Texas Instruments TI-30 XS Multiview Solar Panel Replacement
  1. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the device: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the screw is not turning, do not force it. This can strip the screw. See the How to Remove a Stripped Screw guide if the screw is already stripped.
    • Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
    • Use the spudger to pry into the space between the blue back cover and the white body to take off the back cover.
    I didn’t have a spudger but a flat 3/32” jeweler’s screwdriver worked just as well. Also, the battery slides out the side, nothing to undo. I slid it out using a jeweler’s screwdriver. (Don’t touch any electrical components or traces with the metal tip.) If you’re not sure the battery is good, turn the unit over and see if there is anything displaying, or run a test operation like 2 x 2 etc. to check before putting the back into place.
    Therese S - crwdns2934203:0crwdne2934203:0
  2. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Open the battery compartiment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
    • Lift the metal plate from the battery and set it to the side.
  3. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Eject the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger to lift the battery up from the black holder.
    Funktioniert beim 30X Pro Multiview gleich?
    Dihydrogen Dioxide - crwdns2934203:0crwdne2934203:0
    Is a spudger really necessary. I don't have it, just the phillips 00 screwdriver. Do I need to go out and buy one of these?
    Abdullah Siddiqui - crwdns2934203:0crwdne2934203:0
    You can just use a fingernail to open it.
    Jeffrey Johnson - crwdns2934203:0crwdne2934203:0
    • Put the new CR2032 battery in. Never insert a different type of battery!
    • Reverse the steps 2 and 1.
    And if the calculator doesn’t turn on if you press “on”,
    press the “reset” button on the back.
    Arne Cl - crwdns2934203:0crwdne2934203:0
    my TI-30XS battery was mounted directly onto the circuit board under a metal clip, the black battery holder doesn't exist at all. Anyway the battery is the still the same CR2032.
    Ole Debess - crwdns2934203:0crwdne2934203:0
    Different revisions of the board. I also had the version you described.
    Pencil43 -
  4. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Free the solar panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the #00 Phillips screwdriver to remove the one 3mm Phillips screw holding the solar panel in place.
  5. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Carefully pull the panel out: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful not to pull the solar panel too far out, as the wires connecting it to the calculator are fragile and could be ripped off.
    • Carefully pull the solar panel away from the calculator, as shown to the left.
  6. Texas Instruments TI-30 XS Multiview Solar Panel Replacement, Unsolder the wires: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The capacitor might not be discharged. Proceed with caution.
    • Unsolder the three wires from the motherboard.
    • Unsoldering help can be found here.
    • To re-solder the wires from the new solar panel to the calculator motherboard take notice of the color and placement of the wires.
Aaron Feinstein
crwdns2935283:010/01/15crwdne2935283:0
349 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-2, Forte Fall 2015 crwdns2935289:0Cal Poly, Team 11-2, Forte Fall 2015crwdne2935289:0
CPSU-FORTE-F15S11G2
Do you know where I could get a replacement solar panel for the calculator?
Josh - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,478
