Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment
Nick
crwdns2944107:0crwdnd2944107:0Nickcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Maw 6, 2025crwdne2944111:0
1 - 2 crwdns2931255:0crwdne2931255:0
crwdns2937803:0crwdne2937803:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
If your Xbox One controller has LT/RT issues (or needs manual adjustment), the issue may be due to the magnets. Use this guide to take the controller apart and re-secure the magnets.
Guide warnings
  • TO AVOID MELTING THE PLASTIC FRAME WHEN INSTALLING HEATSHRINK TUBING, ADJUST THE LIGHTER/TORCH TO THE LOWEST RELIABLE IGNITION POINT.
    • If you use a butane torch, test the setting you are going to use on something you do not mind damaging BEFORE working on the controller. Use ABS to practice.
    • Holding the flame once the heatshrink seals may damage the controller frame.
  • This is a final solution. Be prepared to write the controller off if this does not fix the problem or makes it worse.
  • This fix is specific to Model 1537/1697 controllers.
  • This procedure WILL VOID ANY PRESENT WARRANTY. Make sure the warranty is expired if you care about preserving it!
    • My controller is 17 months old. It is long out of warranty.
Guide notes
  • This guide does not apply to Model 1708 controllers. The procedure to fix the problem is different as heat shrink tubing is not required. However, it can be used as a starting point.
  • If you misalign the magnets, you may need a controller frame. Use caution when applying glue. Use of an alignment mark is HIGHLY RECOMMENDED.
  1. crwdns2935267:0crwdne2935267:0
    Essential Electronics Toolkit
    $29.95
    • Toolkit change note: Due to the EET missing several bits present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET has everything needed to complete this guide if you already own one, but if you are shopping for a new toolkit to complete this for the first time, the Pro Tech Go or refurbished Pro Tech is the current recommended kit.
  2. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 1): crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • EET owners: Your kit has this bit. No purchase needed.
    • Remove the batteries from your controller (if installed).
    • Remove the screw under the battery cover label. To do this, puncture the label where it is marked and use a TR8 driver or bit to remove the screw. TIP: This acrew us generally going to be found in the center of the label - feel around with your nail if need be to find it.
    • Remove the side trim from the controller, along with the 4 TR8 screws. Set the trim and screws aside somewhere safe.
  3. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 2): crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Opening Tool
    • Author's note: I have no intention of retaking these photos as I do not have my 1697 anymore (and avoid them when possible). I can do this with one hand, but using a pry tool in the area marked in orange makes this easier.
    • With the screws removed from the back, flip the controller to the front. Remove the front plastic cover.
    • With the front plastic cover removed, remove the back shell. A plastic pry tool can be used if it is easier.
    • Remove the shell once the battery tabs are released.
  4. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Disassemble the controller (Part 3): crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Opening Tool
    • Remove the power button cover from the controller. If the LB/RB assembly is separate, remove this next. A plastic pry tool can also be used.
    • Remove the wireless sync button. Place this on a bright surface to avoid misplacement.
  5. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Cut new heatshink tubing: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Precision Utility Knife
    • Repair one trigger at a time!
    • Before cutting the heatshrink, make TWO alignment marks (non-crossing).
    • After making alignment marks, cut the heatshrink off using a utility knife.
    • Using the old heatshrink as a reference, cut two new pieces.
  6. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Clean up the magnet(s): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Incorrect magnet alignment will result in LT/RT activation without human input.
    • After cutting the heatshrink tubing, do a test alignment before applying glue.
    • These controllers use double sided tape from the factory. Note the dimple side and clean the magnet and frame. Goo Gone can be used on difficult residue.
    • Once the parts are reasonably clean, do a test alignment and apply tape for final installation.
  7. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Align the magnet and glue it in place: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A controller frame may be required if done incorrectly. Verify the alignment before adding glue!
    • After verifying the alignment is correct, apply glue to the controller. It is best to let it cure for 24 hours if possible.
  8. Xbox One Wireless Controller 1697 LT/RT Magnet Adjustment, Install new heatshrink tubing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Heat Shrink Tubing Assortment
    $7.99
    • Soft flame lighters may melt the plastic. Blue flame lighters are generally safer for this!
    • Once the glue cures, add new heatshrink tubing.
crwdns2935229:09crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Nick
crwdns2935283:011/10/09crwdne2935283:0
95,296 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Do you know any specs on the magnet itself? I have a controller that is missing a magnet, and can’t find any information on the strength of the magnet. Without that there’s no way to get a replacement.
Eric Harper - crwdns2934203:0crwdne2934203:0
same here cant find it any were
conman3609 -
check on aliexpress they have then in stock
Noob Gamer -
Ma gachette RT reste enfoncé c quoi le problème.
Merci d'avance
Chawki Bourokba - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 172
crwdns2942667:0crwdne2942667:0 24,639
