This guide will demonstrate how to replace the Power Supply inside the Wii Balance Board.
Flip device upside-down so the plastic white board is facing the ground.
Locate the four feet in the corners of the Balance Board.
Unscrew the three 12.7 mm Phillips screws from each foot cover.
Remove the gray plastic ring from the actual foot by lifting it up.
Separate the loose foot from the device by lifting it up.
Repeat steps two and three on the remaining four feet.
how to completely remove and then put back in would be helpful as that's what the title of this post is…. right?
Unscrew the ten 12.7 mm Phillips #1 screws.
Lift off the gray back cover.
Top Anleitung, aber kann nirgends die Platine finden.... Könnt ihr da helfen? Danke!!!
Locate the gray battery compartment.
Push the tab on the bottom and lift up completely to remove the cover to the batteries.
Unscrew the two 6.35 mm Phillips #1 screws.
Slide the battery case out.
Just wanted to say THANKS it really helped & saved me having to get a new one or repaired. u rock! Sending good karma your way!
Were can I get a battery case replacement holder for my wii fit balance board
Do we wipe down something after that?
New batteries. Start “button" blinks, then turns off. Any suggestions?
After removing it I soaked the battery case in vinegar for maybe 30 minutes. A little toothbrush work and all of the crap was gone. Rinsed it, dried it, put it back in. While it soaked I also used vinegar on the spring battery terminal that is cabled to the base. Cleaned up very nicely.
Unscrew the four 12.7 mm #1 screws.
Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
Lift out the power supply. It is not screwed in.
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
Hi, My batteries leaked over the UART_RX pin and I don't know how to fix it
