Follow this guide to remove and replace the Bluetooth board from a Xbox Series S.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
Lift straight up and remove the bottom panel from the plastic case.
Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
Pull the bottom-left corner away from the chassis while swinging the chassis away from the plastic case.
Remove the plastic case from the chassis.
Use a T8 Torx driver to remove the three 9.5 mm-long screws securing the Bluetooth board to the long edge of the chassis.
Use a spudger to pry and loosen the Bluetooth board.
Pull the Bluetooth board straight out to disconnect it from the chassis.
So I just followed the disassemble guide just to clean the dust out of my series s. When I reassembled the device the controllers were no longer synced and the sync button clicks as it should but it no longer syncing my controllers. I've tried with a cord and the sync then but once the cord is removed they go back to trying to sync and the button on the console is not activating. Do I need a new module
Mind you everything else works the system starts up goes online and plays games
Where can I get a shell replacement?
King DK - crwdns2934203:0crwdne2934203:0
