WowWee MiP Robot Power Switch Replacement
crwdns2942287:0crwdne2942287:0The power switch turns the MiP on or off. If it's malfunctioning the robot will not work.
crwdns2944105:0crwdne2944105:0
Remove the three 12.0 mm Phillips # 2 screws from the battery cover.
Carefully pull the battery pack from the robot.
Remove the batteries from the battery pack.
Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
The hubcap won't come out. It's flat & tight. Even a tiny screwdriver for eyeglass repair can not get under it. Any tricks forgetting it out?
Remove the 12.0 mm Phillips #2 screw.
Pull the wheel off of the square axle.
Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
Remove the arms from the body.
Carefully open the body compartment.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using precision tweezers, disconnect the following three bundles of wires:
Connecting the battery pack to the motherboard.
Connecting the power switch to the motherboard.
Connecting the speaker to the motherboard.
Remove the two 9.3mm Phillips #1 screws.
Remove the power switch assembly from the body by gently pulling straight out on the wires.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947410:01crwdne2947410:0
where can i buy the power switch of MiP
