Toshiba Satellite U840W 12V Charging Port Replacement
  1. Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite U840W 12V Charging Port Replacement, Toshiba Satellite U840W Disassembly Guide: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are ten 5mm screws surrounding the edge of the cover.
    • A rubber cap covers the eleventh 5mm screw (in the center).
    • Remove the screws using a Phillips #00 screwdriver.
  2. Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry between the casing and cover using a plastic wedge tool.
    • Use the wedge tool to move along the case & slowly pry it open.
    • The wire for the 12v charging port connects the cover to the casing.
  3. Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect this connector from the motherboard to avoid damaging the motherboard or charging port cable.
  4. Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery.
    • Hold down the power button for ~10 seconds to discharge any stored electricity from the motherboard.
  5. Toshiba Satellite U840W 12V Charging Port Replacement, 12V Charging Port: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the connector from the motherboard.
    • This separates the only connection from the motherboard to the cover.
  6. Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw holding 12v charging port to the cover.
  7. Toshiba Satellite U840W 12V Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 12v charging port from the cover.
Joshua Pedersen
crwdns2935283:002/04/19crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
Gateway, Team S1-G1, Saknee Spring 2019 crwdns2935289:0Gateway, Team S1-G1, Saknee Spring 2019crwdne2935289:0
GCC-SAKNEE-S19S1G1
crwdns2942667:0crwdne2942667:0 332
