TI-84 Plus CE Recovery Techniques.
TheLastMillennial
crwdns2944107:0crwdnd2944107:0TheLastMillennialcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0February 6, 2024crwdne2944111:0
crwdns2931283:05crwdne2931283:0 - crwdns2931287:010crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
This guide is compatible with all varients of the TI-84 Plus CE and TI-83 Premium CE.
Most issues will be fixed with at least one of these steps, however they may end up erasing data in your calculator's RAM or ROM (Archive). To prevent data loss, backup your calculator to your computer or Archive any important information.
Please note that each step is its own solution. You do not need to perform every step if your calculator starts working again.
crwdns2943227:0crwdne2943227:0
crwdns2936621:0crwdne2936621:0
  1. TI-84 Plus CE Recovery Techniques., Did you try turning it off and on again?: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Did you try turning it off and on again?: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Did you try turning it off and on again?: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Some problems can be fixed simply by powercycling.
    • Press [2nd]
    • Press [on]
    • The calculator should now be turned off.
    • Press [on] to turn it back on.
  2. TI-84 Plus CE Recovery Techniques., Perform a RAM reset with the reset button.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Perform a RAM reset with the reset button.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Perform a RAM reset with the reset button.: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This will clear all information stored in the RAM!
    • Information stored in the Archive will be safe.
    • Remove the slide case and turn your calculator on its back.
    • Take a pencil or thin object and press and hold the 'reset' button on the back of the calculator for at least 2 seconds, then release.
    • After a second or two, your calculator should say "RAM Cleared".
    TI-84 plus CE no enciende. La he puesto a cargar y parpadea con un mensaje
    Ervin Canal - crwdns2934203:0crwdne2934203:0
    Necesita una nueva batería de calculadora.
    TheLastMillennial -
  3. TI-84 Plus CE Recovery Techniques., Perform a RAM reset by removing the battery.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Perform a RAM reset by removing the battery.: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Perform a RAM reset by removing the battery.: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This will clear all information in the RAM!
    • Refer to this guide for instructions on how to remove the battery.
    • Reinsert the battery after a few seconds.
    • Your calculator should automatically turn on and display a "RAM Cleared" screen.
  4. TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 1:  TI Connect CE): crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 1:  TI Connect CE): crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 1:  TI Connect CE): crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This could erase information stored in the Archive!
    • Backup your information to your computer or another calculator if you want to save information.
    • Install TI Connect CE. (If you already have it installed, you can skip this step)
    • If you are running either MacOS or Windows, go to TI's website and download TI Connect CE.
    • If you are running Linux, install TiLP.
    • Open TI Connect CE.
    • Connect your calculator to your computer via a USB to mini USB adapter.
  5. TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 2: Initializing the calculator): crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 2: Initializing the calculator): crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 2: Initializing the calculator): crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • All warnings from Part 1 still apply.
    • Press and hold [2nd] and [del].
    • Turn the calculator over; press and release the 'reset' button.
    • Keep holding down [2nd] and [del]!
    • If you did it correctly, you will see a 'Install OS now' screen. If you do not see this screen, try again.
    • Once you see this screen, you can release [2nd] and [del].
    Right after "Waiting ..." it displays a C rather than status indicator, when I disconnect the device from my computer it goes back to normal, can someone help me fix this?
    Tirth Patel - crwdns2934203:0crwdne2934203:0
    It's common for a C to appear. Unfortunately I don't understand why it appears. What do you mean by 'it goes back to normal'? Is the calculator going back to the home screen?
    TheLastMillennial -
    No, once I unplug my calculator from my computer it displays the screen that you have listed above. Where it says "Waiting.... -" and so on. I can't get my calculator to exit this screen either way.
    This sounds like some sort of driver issue to me. Try using a different computer. You can also try using tilp which is an open source TI-Connect CE alternative. http://lpg.ticalc.org/prj_tilp/ (website is outdated but the download should still work for you)
    TheLastMillennial -
  6. TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 3: Sending the OS): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 3: Sending the OS): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 3: Sending the OS): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • WARNING: The latest OS will disable the ability to run most games and some programs! Once you update you cannot downgrade! OS 5.4.0 is the last safe OS to update to. Anything higher will require the arTIfiCE jailbreak to run many programs.
    • If you know what OS your calculator was using, then you can go ahead and search for it on TI-Planet. Otherwise, attempt to install OS 5.4.0 first. If it fails, then you should install the latest OS from TI's website.
