Xbox Series S Motherboard Assembly Removal
crwdns2862623:0crwdne2862623:0
crwdns2948751:0crwdne2948751:0
  1. Xbox Series S Motherboard Assembly Removal, Peel off the sticker coverings: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Peel off the sticker coverings: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Peel off the sticker coverings: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you start this guide, turn off the Xbox and unplug any cables from it.
    • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
  2. Xbox Series S Motherboard Assembly Removal, Remove the back panel screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
  3. Xbox Series S Motherboard Assembly Removal, Remove the bottom panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the bottom panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the bottom panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
    • This slides the clips out of the slots on the plastic case.
    • Lift straight up and remove the bottom panel from the plastic case.
  4. Xbox Series S Motherboard Assembly Removal, Remove the plastic case screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
  5. Xbox Series S Motherboard Assembly Removal, Remove the plastic case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the plastic case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the plastic case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
    • As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
    • The back panel should now settle on top of the clips on the back of the plastic case.
    • The back panel is permanently attached to the aluminum chassis.
    • Do not attempt to fully remove the chassis from the plastic case with this technique. You may risk breaking your case.
  6. Xbox Series S Motherboard Assembly Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
    • You may need to lift the chassis to free it from the clips on the bottom-front of the plastic case during this process.
    • Remove the plastic case from the chassis.
  7. Xbox Series S Motherboard Assembly Removal, Remove the power button board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T8 Torx driver to remove the 9.5 mm-long screw securing the power button board to the chassis.
  8. Xbox Series S Motherboard Assembly Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry and loosen the power button board.
    • Do not pry from the bottom of the power button board as it may bend the connector.
    • Pull the power button board straight out to disconnect it from the chassis.
  9. Xbox Series S Motherboard Assembly Removal, Remove the Wi-Fi board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Wi-Fi board to the short edge of the chassis.
  10. Xbox Series S Motherboard Assembly Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry and loosen the Wi-Fi board.
    • Do not pry from the bottom or sides of the Wi-Fi board as it may bend the connector.
    • Pull the Wi-Fi board straight out to disconnect it from the chassis.
  11. Xbox Series S Motherboard Assembly Removal, Remove the Bluetooth board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Bluetooth board to the long edge of the chassis.
  12. Xbox Series S Motherboard Assembly Removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry and loosen the Bluetooth board.
    • Do not pry from the bottom or sides of the Bluetooth board as it may bend the connector.
    • Pull the Bluetooth board straight out to disconnect it from the chassis.
  13. Xbox Series S Motherboard Assembly Removal, Remove the power supply screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
  14. Xbox Series S Motherboard Assembly Removal, Remove the upper chassis: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the upper chassis: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over.
    • Lift the upper chassis straight up to remove it.
  15. Xbox Series S Motherboard Assembly Removal, Remove the power supply: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the power supply: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the power supply: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the power supply straight up to disconnect it from the motherboard.
    • Remove the power supply.
  16. Xbox Series S Motherboard Assembly Removal, Remove the fan screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
  17. Xbox Series S Motherboard Assembly Removal, Disconnect the fan: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Disconnect the fan: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take care when flipping the chassis over because the fan is now loose.
    • Use your fingers to pull and disconnect the fan connector from its motherboard socket.
    • Take care not to pull on the wires when disconnecting the fan to prevent breaking the connector.
    • This connector may be difficult to remove. A good method to remove it is to shimmy the connector up and out of its socket with a spudger.
    • You may be able to remove this connector without removing the power supply with a pair of needle-nose pliers.
  18. Xbox Series S Motherboard Assembly Removal, Remove the fan: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the fan: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the fan straight up to remove it from the motherboard.
  19. Xbox Series S Motherboard Assembly Removal, Remove the motherboard screws: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T8 Torx driver to remove the four 9.4 mm-long screws securing the motherboard to the chassis.
  20. Xbox Series S Motherboard Assembly Removal, Remove the locking clip: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the locking clip: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the locking clip: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a spudger into the locking clip located on the front-left corner of the chassis.
    • This will open up the clip to make it easier to remove.
    • Lift straight up to remove the clip.
  21. Xbox Series S Motherboard Assembly Removal, Remove the motherboard: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the motherboard: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox Series S Motherboard Assembly Removal, Remove the motherboard: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the heat sink with your fingers and lift up the front of the motherboard up above the edge of the chassis.
    • Pull the motherboard towards the front of the chassis to remove it.
Robert Boyd
crwdns2935283:002/01/21crwdne2935283:0
31 158 crwdns2915208:0crwdne2915208:0
crwdns2935297:094crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 140
