WowWee MiP Robot Power Switch Replacement
  1. WowWee MiP Robot Power Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WowWee MiP Robot Power Switch Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
  2. WowWee MiP Robot Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WowWee MiP Robot Power Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the battery pack from the robot.
    • Remove the batteries from the battery pack.
  3. WowWee MiP Robot Power Switch Replacement, Wheel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WowWee MiP Robot Power Switch Replacement, Wheel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
    • This plastic material is not replaceable. Any damage will be noticeable.
    The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
    donna.hester7 - crwdns2934203:0crwdne2934203:0
  4. WowWee MiP Robot Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WowWee MiP Robot Power Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 12.0 mm Phillips #2 screw.
    • Hold the wheel in place, or it will rotate as you attempt to remove the screw.
  5. WowWee MiP Robot Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wheel off of the square axle.
    • Do not use excessive force while removing the wheel. Pulling too hard on the wheel can damage the axle.
  6. WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WowWee MiP Robot Power Switch Replacement, WowWee MiP Robot Body Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
  7. WowWee MiP Robot Power Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 WowWee MiP Robot Power Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 WowWee MiP Robot Power Switch Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the arms from the body.
    • Carefully open the body compartment.
    • Open the compartment slowly. There are wires connecting the two body pieces together. If pulled too hard, the wires and/or the motherboard could be damaged.
  8. WowWee MiP Robot Power Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using precision tweezers, disconnect the following three bundles of wires:
    • Connecting the battery pack to the motherboard.
    • Connecting the power switch to the motherboard.
    • Connecting the speaker to the motherboard.
  9. WowWee MiP Robot Power Switch Replacement, Power Switch: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 WowWee MiP Robot Power Switch Replacement, Power Switch: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 9.3mm Phillips #1 screws.
  10. WowWee MiP Robot Power Switch Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power switch assembly from the body by gently pulling straight out on the wires.
Daniel Burkholder
crwdns2935283:002/16/16crwdne2935283:0
623 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-4, Wollert Spring 2016 crwdns2935289:0USF Tampa, Team 3-4, Wollert Spring 2016crwdne2935289:0
USFT-WOLLERT-S16S3G4
where can i buy the power switch of MiP
Reinejoe Cacho - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 702
