Wii U GamePad Back Panel Replacement
Kim Arre
crwdns2944107:0crwdnd2944107:0Kim Arrecrwdnd2944107:0crwdnd2944107:0crwdnd2944107:08crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 5, 2024crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace the back panel on your Nintendo Wii U GamePad.
crwdns2944105:0crwdne2944105:0
  1. Wii U GamePad Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Back Panel Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Back Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Back Panel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Back Panel Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Back Panel Replacement, Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Wii U GamePad Back Panel Replacement, Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Wii U GamePad Back Panel Replacement, Back Panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
    how do i replace the whole front and back casing?
    enbodylin - crwdns2934203:0crwdne2934203:0
    bruh the ifix it screwdriver dont reach down the whole way
    Michael - crwdns2934203:0crwdne2934203:0
    I feel like it’s important to mention how deep some of these holes are. Your screwdriver might not reach. Mine sure didn’t.
    greatshadowdude - crwdns2934203:0crwdne2934203:0
    I had to shove some tissue into the screwdriver bit holder to get it to reach
    Andrew Walker - crwdns2934203:0crwdne2934203:0
  4. Wii U GamePad Back Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii U GamePad Back Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
    You don't have to remove just be careful
    Heather Sheppard - crwdns2934203:0crwdne2934203:0
    I tried to remove like at least 6 times but I wasn’t able to. Using tweezer, my nails, long nose pliers. There could be a lock but I gave up since I’m afraid if I put more force I might accidentally pull the wires. I’m able to remove the left and right analog stick with the back plate plugged, as mentioned, just be careful.
    Royce Remulla - crwdns2934203:0crwdne2934203:0
    I was stuck on this step for a while - note that you’re only removing the little white plastic bit. The beige or yellowish plastic bit is attached to the board. I needed to use pliers to carefully grab just the white plastic bit and wiggle it side to side.
    Nova H - crwdns2934203:0crwdne2934203:0
crwdns2935229:012crwdne2935229:0
Kim Arre
crwdns2935283:001/11/13crwdne2935283:0
5,331 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-20, Forte Winter 2013 crwdns2935289:0Cal Poly, Team 17-20, Forte Winter 2013crwdne2935289:0
CPSU-FORTE-W13S17G20
crwdns2935297:040crwdne2935297:0
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 67
crwdns2936753:030crwdne2936753:0 181
crwdns2942667:0crwdne2942667:0 16,484