    • Download and install OS 5.4.0: TI-84 Plus CE | TI-83 Premium CE.
    • If OS 5.4.0 is not supported, then download the latest OS: TI-84 Plus CE | TI-83 Premium CE
    • In TI Connect CE, click on 'Actions', then 'send OS/Bundle to calculators...'
    • Navigate to where you saved the OS and select it. It will take a second for TI-Connect CE to load. Once the popup appears, click 'send'.
    • This will take a few minutes to install.
  7. TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 4: Recieving the OS): crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 4: Recieving the OS): crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 TI-84 Plus CE Recovery Techniques., Re-install the OS (Part 4: Recieving the OS): crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • DO NOT UNPLUG THE CABLE DURING TRANSFER! You risk damaging your calculator!
    • Wait for the OS to send and verify.
    • Once finished, you should see a 'RAM cleared' screen. Your calculator is now finished installing the OS.
Your calculator should now be functioning.
If it is still having issues, contact Texas Instruments support:
crwdns2935229:011crwdne2935229:0
TheLastMillennial
crwdns2935283:007/18/18crwdne2935283:0
3.564 crwdns2915208:0crwdne2915208:0
crwdns2947412:020crwdne2947412:0
My calculator has not turned on for the past week. I have tried multiple USB cables and power sources, a (charged, working) battery, the On+Ac+Reset trick, and all of the techniques mentioned in this guide. The calculator still displays nothing on the screen, and windows, Ubuntu Linux, and MacOS all refuse to recognize the calculator. Drivers can’t be installed, and I even attempted a jerry-rigged USB connection using a few alligator clips (bypassing the usb connector in the calculator). Any advice? I’ll take any at this point.
Owen Sayre - crwdns2934203:0crwdne2934203:0
@the_pimaster Ok, just checking, you do have a TI-84 Plus CE? There are similar calculators out there that have different key combos. Also, what do you mean by On+Ac+Reset? The correct combination is [2nd]+[del]+Reset. I’m surprised the computer doesn’t even recognize the calculator is connected, does the LED by the USB port turn on when you connect it to power? If so, what color?
What were you doing when the calculator was last working? Did you accidentally spill something on it, drop it, or crush it?
TheLastMillennial - crwdns2934203:0crwdne2934203:0
@thelastmill Thanks for the quick response! Yes, it is definitely a TI-84 Plus CE. I just tried the 2nd+Del+Reset combo you mentioned, but still no response. Something interesting— The calculator is not showing up in Windows’ device manager nor in driver installation menus (“Unknown USB Device”) but unplugging/re-plugging or hitting the reset button triggers the “new device” sound in Windows 10. When I first plugged in the Calc, the Light by the charging port lit up red. After 2-ish hours charging, it is now green— I am aware that the battery/charging circuit is seperate from the calculator itself, which may be the source of this issue. The calculator was working last week during a math test, during which the screen turned black. The battery was charged to ~80% at the time, and the device was sitting on a desk— no physical damage occurred, and the calculator is only around a year old.
@the_pimaster Sorry it took a lot longer for this one. I’ve been asking some of my friends about this and unfortunately I think your best bet is to contact TI. I’ve never seen a calculator just… die like that before and it’s quite confused me; if I find a solution I’ll be sure to notify you. For now though you can email them at: ti-cares@ti.com or call 1-800-TI-CARES (toll free). I apologize I wasn’t able to help you with this, if TI somehow gets it working again, please inform me how they did it!
So I have an issue, my calculator has had its battery light charger indicator on forever until it dies, that was 4 months ago. Since then I have been constantly having to charge it when I use it since the battery lasts for 2.5 hours off a single charge, but unfortunately, the darn thing would not turn on last night. I have tried every cable, nothing works.
Now for my what I think happened was that I used the wrong wall plug which destroyed the capacitor. Any advice?
Alexander Mai - crwdns2934203:0crwdne2934203:0
@Infine Axel, I think this is the exact question topic you’re looking for: Why my charging light is always on? It kills the battery..
