Wii Balance Board Frame Replacement
  1. Wii Balance Board Frame Replacement, Unscrewing the Foot Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip device upside-down so the plastic white board is facing the ground.
    • Locate the four feet in the corners of the Balance Board.
    • Unscrew the three 12.7 mm Phillips screws from each foot cover.
  2. Wii Balance Board Frame Replacement, Removing the Foot Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the gray plastic ring from the actual foot by lifting it up.
  3. Wii Balance Board Frame Replacement, Removing the Foot: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the loose foot from the device by lifting it up.
  4. Wii Balance Board Frame Replacement, Removing the Additional Feet: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat steps two and three on the remaining four feet.
    how to completely remove and then put back in would be helpful as that's what the title of this post is…. right?
    Nelda Murray - crwdns2934203:0crwdne2934203:0
  5. Wii Balance Board Frame Replacement, Unscrewing the Back Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the ten 12.7 mm Phillips #1 screws.
  6. Wii Balance Board Frame Replacement, Removing the Back Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off the gray back cover.
    Top Anleitung, aber kann nirgends die Platine finden.... Könnt ihr da helfen? Danke!!!
    Dominik - crwdns2934203:0crwdne2934203:0
  7. Wii Balance Board Frame Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Wii Balance Board Frame Replacement, Battery Compartment: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the gray battery compartment.
    • Push the tab on the bottom and lift up completely to remove the cover to the batteries.
  8. Wii Balance Board Frame Replacement, Removing the Battery Case: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 6.35 mm Phillips #1 screws.
    • Slide the battery case out.
    Just wanted to say THANKS it really helped & saved me having to get a new one or repaired. u rock! Sending good karma your way!
    scottydecept - crwdns2934203:0crwdne2934203:0
    Were can I get a battery case replacement holder for my wii fit balance board
    Jacqueline Booth - crwdns2934203:0crwdne2934203:0
    Do we wipe down something after that?
    Kandace Lavender - crwdns2934203:0crwdne2934203:0
    New batteries. Start “button" blinks, then turns off. Any suggestions?
    Ginny Butler - crwdns2934203:0crwdne2934203:0
    After removing it I soaked the battery case in vinegar for maybe 30 minutes. A little toothbrush work and all of the crap was gone. Rinsed it, dried it, put it back in. While it soaked I also used vinegar on the spring battery terminal that is cabled to the base. Cleaned up very nicely.
    jatrac1 - crwdns2934203:0crwdne2934203:0
  9. Wii Balance Board Frame Replacement, Unscrewing the Frame: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 12.7 mm #1 screws.
  10. Wii Balance Board Frame Replacement, Removing the Frame: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the frame, circuit board, and power supply out of the front case. These components are all connected.
  11. Wii Balance Board Frame Replacement, Removing the Power Supply: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out the power supply. It is not screwed in.
Cory Olson
crwdns2935283:009/29/14crwdne2935283:0
915 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-8, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 13-8, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S13G8
Top Anleitung, aber wo kann ich die Platine herbekommen? Danke!!!
crwdns2942667:0crwdne2942667:0 3,624
