up to remove it from the motherboard.
crwdns2935267:0crwdne2935267:0iFixit Thermal Putty$9.95
Only the motherboard remains.
Follow this guide for more specifics on how to reapply thermal paste to the processor and shield plate.
crwdns2935229:023crwdne2935229:0
crwdns2947412:09crwdne2947412:0
for some reason to me it seems like the apu is just an am4 cpu stuck on to the motherboard, could you guys do some measuring to find out?
Where can I get a new motherboard and new replacement parts ? Please help
Exactly, where can anyone get a motherboard?
I mean, dismounting it is the easy part!
I’m looking for a replacement motherboard. Has anyone figured out where to get one?
Among us work great
