If the processor fan stops working, and the system is overheating, Follow this guide to replace it.
There are ten 5mm screws surrounding the edge of the cover.
A rubber cap covers the eleventh 5mm screw (in the center).
Remove the screws using a Phillips #00 screwdriver.
Pry between the casing and cover using a plastic wedge tool.
Use the wedge tool to move along the case & slowly pry it open.
The wire for the 12v charging port connects the cover to the casing.
Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
Disconnect the battery.
Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
At this point you should be able to:
Remove the three 3mm screws using a Phillips #00 screwdriver.
Plastic wire guides hold the wire in place. Manipulate the wire out from these guides.
Remove the connector from the motherboard.