TheLastMillennial -
just try a new battery lol
Shua Manory -
TheLastMillennial, my daughter’s calculator has just done the same thing as yours. Not responding, black screen, computer is not recognizing it and when plugged in to the outlet to charge it continues to show a red light. Not responding to reset or anything, screen is black. Happened overnight, no damage. I also bought a new batter, but seem it’s not that. Did you ever get your calculator working and if so what did you do? Thanks
cnc - crwdns2934203:0crwdne2934203:0
@tfc_cnc Hi, first off I really appreciate all the information you provided, it makes this a lot easier to diagnose! Unfortunately if reinstalling the OS (step 4) does not work, then there’s nothing more you can try on the software side. However, If the battery indicator never turns green even after charging overnight then there may be a defect with the battery itself. Try replacing the battery; if that doesn’t work then I think you’ll need to contact TI Cares. I have no idea why some calculator just die for no reason. Please let me know if you get it working again!
TheLastMillennial -
I dropped my calculator and the screen froze and stopped working; everything else seems to be working it detects batter the light turns off and off when I plug into the charger; I tried everything but the screen won’t turn on. any suggestions?
sami dakka - crwdns2934203:0crwdne2934203:0
That’s interesting, does your computer recognize it when you plug the calculator in?
Just so you know, the charging circuit is separate from the rest of the calculator so it can still work even if the calculator doesn’t.
TheLastMillennial -
My problem is that the ON keypad button does nothing, but everything else works fine. I can turn on the calculator in 3 ways: 1. Remove and reinsert the battery. 2. Press the tiny reset button in the back. 3. Plug in the charging cable while connected to a charger. When it’s on, I can’t turn it off. Pressing 2nd - ON does nothing. If I leave it alone, it will power off, but pressing the ON button does nothing and I have to use one of the 3 methods above to turn it back on. I tried everything in this guide, but the problem is exactly the same which leads me to believe it’s a hardware problem. I also installed a brand new battery. Any ideas about how to fix this would be greatly appreciated.
Bob Cassidy - crwdns2934203:0crwdne2934203:0
My TI-83 calculator is just displaying 0000000 and nothing else. All tricks I found on the internet didn't work. I can't turn it off, clear its ram, or do anything. I had restored the calculator the night before after about 15 years of not using it. It doesn't respond to anything, even pressing the 2nd button doesn't change the cursor to the up arrow. I was wondering how I could fix it. Yesterday, the day I restored it, the calculator was working just fine, but today it's not working. please help.
Aleksandr Comazzi - crwdns2934203:0crwdne2934203:0
This morning, I accidentally left my TI-84 Plus CE graphing calculator in my backpack while putting it through the washing machine. I can't do anything because it won't turn on. Is there anything I can do to fix it? Any place I can go? Please help!!
Ngoc Vo - crwdns2934203:0crwdne2934203:0
Do not try to turn it on while wet! Immediately take out the battery. Disassemble the calculator using the teardown guide TI-84 Plus CE Teardown wipe down the circuit board with isopropyl alcohol and let it dry for several hours. With any luck the calculator will turn on.
If it doesn't turn on and it's less than a year old, then you can try to contact TI customer support for a replacement https://education.ti.com/en/customer-sup...
If they won't help you then you're just plain out of luck. You may be able to sell the calculator for parts but you'll still have to buy a new one.
TheLastMillennial -
Mi calculadora indica
Validing OS
calculator will restart when validation complete.
y parpadea este mensaje y no se puede reiniciar, como puedo soluciionarlo ya que se encendio despues de varios meses despues de las vacaciones
Artemio Cabanas - crwdns2934203:0crwdne2934203:0
Intente cargar la calculadora durante la noche durante al menos 8 horas.
Try charging the calculator overnight for at least 8 hours.
TheLastMillennial -
I left my calculator unused for a while, and now a message appears indicating that it is validating the operating system (OS). It wouldn’t turn on, so I connected it to a power source, but the message keeps appearing. I connected it to my computer, but it doesn't recognize the calculator. Is there a way to make it work again? I’ve seen tutorials suggesting that the battery needs to be replaced. What can I do if I can’t find a new battery?
Fabricio Fernandez - crwdns2934203:0crwdne2934203:0
You need a new battery. Some people had success manually charging the battery but this is extremely dangerous and will cause a Lithium fire or explosion if you don't know what you're doing. If your battery is bulging at all then dispose it immediately and do not attempt any further charging.
TheLastMillennial -
crwdns2936751:024crwdne2936751:0 38
crwdns2936753:07crwdne2936753:0 184
crwdns2936753:030crwdne2936753:0 741
crwdns2942667:0crwdne2942667:0 70,763
