SteelSeries Nimbus+ Thumbsticks Replacement
  1. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the phone mount: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Remove the phone mount: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the sticker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. SteelSeries Nimbus+ Thumbsticks Replacement, Unscrew the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Release the plastic clips: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Unfold the back cover assembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the battery cable: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the back cover assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover assembly.
  11. SteelSeries Nimbus+ Thumbsticks Replacement, Unscrew the board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
  12. SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 SteelSeries Nimbus+ Thumbsticks Replacement, Disconnect the thumbstick board: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
  13. SteelSeries Nimbus+ Thumbsticks Replacement, Remove the board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the board with the thumbsticks from the mainboard.
Repair didn’t go as planned? Check our Answers community for help.
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58 839 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021 895crwdne2935297:0
how can we find a replacement board with the thumbsticks?
Anne Taylor - crwdns2934203:0crwdne2934203:0
I wonder the same thing
Bizkot -
Any one found the replacement thumbsticks for the Nimbus+?
Igor Bond - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,469
