SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement
  1. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Ear Cushions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Ear Cushions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the edge of the cushion and pull out slightly.
    • Work your way around the cushion until it comes off completely.
    • Repeat for the other cushion.
    I do not believe that my Arctis 7 uses Phillips #0 it looks to be some kind of tamper proof start bit, do you know what kind that would be?
    Jerrett Smith - crwdns2934203:0crwdne2934203:0
  2. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Circuit Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
    Philips #0 doesn’t work, it’s using a weird screw head
    Mojo - crwdns2934203:0crwdne2934203:0
  3. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the speaker off the headset to expose the circuit board.
    • Be careful not to lift the speaker too quickly or too forcefully to prevent the wires from being pulled out of their connections.
  4. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 5mm screws using a Phillips #0 driver head.
  5. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the circuit board out of the plastic housing.
    • Press in on the volume wheel while pulling on the circuit board to help maneuver the circuit board out of the housing.
    I am worried about damaging the board while lifting the board out, there is quite some resistance, do I apply more pressure?
    Garrett Chambers - crwdns2934203:0crwdne2934203:0
  6. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button Cap: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button Cap: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the circuit board over and remove the keycap by pulling on it.
    Hi, my headset fell down on the floor while I was charging so the connector is now with bad conection I have to find the right position to charge the headset, do you have any tips of how can I fix it?
    Rebeca C. Dávila - crwdns2934203:0crwdne2934203:0
    Hello, where did you order the mute button cap part for this replacement?
    Pete - crwdns2934203:0crwdne2934203:0
    Same question. Where i can buy mute button?
    Mirage J - crwdns2934203:0crwdne2934203:0
  7. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement, Headset Mute Button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the wires connecting the button to the circuit board.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
  8. SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 SteelSeries Arctis Pro Plus GameDAC Headset Mute Button Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the three pins to remove the button from the circuit board.
Kyle Chang
crwdns2935283:001/24/19crwdne2935283:0
1,170 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G1, White Winter 2019 crwdns2935289:0Cal Poly, Team S18-G1, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S18G1
crwdns2935297:021crwdne2935297:0
crwdns2947412:010crwdne2947412:0
Where can you get the replacement switch?
Jason Rosa - crwdns2934203:0crwdne2934203:0
Can you provide any specs for this switch? I’d like to buy the replacement switch before disassembling the headset.
DAA - crwdns2934203:0crwdne2934203:0
I also need to know where to get the replacement switch from !
Trevor Peters - crwdns2934203:0crwdne2934203:0
If anyone wants to try it (I have not), I think the G type switch will work. BUT you will have to find a way to mount it, as it does not have the Metal case for soldering to the PCB.
Searchebay.co.uk for 11 Types, DPDT Self Latching Locking Momentary Push Button PCB SMD Switch 6 Pin
Select Type G
Try at your own risk and good luck
BTW, the size of the switch is 5.8 x 5.8 mm
How to repair mute button in the ear head.
Catherine Brown - crwdns2934203:0crwdne2934203:0
There's a thread on Reddit about this:
``https://www.reddit.com/r/steelseries/com...
Where they suggest buying 5.8x5.8mm 3 pin latching switches. People in the thread above specifically used the ones in the eBay link below:
``https://www.ebay.com/itm/185336592680``
I'll update my comment if I do this with any success.
David Zilio - crwdns2934203:0crwdne2934203:0
have you been succesfull? greetings
Max HBLAND -
The switches I bought were perfect replacements. @maxhbland75222
Soldering was very difficult for me. The pins are clearly on a ground plane so it takes a lot of heat to get the solder to let go. If you take too long to get the heat in it'll transfer heat through and melt the switch itself. I had to compensate for my cheap iron and low skill with a lot of flux, but I managed to push the pins through and get it changed. Considering how the board heat soaked the "difficult" rating really makes sense.
I should also note, I have an Arctis 9X, not an Arctis Pro. They are different products with different boards but, from what I can tell, the switches are the exact same.
David Zilio -
If you have the Arctis Pro, you need a 6 pin latching switch: https://www.ebay.de/itm/185336592680
For the Arctis 9 you need a 3pin latching switch.
INVESTEGATE - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 136
crwdns2942667:0crwdne2942667:0 11,297
