Toro Stump Grinder 22615HD 2017 Guard Plate Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Turn off the power: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Turn off the power: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, ensure the machine is powered down and cool to the touch.
    • Turn the ignition switch to the off position.
  2. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Close the fuel valve: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Close the fuel valve: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the fuel cutoff valve switch into the off position.
  3. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Disconnect the spark plug: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Disconnect the spark plug: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  4. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Tilt the cutter wheel up: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tilt the machine so that it is resting on the handle with the cutter wheel raised.
  5. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Remove the belt guard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Remove the belt guard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 14 mm socket to remove the fasteners securing the belt guard:
    • One 10 mm bolt
    • One 10 mm nut
  6. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the belt guard.
  7. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Remove the drive belt: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Remove the drive belt: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Remove the drive belt: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 9/16 inch socket to loosen the four nuts securing the bottom of the motor enough to allow the motor to slide freely. Do not remove the nuts.
    • Use a 1/2 inch wrench in combination with the socket wrench to hold the bolts in place.
  8. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch wrench to loosen the two bolts behind the centrifugal clutch enough to allow the motor to slide freely. Do not remove the bolts.
  9. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wrap a piece of tape around the upper half of the tensioner bolt to mark the location of the second nut.
    • Use a 9/16 inch wrench to loosen the nut on the lower half of the tensioner bolt until the motor can slide forward as much as possible.
    • During reassembly, reference the tape to position the outer nut into the same location as before to ensure proper belt tension.
  10. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the engine towards the cutter blade to loosen the drive belt.
  11. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the drive belt up and away from the machine while rolling it towards the cutter head to gradually roll it off of the pulley.
  12. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the drive belt.
  13. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Remove the centrifugal clutch: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an impact wrench with a 9/16 inch socket to remove the bolt and washer securing the centrifugal clutch to the spindle.
  14. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a jaw puller to extract the centrifugal clutch from the spindle:
    • Place the center screw so that it is in line with the center of the spindle.
    • Hook the jaws around the back edge of the clutch assembly.
    • Tighten the center screw until the centrifugal clutch is removed from the spindle.
  15. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the centrifugal clutch and shaft key from the spindle.
  16. crwdns2944590:016crwdnd2944590:018crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Remove the pulley: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/8 inch hex key to remove the pulley set screw.
  17. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a universal puller to remove the pulley from the cutter wheel shaft:
    • Attach the universal puller to the pulley using the three bolts provided on the pulley.
    • Use a wrench to torque down the center screw to slowly loosen the pulley.
    • This may take a lot of force.
    • If the pulley seems to be stuck after significant pressure is applied with the universal puller, use a blowtorch to apply heat where the pulley contacts the shaft.
  18. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If heat was used to loosen the pulley, use gloves when removing it.
    • Pull the pulley off of the shaft to remove it.
    • Remove the shaft key.
  19. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement, Remove the guard plate: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch socket to remove the two bolts and washers securing the guard plate to the motor.
    • During reassembly, do not tighten these bolts all the way down until the belt is tensioned.
  20. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 9/16 inch socket to remove the bolt and washer securing the guard plate to the frame.
    • Use a 5/8 inch wrench in combination with the 9/16 inch socket to hold the standoff in place.
    • Remove the bolt, washer, and standoff.
  21. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 9/16 inch socket to remove the bolt and accompanying washer securing the guard plate to the frame.
  22. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 5/8 inch socket to remove the nut securing the guard plate to the frame.
  23. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/2 inch socket to remove the bolt next to the cutter wheel shaft securing the guard plate to the frame.
  24. Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toro Stump Grinder 22615HD 2017 Guard Plate Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the guard plate from the frame.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
88.182 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 17
